SOURCE: Gainsborough Shower Running Cold
It sounds like you have a faulty thermostat or broken heater element.
SOURCE: hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
SOURCE: No water coming out of shower
First you should check the screens st the ends of the hose to be sure they are not clogged. The shower head as well. Otherwise it could be the water control valve, solenoid or thermal cut off.
http://www.theshowerdoctor.com/shower-spares/gainsborough/energy-2000x.html
SOURCE: Cold water only from single-arm shower faucet in master bathroom
Yes - This is an easy (though not widely known) diy fix! Remove the cover of the faucet handle (may pop off if crystal type or use a screwdriver to remove the screws) inside there is a scald guard safety mechanism - using a flathead screwdriver, turn the guard some the left. There should be a guide so that you do not turn the water up too hot. If there is not, you may need to consult a plumber or supplier in order to adjust the hot to a moderate temperature.
Hope this helps! ;)
SOURCE: Remove and replace a hand held shower head hose in whirl pool
Hey Rick........the connectors are just large nuts at each end of the hose. If you remove one of the connectors there should be a a ring slipped around a grooved part of the hose with a plate. If you remove the clip the plate should slide off enabling you to remove the hose. Let me know if you need any more help.
Thx
Ken
