Question about Trek Fuel 70
Which bottom bracket will fit my trek fuel 70 please
    Guru:
  • 347 Answers
It's an English thread 68 shell. Beyond that depends on what cranks you have.
Posted on Mar 27, 2011
Polish finish, may not be original finish. Serial #I17121105 on underside of bottom bracket on non drive side, also on drive side #TBI -0405
This is from the
Trek Aluminum Series 420 The model is TBI 0405.
Nice bicycle, but I wish they had included a chain guard as standard.
They were gray paint with a red TREK logo on the drop tube in the original finish.
Jan 01, 2016 | Cycling
Trek 7300 effort pedaling
If the wheels spin free then I would look at the bottom bracket. All of the force you use for pedaling relies on the bearings in the bottom bracket being good. Are the pedals hard to turn by hand? Do the pedals themselves spin freely? If the wheels turn, this really only leaves these two rotating points as possible suspects.
Sep 17, 2014 | Trek 7300
Pedal assembly for a trek navigator 100
This bike had a square-taper bottom bracket. What happens with this type is that the bolts holding them on become slightly loose over time. The crank arm begins to wobble and the "wollows" out the inner hole on the crank arm such that a new one will have to be purchased. They are about $15.
The only parts envolved are the cranl arm and the both that holds it in place.
Jun 07, 2014 | Trek Navigator 100
Failed to install in my 2013 trek mtb bike. what tools needed for us be able to install or need washer. Also need to know the comlete package and parts included when you buy it
First, you're going to need to know what type of bottom bracket is on the frame of said bike. Hopefully it will be a standard threaded BB. It could be a BB90 or PF90. If there are no threads in the BB where your BB cups then your working with a press fit system. Let's start with what should come with your Truvativ Noir Crankset. You'll have the drive side arm & spindle, non-drive arm. 3x2.5mm spacers,1x wave washer. The Noir crank uses a 24mm diameter spindle, same as Shimano. SO, if your replacing a hollow tech II crank it should be a pretty standard affair. You'll need to know how wide your BB is on the bike frame to know how many 2.5mm spacers to use. The wave washer goes on the non-drive side against the bearing. Make sure to grease the BB before installation. If there are threads in the frame you'll be using outboard bearings. If it's a press fit system you'll be using cartridge bearings that press directly into the frame. Good Luck!
Sep 09, 2013 | Sram TruVativ 2010 Noir XC 3.3 Team...
Hi I keep getting a clicking noise when i get out of my saddle to apply more power on my Trek ex6 as any one else had the same problem
Sounds like the saddle undercarriage may be loose where it attaches to the seatpost. Either that, or you may be experiencing a problem lower down - actually at the bottom bracket. Is it a sound that repeats itself with approximately every rotation of the pedals? If there is play in the bottom bracket, this could be the source of your sound. Unfortunately, tightening the bottom bracket requires specific tools that normally only a bike shop will have.
Apr 26, 2011 | Trek Fuel EX 6
Need to no year make and model of trek bike bye serial number
Hi
Trek's serial numbers are on the underside of the bottom bracket. Flip the bike over and read the letters and numbers. It will look like this :
9000697000480
This would be a Trek 9000, made in June 1997 and number 480 off the production line.
Hope this makes sense and you can decipher your bike. Vote for me if this helps, thanks.
Jun 27, 2010 | Mountain Trek Fisher Bike Derailleur...
Where is the fuel filter located on a 2005 Lincoln LS? I drove my LS just before empty. Now I notice when I'm driving it's a little sluggish when trying to accelerate. I would like to change the fuel...
The fuel filter is behind the driver's side wheel. Here is the procedure....
  1. Before servicing the vehicle, please familiarize yourself with safety procedures.
  2. Relieve the fuel system pressure.
  3. Disconnect the negative battery cable.
  4. Remove the left front wheel well rear splash shield.
  5. Disconnect the fuel tube quick release fittings from both sides of the fuel filter.
  6. Remove the fuel filter bracket mounting bolt, fuel filter bracket, and the fuel filter.
To install:
  1. Install or connect the following:
    Fuel filter into the bracket making sure the flow direction is correct. Tighten the clamp to 15-25 inch lbs. (2-3 Nm). Fuel lines. Tighten the fittings to 22 ft. lbs. (30 Nm).
  2. Tighten the bracket bolts to 62 inch lbs. (7 Nm).
  3. Start the engine and check for leaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 18, 2010 | 2005 Lincoln LS
Where is the fuel filter located on my 2005 focus zx3
If you are thinking in a replacement, remember the position the fuel filter into the bracket. Ensure the fuel flow direction is properly aligned:
  1. Install and tighten the fuel pump bracket bolt.
  2. Lubricate the fuel tube fittings with clean engine oil. Align the fuel tube fittings and press together until a click is heard and then pull on the fittings to make sure they are fully engaged.
Fig. Location of fuel filter and lines.
Hope help (remember rated and comment this).
Mar 26, 2010 | 2005 Ford Focus
Were is the fuel Filter
LOCATION OF FILTER IS DRIVER SIDE FRAME RAIL ABOUT AT DRIVER DOOR HARD TO SEE BUT FALLOW FUEL LINE ITS THERE. hOPE THIS HELPS PLEASE RATE ME !! THANK YOU AND GOOD LUCK
TOOLS Are Simple and inexpensive local Parts Store like AutoZone will Have it
FUEL FILTER REPLACEMENT
TOOLS REQUIRED
J-46363 Fuel Line Release Tool
REMOVAL PROCEDURE
  1. Relieve the fuel system pressure. Refer to Fuel Pressure Relief Procedure.
  2. Raise and suitably support the vehicle. Refer to Vehicle Lifting.
  3. Remove the fuel composition sensor bracket nuts.Reposition the fuel composition sensor/bracket off to the side
    1. Using a flare nut wrench and backup wrench disconnect the fuel line fitting from the fuel filter.
    2. Pull the quick connect fitting back until the internal retainers hit the filter stop.
    3. Twist one end of J-46363 and insert it between the fitting and the filter.
    4. Twist the opposite end of J-46363 and insert it between the fitting and filter.
    5. Once J-46363 is inserted, ensure that J-46363 is parallel to the filter and fitting.
      1. While holding the filter, push the fitting towards the filter in order to disconnect the quick connect fitting.
      2. Remove the fitting from the filter.
      3. Remove J-46363 from the filter.
        1. Remove the fuel filter from the bracket.
        INSTALLATION PROCEDURE
      4. Install the NEW fuel filter to the bracket.While holding the filter, push the fitting towards the filter in order to connect the quick connect fitting
      5. Using a flare nut wrench and backup wrench connect the fuel line fitting to the fuel filter.
        1. Position the fuel composition sensor/bracket into place. NOTE: Refer to Fastener Notice in Service Precautions.
        2. Install the fuel composition sensor bracket nuts. Tighten the nuts to 17 N.m (13 lb ft) .
        3. Lower the vehicle.
Apr 07, 2009 | 2005 Chevrolet Avalanche
Trek Fuel 70 Logo
220 people viewed this question
Top Trek Cycling Experts
John Egan
John Egan
Andrew Crawshaw
Level 1 Expert
Are you a Trek Cycling Expert? Answer questions, earn points and help others
