Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Seagate FreeAgent|Go getting really hot while transferring files from PC to the external hard disk. Do I need to replace it?
    Master:
  • 346 Answers
Hi -Do you mean hot as you can't keep your hand on the case or very warm as in toasty?
The hard drive being an electrical/mechanical device will get warmer the more files and the longer it takes to transfer them. If it's getting hot (not warm) after several hundred megabytes of data that would be unusual and maybe a problem. If it's getting very warm after gigabytes of file transfer that would be normal.
To ease your mind (or to verify your concerns) you can get a free copy of Seagates's own hard drive testing software HERE.
The unit does not have any sort of fan for cooling so just make sure any ventilation. holes or vents are clear.
Regards and thanks for using Fix Ya.
Mikeywaf
Posted on Mar 27, 2011
  • 56 Answers
No. External harddrive enclosures that don't have fans are generally going to get quite hot during extended use.
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software: http://www.icare-recovery.com/seagate-recovery/seagate-external-cannot-be-recognized.html
May 14, 2014 | Seagate FreeAgent Pro 500GB External USB...
How do I get everything from my external hard drive onto my Mac and then completely clear the ehd?
The problem you really face is a lack of space on the Mac. The movement of files from the Seagate to the Mac is easy. Plug in the drive and open it, then select the items you want to transfer from the Seagate and drag them to the location on the Mac where you want to store them. Job Done. When the files have all been transferred you just need to "Format" the external drive.
May 09, 2012 | Seagate FreeAgent 2TB GoFlex Desktop USB...
How to write to a seagate hard drive from a mac
you will need to reformat the seagate drive if it has not been formatted for mac.to do this.
connect your seagate drive to the mac.go to spotlight the magify glass at the top right corner and type in disk utility and select disk utility
in disk utility make sure you select the seagate hard drive and choose erase. at the middle of the screen look for format and choose mac os extended. click erase.
you should now be able to write files to your seagate drive.
also if you would like be able to transfer files to and from a mac or PC then you will need to format the drive as FAT.
Feb 15, 2012 | Seagate 1TB FreeAgent USB 2.0 External...
Can you use a Seagate 500GB FreeAgent GoFlex external Hard Drive with ready boost in windows 7?
Yes, but because it's a hard disk and has low transfer speeds it will actually slow down the pc instead of making it work faster. Ready boost is designed to be used only with memory sticks of the latest generation.
Jun 01, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
How to transfer files to the seagate external drive
attach the seagate open windows explorer click on my computer if you can see this seagate free agent select the files you want to transfer right click copy navigate to the seagate select it then right click paste or select the files right click send to seagate
hope this helps
Nov 02, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I'm trying to sync my files from my old computer
no you can what you have to use is files and setting transfer wizard in windows xp you can start the Files and Settings Transfer Wizard by clicking Start on the computer running Windows XP, pointing to All Programs, Accessories, System Tools, and then clickingFiles and Settings Transfer Wizard. (If both computers are running XP, you can start with either one.)
just select "i want create wizard disk in following drive " and select you external disk drive tha will do the trick...
Apr 11, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
How do I transfer data from my hard drive to added external drive
you can this many different ways. The most straightforward is to go to the drive and select "folder and file options" in the view menu and selct "show hidden files", that way when you copy and paste you will get every single file. The other way is to use a program such as Acronis Tru Image and use the clone option. I am assuming that you want an image of your C:\ drive.
Sep 14, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Free Agent Drive cannot be modified? Worked before...
Ok,
Sounds like it's one of three things then
Disk trouble from unplugging the usb while the unit is still "running" and not yet finalized. Running CHKDSK /? /F in the run box where ? = extrenal drives lettrer. Then restart the computer(done from windows PC with drive attached)
Shell trouble I have already advised a dozen or so people this week that if CHKDSK doesn't work, replace the shell with a new one and see if the hard drive works in the new shell.
Failed harddrive, of course this is always an option. If neither of the above suggestions works then it's possible the hdd has failed and you may need to send it to a pro if you have any files on it that need retreiving.
Hope this helps FixYa, if you need additional help just reply to this by adding a comment.
Chris
May 22, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Freeagent external hard drive doesn't show up on My Computer
Your Mac would have formatted the Seagate drive as HFS+ (journaled) format. If you have access to a Mac, copy your data off the Seagate to any Mac, then use your PC to reformat the Seagate drive in FAT32 format. Macs recognize FAT32 format, and can store data in it, but can't create the format. The Mac holding your data can store it on the Seagate in the FAT32 format, and you can then copy the files to your PC. Hope this helps.
Feb 25, 2009 | Seagate Free Agent Go Small 12 GB USB...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
89 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
