Question about Grilling
Have a bbq grill with a XINDA ignitor that fires on all three burners at the same time. Replaced the battery and can hear a faint "squeal" when I press the button, but no spark.
    Brigadier General:
  • 4,736 Answers
The battery may be facing the wrong position. Generally, the Positive (+) end should be facing you when you insert it into the holder. If you did that correctly, check the spark ignitors at each burner. If they are covered with grease they will not fire.
Posted on Mar 27, 2011
Why wont the left and right burners lite using the electric ignitor?
Are the igniters for those burners sparking?
Aug 29, 2014 | Grilling
I have a Whirlpool Accubake 465 oven, model number SF368LEPB. When I select "Bake" and then press "Start", there is a sound of the flow of gas and the ignitor attempts to spark. I can...
Hello Kevin,
That sounds to me like a cracked bake igniter. One way to tell if its the igniter and but a problem with the burner is use bbq lighter and try to light the bake burner, If it does light using the bbq lighter it will be the igniter. Also ya could remove the igniter from the bake burner and see if their is a visible crack in it.
If it does turn out the igniter needs to be replaced,the part number is 9758079 thepart can be picked up from yoor local appliance parts store or online at;
Aug 19, 2011 | Kitchen Ranges
Ignitor keeps clicking on burner
A creda microwave oven doesn't have an ignitor or burner, so I assume you are talking about either a BBQ grill or gas range.
A suggestion: Clean the ignitor tip with a CLEAN and DRY green scouring pad; check that you have gas coming out of the burner.
If you have gas at the burner and the ignitor is clicking (sparking) then it is usually an ignitor alignment problem where the ignitor got bumped out of position.
Jun 06, 2011 | Creda Microwave Ovens
Where do you hook up the sideburner ignitor wire to on the char-coil bbq model 463721111
The side burner ignitor wire connects to the spare lug on the main ignitior module. That one module, controls all the spark ignitors at each main burner and the side burner. When you press the button all ignitors spark at one time. I know it sounds stupid, but that's the way Charbroil's R & D designed it. I guess it saves money.
Hope this helped you to make the final hookup. Happy Grilling!!
May 01, 2011 | Char-Broil CharBroil 4637318 Grill
Cant get bbq to light
Make sure the battery is in correctly, then check the wires from the ingniter to the electrodes, if they are connected and ok, then check to see if there is a spark from the tip of the electrode to the collector box or burner. If there is no spark, then it could be the igniter, electrode or wire. Hard to tell with out trouble shooting.
Jul 06, 2010 | Grilling
Our igniter doesn't work.
clean the elctordes on the burners make sure the battery conections are clean corrosion free
Jun 21, 2010 | Weber Genesis E-310 Gas Grill
Ignitor on gas BBQ no longer works. Replaced battery and cleaned out chamber (light rust). I've tried to remove the ingnition housing, but the entire front panel of the BBQ needs to be removed. Suggestions...
Check to see if the probe where it sparks to the burner inside the grill is clean and not shorted by grease or other gunk and the burner itself in this area is not too heavily rusted or corroded. If not, short of disassembling the whole grill and replacing the spark module, spend $2-3 and buy one of those pistol type grill lighters. The ignition systems on BBQ grills rarely seem to last long.
Feb 24, 2010 | Grilling
Grilling Logo
104 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
