Question about Nokia 1100
Charging problem!..no any response to a nokia charger.
N1100 type: RH-18
....no response to charger!..
  • Anonymous Aug 04, 2008
    The same will happen if i will try to another charger. Is these a hardware related problem? Will u help give me some possible solutions or troubleshooting techniques?
  • mohammad.dahmardeh Nov 28, 2016
    359579053174736
  • 304 Answers
The easiest way to test if the jack has a bad connection is to use a meter and an old nokia cord. Cut the plug off the end of the old nokia cord and strip back the 2 wires just long enough to touch them with the leads of the meter (1/4"). Set the meter to measure ohms and touch the 2 leads of the meter together and the meter should Zero out. Now touch the leads of the meter to the exposed leads of the plug. Have the test plug inserted in the phone of course. If you do not get a reading on the meter there is an open circuit. The phone will have to be disassembled and you must solder the jacks connectors back to the main circuit board. Many times these jacks dislocate from being droppedor hanking the plug out too rough or on an angle. I'm sure you already tested the battery and made sure the contacts were clean and free of obstructions. It only takes 1 small particle to keep the contacts from mateing properly. If non of this is the problem the main circuit card itself may be cracked. Visually inspect it. If any cracks are found use an exacto knife and scrape the coating off down to the copper traces themselves then carefully solder single strands of copper wire bridging the gaps in the cracked cicuit board. Then apply a layer of epoxy to the damaged section of the board to prevent further flexing and lenghtening of the crack in the board. If you have any question or need professional help feel free to ask me. [email protected] Hope this points you in the right direction.
George
Posted on Aug 04, 2008
  • George Kohler
    George Kohler Aug 31, 2008
    Did you get your phone to charge? Do you need more help?
    George
    Scholar:
  • 133 Answers
Change the charger pin it might be loose conatct
SOURCE:
Not charging
Have you try to use another similar charger to charge it to see if it will charge, if you have and yet, it did not charge, it means the charging port is bad.
The problem with your phone is that the charging port of your phone is bad and will need to be change in other for your phone to charge.
All you need do is change the charging port of your phone and you will see that your phone will charge.
Take care.
May 15, 2010 | Nokia 1100
Sonim xpi jcb toughphone,the phone won't switch on,but when the battery is removed and replaced the phone comes on.However none of the buttons pressed gets a response,can,t enter pin and it won,t turn...
Remove battery,attach and switch on charger,for about 10mins or until charge mode displays,should flash.Insert battery, donot disconnect charger,leave for 2 hours,disconnect charger ,phone should switch on.
Jan 24, 2010 | Sendo Sonim XP1 JCB phone extreme...
Tracfone will not charge
try dismantling the phone, keep it disassembled for sumtime... assemble again.. try recharging..
if it still doesnt work, have your charging port checked with an electronics mechanics..
Dec 11, 2009 | Nokia 1100
Nokia 1100 RH-18
take the phone and have the lcd replaced
Sep 08, 2008 | Nokia 1100
Charging problem!
George
Aug 04, 2008 | Nokia 1100
Can you share to me on how to repair of not charging in N1100
i think the charging port might have damaged or the charging IC is gone ...
just give a try with the other charger ...
if the charging port is gone then you replace the port with the new one ...
if the charging IC is gone you must get the new one and solder it ....
just have a check after opening the handset check whether is there any loose contact inside near the charging port ...
make sure of which type of problem you have and then taking the necessary steps ..
any doubts reply me
i am always here to assist you
thank you
bye ....
Apr 15, 2008 | Nokia 6600
Not charging N1100
any doubts reply me
thank you
bye ....
Apr 10, 2008 | Nokia 1100
Nokia 1100 Logo
133 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
