Question about Panasonic TX-32LXD70 32 in. HD-Ready LCD TV
Can't remove the stand base from my panasonic tx-32lxd70, i want to attach the television to a wall mount. thank you
2 Suggested Answers
  • 718 Answers
SOURCE: How do I remove the stand from a panasonic tv. model TX - 32LXD70
The stand is held on by four screws. Lay the tv face down on a flat surface. Cover the surface with a blanket first. Use a regular phillips screw driver. (If you have a users manual see page 7)
The screws are the set just above the stand on the back of the set. The stand will then slide out.
Posted on Feb 17, 2009
Screw sizes for the 4 screws for the wall mounting plate
They are usually fine thread machine bolts, a call to Panasonic customer service with the correct model number will be the quick way to find out what you need, most will be readily available at places like Home Depot or any major hardware store.
Dec 21, 2012 | Panasonic TX-32LXD70 32 in. HD-Ready LCD...
I need help removing the stand to my ASUS VH197D LED monitor so that i can attach my wall mount.
For the ASUS VH197D LED Monitor, turn it upside down so you are looking into the base of the stand. Squeeze the plastic tabs to unlock the base and pull. This will remove enough of the base to make it wall mounted and you can quickly attach the base if so desired. If you want to permanently remove the base and stand, remove the two screws that are now visible after the base is removed and pry out the plastic stand. This will break it off at the hidden screws. You will be left with a short metal stub that can be folded in.
Aug 01, 2011 | ASUS VH197D LCD TV
I Have a Panasonic Veria TH37PX600B flat screen TV with no manual,what I would like to do is take it off it's stand to wall mount it.But how? I've tried removing various screws and plates but it...
Unscrew the base screws attaching the base to the TV set, once the four screws have been removed, the TV can be seperated from the base as shown below. The circles are where the screws were on mine before I removed the base.
Jun 12, 2011 | Televison & Video
How do i remove the stand/base off a panasonic viera TX37LZD70 37" flat screen tv so I can wall mount it?
Place the TV on a flat bed preferably your mattress and look for the base mountings. The lock and base mount can be slid off and you can use a good wall mount that will support the weight to be fitted.
Please find the link below for help:
Wall mounting flat TV
Jan 07, 2011 | Panasonic Televison & Video
How to remove a stand
you have 4 screews to remove on back of your tv. 2 each side of connector panel
Apr 29, 2010 | Televison & Video
How do you remove the base inner bracket parts so that you can mount the TV on to a wall?
What make and model?
Most wall-mountable TVs will have threaded holes in the back for wall-mounting. Most of which you can bolt a bracket to then unscrew a few of the set-screws for the stand and slide the TV off of the stand.
Most TVs have 4 set screws for the stand located near the bottom middle of the TV where the stand inserts into the TV. The screws may be recessed fairly far into the back of the set and may require a long thin screwdriver.
Jan 01, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
Panasonic lx-32lxd70 lcd tv not working in cyprus?!?!?!
Under the channel setup menu there should be a way to change the input type of the channel. When you go to edit a channel look for this setting. If all your channels are grainy this is probably the solution also.
Jun 15, 2009 | Panasonic TX-32LXD70 32 in. HD-Ready LCD...
Jan 31, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
How do we mount our Panasonic Plasma tv on a tv stand?
Panasonic Plasma TVs come with a detachable base. For wall mounting it is not used, but you will need to find and attach it for use on a TV stand.
Nov 30, 2008 | Panasonic Televison & Video
Panasonic TX-32LXD70 32 in. HD-Ready LCD TV Logo
221 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
