I have been using my desktop for sometime now with no problems. I powered it up one day and got no signal o the monitor, no beeps nor anything like that. The processor fan spins and keys board lights up initial then goes out. I am running a MSI MS-7309 K9N65Gm-V motherboard with a AMD sempron processor. To date I have tried resetting the BIOS by switching around the jumper, I have removed the CMOS battery, I have removed all PCI components and tried starting the pc but same problem. I even tried bootng the PC without any memory in, I did not even get the warning beep. I need your help urgently. Pleae help.
  • 34 Answers
Since you have tried everything else, i persure the problem is with the processor. It might not be getting the require power. If you have installed any hardware recently, try removing it and starting thr pc.
Posted on Mar 27, 2011
Monitor does not come on
Hi Scott,
please check the removing the vga cable of monitor and turn its power on and display must show no signal error itself you can see it very clear text on it.
if your monitor good check the cable and plug it back to pc.then turn on the pc.if computer starts you can hear the HDD sound and please note the Beep sounds comes up or not ,if continues beep comes up problem can be with your pc memory modules or vga card ,sometimes mother board,
clean the ram card using smooth brush and mother board also.
unplug the power supply jack and re insert it .
remove the vga card also and do the same.
first all check the power unit fan is turning on when you press the power button too...
please let us know the results or come with more details.
regards.
nuwan
Jan 08, 2014 | Dell Dimension 3000 PC Desktop
No signal to monitor from my pc
TRY WITH A OTHER PSU.CAN BE THE PROBLEM.
Jul 25, 2013 | Acer Aspire M3641 Dual Core E2200 PC...
The computer was connected to the monitor when i walked out and when i returned it was unplugged. when i tried to connect it again the monitor reads no signal and makes a series of beeps. first beep isnt...
The beep is actually called a beep code and it is telling you where the problem is. IF that is one short and one long beep than the problem is memory. You may have to just reseat you memory or replace one of the modules.
This is a link to a page that goes over all the beep codes used on HP's. You should have a look and a listen and you will soon know where your problem lies. If it is bad ram then it is annoying but also a good excuse to upgrade the amount of ram as it is fairly cheap these days. Extra ram will make a big difference to how fast your hp runs. It is the second best thing you can do to improve your speed, the first is a newer type video card with over 1gb of vram.
The cost of say 4gb of ram can be under $40 , sometimes quite a bit less. And it is something you can replace at home. If you buy the ram from a shop they can be usually convinced/bribed to put in in for you.
Sep 17, 2011 | HP Computers & Internet
Diagnostic beeps
try google on motherboard error beeps good article and see if you can match up the beep pattern. it says 2 short one long for video problem. good luck
May 23, 2010 | E-Machines eMachines Desktop PC
We are getting a No Signal on our monitor,
it should be motherboard problem.
try to check it nearby service centers
are you able to hear any beep sounds
pp
Nov 21, 2009 | Acer Aspire L100 PC Desktop
Lights 3 &4 stay on.
Computer beeping at you is usually a problem with the video card or memory. Try re-seating both and see if you still have the same problem. If you do, individually remove each component and power on to test if the beeps persist.
Jan 06, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
No signal on monitor
Check that the power is plugged into the back of the monitor and also to the power point, make sure power point is ON. If anything pull plugs out and re-connect both just to make sure.
Make sure monitor cable is also plugged into the back of the computer.
Turn computer on and make sure it beeps and looks like it has hard disk activity to show it is booting into windows. If it doesn't beep or show activity it could be your PC having an issue else it is possibly your monitor.
To double check try your monitor on another PC and try another monitor on your PC to see which has failed.
Jan 25, 2008 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
