Question about Amana Dryers
Amana Dryer model #NED5240TQ0 has no heat and the timer doesn't move. Does this this smean I have to replace the timer?
TheMobilian
  • 8220 Answers
SOURCE: older amana electric dryer model #le8457w, wont heat up
You probably have a bad heating element. This is just about the easiest dryer to repair ever. Take the screws off the base and pull the front off. The heater is on the left on bottom and has all the fuses mounted on it. 2 screws hold the whole thing on. get it out and give it a look over for a bad coil. Not sure if it is bad? Take it to the appliance parts store and let them guys confirm if it has a problem. they will be glad to do so because they hate to have to give refunds on electrical stuff and they know the cust will get bent outta shape. Trust me. How do I know? Because my friend I used to own and operate an appliance parts store.
Posted on Apr 10, 2009
canbruce75
  • 1776 Answers
SOURCE: My Amana dryer model number LE7153WM does not heating
The thermal fuse and the heating element would be the likely suspects. Both can be checked with an ohm meter. If there is no continuity, it indicates a defective component. Neither is repairable and if either component is bad, it will have to be replaced. Hope this helped. Good luck.
Posted on Jul 16, 2009
localwonder
  • 6784 Answers
SOURCE: whirpool amana dryer runs but no heat
HI, the timer motor is malfunctioning. this can affect the way you dryer heats in this case. I would advise to check the thermal fuse before replacing the timer. it is located on the blower house or, on the vent duct. in will show no continuity if defective. replace the timer if the thermal fuse is showing good continuity when measure with a meter.
Posted on Jul 25, 2009
  • 2699 Answers
SOURCE: Amana Gas CLothes Dryer Mod#NDG7800AWW dryer will
if your clothes are damp because you say it does dry some what then it sounds like it could be the gas coils,the coils will work for awhile but then they fail and the timer will not move if there is no heat on the more or less
Posted on Oct 30, 2009
  • 1214 Answers
SOURCE: replace electric heat element in Amana dryer
You can find an exploded view of the dryer on searspartsdirect.com. Looks like you access from the rear service panel.
Posted on Dec 11, 2009
My dryer timer is not moving and the isn't heating up
From the info. you gave it sounds like the timer motor is defective.
If the timer motor is not moving it stops the heating element from activating.
Oct 03, 2014 | Amana Dryers
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Dryer tumbler for a short time then shuts off,will not run a full cycle like it stuck
see this causes and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and needs replacing. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace the Heating Element.
Sep 27, 2012 | Amana ALG331RAW Gas Dryer
Amana electric dryer timer doesn't advance during
If this is one of the electronic models: Clean the sensor strips located inside the drying area. As wet clothes rub against these the control monitors the resistance changes and knows the clothes are still wet therefore it continues to operate. When buildup from dryer sheets and fab softener get on them strips a barrier is formed that repels dampness. Therefore the control does not know the clothes are wet and goes to the end thinking all is Kosher. Clean them sensor strips with Windex and party on!
Jun 18, 2012 | Dryers
Hi, i have an amana dryer that the timer and the heating element quit at the same time.could the heating problem be coming from the bad timer?
Hi and welcome to FixYa, I am Kelly
I think you have a failed cycle thermostat. The cycle thermostat provides power to the timer to advance the clock and the heating element. If the thermostat has failed it will not heat or advance the timer. Usually when just one side of the thermostat fails the timer will advance but the dryer will run and not shut off. There may a wiring problem on the C terminal of the cycle thermostat. (Burned / got hot / wire itself failed from heat )
If you can provide a model number I can probably locate he replacement parts information for you and possibly a wiring diagram.
Thanks for choosing FixYa,
Kelly
Jan 30, 2011 | Amana Dryers
My Amana electric dryer sometimes will not heat and timer will not move. The dryer will just run and run. If I unplug the dryer for a few hours it will work again, but the problem will return.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The timer has gone bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Aug 31, 2010 | Amana Dryers
Timer making noise, but not moving
If timer motor is in operation but the dial not forwarding, yes the timer is faulty. plastic gears in the timer eventually ware..
Jun 09, 2010 | Amana LEA11 Dryer
Whirpool amana dryer runs but no heat. on timed try timer doesnt move either.
Jul 24, 2009 | Whirlpool LER4634J Electric Dryer
Amana gas dryer ALG331RAW timer does not work and no heat
HI, the timer is defective. the heating process can be affected if the timer isn't functioning correctly. replace this failed timer asap. this will fix the issue.
Jun 19, 2009 | Amana ALG331RAW Gas Dryer
Dryers Logo
71 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
