Question about Casio DB360G-9A 30 Pages Telememo Watch
Cant remember how to set the digitl clock - Casio DB360G-9A 30 Pages Telememo Watch
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Try opening this link below by copying and pasting it into a new address bar in a new window;
http://support.casio.com/manuallist.php?rgn=1&cid=002
A new window should open with;
Timepieces
Click on;
  • Watch Manual Archives
A new window will open asking for the 3 or 4 digit Module Number (which is located on the back of the watch)
Module No. Search
Type the 3 or 4 digit number in the box then click search;
When the next window opens click on the highlighted underlined Module Number and this should take you to a new window with the manual you need.
Posted on Apr 09, 2011
I cant fix the analog of my watch pasnew model PLG_1002AD GRADE A QC 6
Ignore the instructions I found its not as easy as they say first you need to sync the digital and analog to do this press all four buttons at once and hold for 3 secs tho sets the digital clock to 12 Now press mode till you see h-s hold reset till h-s flashes hold the start button in the analog will start moving its slow so be patient set analogue to 12 exactly ignore the minutes that have passed press preset the minute hand will automatically adjust once done press mode go to the main watch screen hold preset use mode to select hours minutes date year month etc and start to change the values keep it on 12 not 24 hour clock set the clock and press preset the analog will now automatically adjust to the time once done you can change to 24 hr mode if you wish
Mar 06, 2015 | Watches
Danbury clock 'things remembered'. How do I access the battery? I cannot figure out how to find the battery. The battery is dead after two years and I need to replace it. It is not obvious how to...
The things remembered clock is just tension fit in the housing. Easiest way to get it out is to get a plastic suction cup. Press the suction cup onto the face of the clock and pull and jiggle till the clock comes out. This way you wont gouge up the wood trying to pry the clock out with a screwdriver. It takes an N cell battery: https://en.wikipedia.org/wiki/N_battery
Jan 31, 2014 | Watches
The clock is just tension fit in the housing. Easiest way to get it out is to get a plastic suction cup. Press the suction cup onto the face of the clock and pull and jiggle till the clock comes out. This way you wont gouge up the wood trying to pry the clock out with a screwdriver. It takes an N cell battery: https://en.wikipedia.org/wiki/N_battery
The digital will not sync with the analog hands on my g shock
same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
Dec 30, 2012 | Watches
Minute hand on Braun AB1A has curved up stopping second hand
The whole front square face of the clock has 4 little nails which are located in the middle of each side (inside and next to the edge of the joint), so you have to carefully insert a screwdriver and lever the front out. After this you have to remove the hands (remember to set the clock and alarm hand to 12:00 before taking those away). The face will be loose, and you'll have access to the mechanism. Clean the alarm contact (look for a double silver metal arm that touches an small bronze stick. Alarm button can be release by gently lever the little nail that shows in the center when button is up at clock's backside.
Cheers from Argentina
Jul 04, 2012 | Braun Ab1a Alarm Clock - Black By Rams &...
Lost manual and can't remember how to set analog
Hi,Here it is...to download the soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Jun 28, 2011 | Casio Watches
I have a Westclox, Calander Model 70026. I have set the clock several times to the correct time,(with the time zone at the proper setting) but, after a day or so, the hour reading, reverts back...
It's most likely because of Daylight Saving Time. Your clock receives a signal through the air once a day from the actual atomic clock, much like a cell phone receives the time from your cell phone service provider, and it automatically resets itself to the exact time each time it receives this signal. Remember that the middle of the year (the second Sunday in March until the first Sunday in November in the US) is Daylight Saving Time for much of the United States. The clock has an option that allows you to set whether you are observing Daylight Saving Time or not. If this is set to "off", the time will be one hour behind until Daylight Saving Time ends (November 7th). Make sure this is set properly, and your problem will be solved.
Sep 27, 2010 | Watches
Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
Mar 08, 2009 | Watches
Can't set the time or adjust the ******** crystal Starck PH-1100
Take a VERY close look at yor watch and you should notice a few tiny buttons. One of them should correspond to MODE, another to SET and so on- depends on how many your watch has.
Use a pin or a needle to push them and find out the settings procedure.
If you cant find buttons on the case sides, examine case back. They can be hidden between the lugs, so, the strap should be taken off.
Remember- there are no watches in existance without adjustment features. Even atomic clock needs to be adjusted after a few million years of work:))
Good luck.
Arthur
Dec 16, 2008 | Fossil Watches
Casio cmbi watch with didgital timer and normal clock on
I lost my instruction and need to set my watch to the correct time. It is a casio illuminater AW-80
Oct 26, 2008 | Casio AW80-7AV Wrist Watch
Casio DB360G-9A 30 Pages Telememo Watch Logo
81 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
