Question about Sony Audio Players & Recorders
When I put 3 cds in the tray and close it, it goes through all three dics and shows no disc. WHY?
    Sergeant:
  • 347 Answers
Possible solutions:
-insert disc with labelside up
-clean cd/dvd blanc surface with a soft fabric
-use cleaning cd to clean lens
-change pick-up laser or eliminate electronical defect (service issue)
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Posted on Apr 07, 2011
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
My jvc player rejects my cds when I put them in. what do I do?
The mechanism that controls opening and closing of the tray is bad, that is why it keeps ejecting cds when inserted in.
Unplug the player and unscrew it open then plug it after opening the cover and try to insert a disc and see the how far the cd goes before ejecting, be sure not to touch any metal part in the player to avoid shock.
After trying to play a cd, you will notice where the tray ejects the cds from, it is located try to unplug the player and disassemble the mechanism, you will see either a worn out rubber or teeth on the mechanism, then replace them and reassemble it back together, after doing that, the player will be able to hold a cd.
Take care and good luck
Dec 02, 2010 | JVC KD-S640 CD Player
Cd player takes dics in then says no disc
Certain CD players have not been designed to play certain formats of pre recorded audio CDs. Therefore check in your users manual what format of CDs it can play. Play those . Also make sure that CD sits properly in the CD tray with label side up. If the problem persists then you have to call the technician.
Aug 21, 2010 | Technics Audio Players & Recorders
My dics dor to its changer wont close
open it up
the tray has somthing stuck init
Mar 02, 2010 | Sony CDP-C445 5-Disc CD Changer
My 360 will not read my disc even tho they are clean
The optical drive on the xbox wears over time. Call 1-800-4MYXBOX and get a repair scheduled.
Aug 03, 2009 | Microsoft Xbox 360 Console
Scratch dics play good dics go to open tray
put soap on the disc and put it under hot hot water thats how i got mi games to get back workin
Jan 24, 2009 | Microsoft Xbox 360 Console
Xbox360 disc reading error
u should find out if its chiped or not chiped 360s dont play live cds unless they r burned
Nov 06, 2008 | Microsoft Xbox 360 Console
Cannor Read DVDs
I have a similar issue to you, except that my dvd drive will only recognize a disc if I have booted up into windows with it in the tray...once in windows it will still think it has the first disc in no matter what disc i insert. If i boot up with no disc then it will never read it unless I follow the steps below.
A solution I found by pure frustration and trying all sorts of things is to eject the DVD tray and leave it opened, then right click on the dvd drive in 'my computer' and select the 'hardware' tab...then select the drive and click 'properties'.
A new window should open. Select 'volumes' and click 'populate'. Now close the window and insert the disc you wish to read, close the tray and repeat this process. Windows should now recognize the disc you inserted
Alot of trouble I know, but it works for me. Hope this helps.
Oct 22, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
Cd tray jammed
If you turn it off at the mains, wait a few seconds then turn it back on. As soon as you turn the power on, try and press the button for the tray to open. If this dont work, you will have to open up your system and remove this disc yourself. Good luck.
Sep 21, 2006 | Panasonic SC-PM313 Shelf System
54 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
