Question about Whirlpool 25.2 cu. ft. Side-by-Side Refrigerator ED25PQXF
The unit won't get cold. It has worked well for several years but jsut quit working. It did not have frost in the freezer.
  • 822 Answers
Mite need regassing...................
cheers
Posted on Mar 27, 2011
Royal dometic. not sure year or model. started cooling several days after power connected..auto defrost kicked in second time there was frost buildup and now neither fridge or freezer will get cold..have...
When you feel cooling unit from outside behind cover and unit is on for a couple of hours min, does it feel warm, hot? describe any other things you notice please.
Apr 09, 2013 | Refrigerators
Freezer works but refigerator won't get cold
IF YOU HAVE ALOT OF FROST ON THE BACK PANEL OF THE FREEZER IT IS A DEFROST T-STAT THAT CAN BE BAD IF THERE IS NO FROST FELL UP IN THE LEFT UPPER CORN OF THE FRIG SIDE SEE IF YOU CAN FILL THE AIR COMING OUT OF IT
Nov 01, 2012 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
Freezer is not working. Ice maker is working. Started noticing the past 2 weeks that ice cream is melting. Refrigerator is working but not keeping things really cold. The unit is only 3 years old.
ice mker will soon quit as when ice cream is soft the tempt is rising . look for frost build up in back wall of freezer . if so the heaters have failed ( very common ) . they will have to be replaced . there is a new style that replaces mose G E heaters . and they are much better .. mm
Jul 29, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a frost free upright ge freezer that quit working. No cold at all. It is less that 2 years old. Where did the quality go in GE? I have a GE microwave and it broke within the first year. Is it me or...
when the compressor is working and dont produce cold maybe the tube is leaking, causing the freon gas to scape. you need to reprocess your freezer to clean up and to find leaking tube to fix it. you nee a white line technician to fix your problem.
Jun 16, 2010 | GE 203 cu. ft. General Electric Upright...
Fridge works freezer isnt getting cold enough to freeze
check to see if you have frost on the back panel of the freezer if so then defrost the unit and if your able to find the failure of the defrst heater or defrst thermostat,or the defrost thmer more than likely its the mother board since its a general electric frig but if you manually defrost until a repair tect can come then it will run normal until it frost up again but before you call the tech out make sure you have the frost on the back panel otherwise he'll make several trip trying to solve the problem with the frig unless its the defrst heater
Sep 08, 2009 | Amana Refrigerators
Fridge not getting cold enough
The cold from the freezer is piped up to the refrigerator and if that tube gets clogged with frost or ice it will not be able to blow to the cold air into the refrigerator area. I took everything out, unpluged the unit for about 6 hours, till all the frost from the freezer was gone, wiped up all moisture and turn it back on. It worked!
Aug 03, 2009 | Amana ABB1927DE Bottom Freezer...
Kenmore fridge not working, ice cubes wet, freezer frosting up
You may need a new defrost module. The coils ice up when it is not working. This makes the fridge and freezer only a little cold. About 150 to 250 bucks to fix if you call a service person. Under a hundred for the part.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE Monogram freezer side working but refrigerator side is not.
Did you clean the condenser?  Is the unit FULLY defrosted?   Defrost fully!!!!!!
Did he check the amount of gas in the unit?  If your unit has low gas...it is in need of more.  R12 is expensive.
Check gas level:  Shut unit for at least one hour.  View compressor.  Several pipes...we're looking at the largest.  Start the unit.  This pipe will begin to frost.  If it does not clear to dry, ice or wet...stays frosted...it is low.  Get the repair guy back ... but ask how much he'll charge first.
Dec 12, 2008 | Refrigerators
Dandy 8.8 fridge not working but freezer does
freezer works but fridge wont cool
Aug 29, 2008 | Freezers
Freezer not freezing
How old is the unit? Does it seem to have air circulating in freezer? Is the temp in the refrigerator side cold enough? One common thing is for the defrost heater to stop working which causes the freezer to ice up and stop circulating air. If you can put all items in a cooler and unplug the unit for several hours leaving the freezer door open. Plug it back in and see if it starts blowing frost again. That would indicate a bad defrost system. It can be several things but most common are the heating elements. If the defrost timer stops working you get the same results. If this does not produce positive results then it could be a weak compressor or gas leak. Best have a repairman check it or get a new one if it is the compressor.
Jan 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
