Question about ASUS P5GC-MX/1333 Motherboard
No output to monitor. Monitor tested with good PC and is OK. No alarm beep code
  • ASUS Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
one bad lead will end with a computer error
hope this will help
Posted on Mar 27, 2011
No screen image
Test with known good monitor. Consult a nerd at this point. They can diagnose things quickly. Its usually more obvious then you think.
If still no image, replace video card. You can buy a replacement online. Most likely you have something else going on. For example, You usually hear beeps from a PC if it is doesn't pass post testing during startup. This could also cause no video output. You would need to check PC memory and power supply as those two can cause many performance problems.
Oct 10, 2013 | Westinghouse Electric L1916HW 19" Monitor
No signal on monitor, vga tested and ok
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Mar 11, 2012 | Computers & Internet
When I start my computer up my Philips Monitor
Good day sir/maam, hi, the problem may not be your monitor but your PC, they produce the same symptoms if your PC has no video to display. does your monitor led/lamp lights up as turn on your computer? If you want to test your monitor, go bring it to a friend who has a computer, test it there. if it works, your pc has a problem, so try the following first.
  1. Open you PC side cover, locate the memory module, remove the momory by releasing the side clamps. clean the contacts using an eraser (pencil) then put it back, you will clicks as you put it back on, test again. Do it several times if the first try fails.
  2. Check your Power supply, does it gives out hot air exhaust?
  3. Did you hear one beep, (good) or several beeps(bad).
  4. As you power on the pc check your keyboard light, first set of lights (Num lock+Caps Lock+ Scroll lock) then second set of light (Numlock only). At this point your pc is good.
Hope this helps, let me know your progress.
Oct 08, 2009 | Computers & Internet
Monitor has solid green LED, but no display
you have to test the processor functions. therefore use post diagnostic card via PCI or PCIX or USB for the check hexa codes, if you show codes the processor ,ay be ok, also have to check the code function by card manual. and replace the unit that failure.
Mar 12, 2017 | AOC LM-800 18" LCD Panel Monitor
Dell Vostro 1510 Power but no boot
Have you plugged in an external monitor to see if there is any output on the screen? You could have a LCD problem or the motherboard is shot. I would also remove the RAM from the machine to see if it gives you any beep codes. This will tell you if your computer is going through POST. If your computer gives you beep codes then theres a good chance your motherboard is still ok.
Jul 16, 2009 | Dell Vostro 1510 Laptop
PC does not boot, no beep, no monitor output but fans and lights work.
Usually if everything inside the case is working (from best you can tell) and the monitor is not coming on it's one of two things.
1.) The video card is bad, if you are using on-board video this isn't too highly likely. To test just replace the video card if possible with any other compatible video card.
2.) The CPU has gone bad, in general I find that this is the most common scenario. Obviously to test you would need to replace the CPU.
May 23, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Using Non-Dell monitor on Dell system
Have you tried the monitor on another PC, have you checked the cables, or tried another monitor cable, AND Look inside both place the monitor plug goes and look for BENT PINS or broken PINS, not every hole may have a corresponding pin but thats OK, look for bent or broken pins, If those soutions dont work repost error code beeps, and I or someone will help more.
Thanks for the fixya rating, everyone helps me..have a blessed day
Apr 08, 2009 | Computers & Internet
Monitor blackscreen
If you have access to an external monitor then conncet that to the external monitor port. Holding the function key and F7 or F8 should switch the computer to the external monitor. If this is OK then I'd say your mercury lamp has burned out. If no access email back the beep code. You'll have to listen carefully. In either case this computer will need to be repaired by a reputable computer repair person.
Good Luck
Mar 22, 2009 | HP Pavilion dv9000z Notebook
Alarm for failed monitor when I turn on the pc
PC is not producing and video signal - can you test it with another monitor or test monitor on another PC or notebook.
Is graphics card in PC loose?
Aug 09, 2008 | E-Machines eMachines Desktop PC
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
ASUS P5GC-MX/1333 Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
