Question about Microwave Ovens
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee Coffeemaker PSTX series Note : Unplugging the unit didn't help . Thanks
    Sergeant:
  • 192 Answers
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Posted on Mar 27, 2011
Testimonial: "Thank You Whispis2 ! I will surely clean the unit as described. Hopefully the light will turn off.Thanks again !! Dave"
  • Whispis2
    Whispis2 Mar 27, 2011
    Glad to help Dave. Also a black magic maker will make it go away :)
ALL LIGHTS ON MY KEURIG ARE BLINKING. I UNPLUGGED THE UNIT BUT WHEN I PLUGGED IT BACK IN, SAME PROBLEM. JUST BEFORE THE BLINKING STARTED, WATER WENT THROUGH THE BREW CYCLE BUT NO BUTTON WAS PRESSED NOR...
your coffee maker is damage.it has a faulty ic and transistor probably the whole little circuit is burned out .so my advise is to buy a new one if you dont want to get it repaired.good luck.
Sep 25, 2011 | Microwave Ovens
We have a Mr Coffee 10 cup thermal programmable coffee maker COF FTTX95-1 The clean light is blinking and I can't figure out what else to do. HELP!
When the clean light is blinking it is saying that the tubes are blocked up with mineral deposits. If you waited until the light in blinking then it is going to take some time for a vinegar clean to work.
Just put vinegar where you normally put the water, and let it perk about 1/3 of the water through, and then shut it off for 30 minutes. Then restart and let it perk another 1/3 through. Let set for 30 minutes. Then let it complete the cycle.
Take a look at the output vinegar, if there is a lot of chunks in it, strain it using a coffee filter and then reuse the same vinegar and do it again. Keep repeating until the light is out and the vinegar no longer get the chunks.
Jul 13, 2011 | Microwave Ovens
How do you clean a Mr Coffee Model Number COF JWX27?
Most folks run white vinegar through one cycle to clean a coffee pot ... follow by one regular water cycle (no coffee).
Feb 09, 2011 | Microwave Ovens
I have a Black 4 cup Mr Coffee with luminate lighting and time display programer so that I can have coffee brewed in the morning when I get up for work at 4:30am my problem is the coffee pot has started...
I had a black and decker coffee pot do same thing and it was brand new. here is how I fixed it.
make sure the filter seated down good. If you look at the top of the coffee pot it should open up the little valve of the coffee filter holder. also mine had a little water spout above the coffee filter that swings over the filter. make sure it is over the filter. I know my coffee pot is different, but I think the problem is the opening from filter to coffee pot is not open some how so the water is flooding over the filter and going out the sides onto counter
hope this helps
Jan 28, 2011 | Microwave Ovens
We made hot water for coffee this morning and when I went to made the second mug the lights work, the timer worked however the microwave and turn table did not work.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 09, 2010 | Kenmore 62463 Microwave Oven
New GE coffee maker #169209 (1300 watt) 12 cup digital. House lights flicker when in hot plate warming mode. Tried on 15 amp GFI circuit and then on dedicated 30 amp #10 wired circuit -- but same...
Hi, then it might be a factory fault problem, i will advise you to call in a electrician to come and witness it whenever you put it on so that he will be able to identify weather it is the microwave's fault or an electrical fault...
Mar 11, 2010 | Microwave Ovens
Microwave Ovens Logo
1,482 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
