The screen on my hp pavilion dv7 is making weird dots and at times on the white parts it goes pink kind of like it's inverted, and it does it at random times, what's the problem and how can i fix it?
  • 4,889 Answers
The first thing you should verify would be to check whether its a problem with the screen or the Graphics adapter. Connect the laptop to an external monitor and see if you still get the spots. Let me know what you found
Posted on Mar 27, 2011
Display issues
no photo posted, of bad screen, why? why make help blind?
the display LCD is bad.
or is the 2008 , solderballs Nvidia chip failure.
if the screen fails in BIOS (press f10 or ESC to enter setup
an fails under boot CD linux or any kind the screen is bad
test with big battery out, always. run on AC power only to test.
do the funny LINES change if you gently twist screen case?
i see reviews on this LT back to 2009
the vista review page on its support pages is stamped 2008
oops !
the BIOS screens are here. hit ESC then F10
dv7-1245dx
this is called hp setup, its BIOS.
if these screens look bad, bingo for bad screen LCD or the GPU.
http://h10032.www1.hp.com/ctg/Manual/c01662442
Jan 01, 2018 | HP Pavilion dv7-1245dx Notebook
Monitor hpvs17e stays on for second and goes blank
gldngrlz411, most likely problem with internal "switch-mode-power-supply" / CCFL inverter supply that provides 600 to 1000 volts ac to light the CCFL tubes that provide "white light" so you can see what is on the glass LCD panel!! Explore here first: http://www/lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ If vs17e does same when connected to a different "known good" pc, then you will need to make big decision!!! FIX or Trade in for new wide screen unit. 12fixlouie
Oct 08, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Have a hp dv7-1240us laptop. the screen will not
this sounds like the inverter in the screen. I would start by subbing the lcd screen. Then try and external monitor. video problems are difficult. don't get frustrated
Jun 17, 2010 | HP Pavilion dv7-1130us laptop
Hpvs17e white backround is pink
hucknannie, Power down the pc and monitor. Then disconnect and reconnect the VGA cable a few times to the rear of the pc. then turn system back on and re-boot. If your "PINK" screen still there, then you may need to have unit refurbished with new "cold-cathode-fluorescent-lamps" or have the internal "switch- mode-power supply/ccfl-inverter-supply" inspected and repaired. Yes, before you do anything, visit this web blog about HP monitors!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Read and make note that people are still visiting the blog even after 4 years!! Hope this response helps. Feel free to leave a comment and also rate this response on fixya. 12fixlouie
May 03, 2010 | HP Vs17 17" LCD Flat Panel Monitor
What does it mean when the screen goes all white or all black and how can that be fixed?
i droped my laptop on the floor and now it is white and nothing will come up on the screen what dose it mean
Jan 20, 2010 | HP Pavilion dv7-1245dx Notebook
How do i change lamp in hp dv2500
you cant u change the inverter board or the screen soz m8 inverter sits behind screen facia at bottom and has the pink and white wires attached to it and the black or blue wire from the other side the board can be bought of ebay for around 20 pounds
Oct 02, 2009 | HP Pavilion dv2500t Notebook
My screen light just turned off, but i can barely see my desktop and the taskbar. what happened?
sounds like either the ccfl tube died or your inverter died, a easy way to test this is to take a old working laptop, remove the screen bezel on both laptops and dissconnect the plug leading to the screen (usally a pink and white wire cable and connect the cable from the hp to the inverter on the old laptop, power on both laptops and if the hp screen lights up then the inverter on your hp is dead, this is not uncommon on laptops and if you ever get a new laptop try to get one with led backlight technology, if the inverter from the old laptop has the same plugs, put it into the hp, otherwise order a new on
Jun 14, 2009 | HP Pavilion dv7-1130us laptop
White turns to pink on acer laptop
The problem is CCFL light bulb in the screen. It is starting to die :( Can be replaced but that is not an easy task (easier is to replace screen as new bulb comes with it)
Jan 12, 2009 | Acer Aspire 5630 Notebook
Hp pavilion zd8000 inverter problem
you need to remove the front screen bezel (remove the screws and unsnap the cover)
then unplug the Pink and White Power Plug to the LCD Bulb..... Also Unplug the Display cable Plug from the other end of the inverter... Unscrew the inverter from the screen and remove/replace
Nov 17, 2008 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
294 people viewed this question
David Payne
David Payne
