Question about Pentax Optio S Digital Camera
Pentax Optio A10
I have a problem with The Pentax Optio, when I switch on the camera, the green light show but the lens does not extend and there's a continuous clicking noise which sounds like a small motor turning. How can I solve this problem?
  • bewolf Sep 07, 2008
    I went to turn on my camera and it worked right away, I viewed photos only for a few seconds before turning it off to save the battery.  When I turned my camera on, moments later, to start taking photos it wouldn't start.  The green light would turn on and flash several times before turning off.  The lens didn't extend.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Aug 30, 2012
simplemitch
  • 752 Answers
SOURCE: Pentax Optio 50 Digital Camera Lens Error
Not really, it sounds like the lens has been bumped while it was extended. Unfortunately, the "buzz" you hear is the gears stripping one another. The only fix is to have the lens assembly replaced, which usually costs upwards of $200. I see this problem at least 3 times a week in my shop.
Posted on Oct 27, 2007
SOURCE: Pentax Optio 555 - Fozen with the lens stuck-out
happened to me a couple times & after recharging battery, still stuck, so manually pushed it in when motor was running trying to close it.
Posted on Apr 06, 2008
SOURCE: Pentax Optio A10 lcd replacement
I bought my parts from Pentax Imaging Co. for 59.73 + tax + shipping: Part Number 76650-0500 Tel 1 800 877 0155. I am willing to sell this lcd for 55+ ~ ($7 shipping in USA only) because I now have other problems with the camera. LCD is like new condition. (contact: magee.silas@gmail.com)
I pulled on the power wires to disconnect the LCD power supply and broke the black one at the connector. I was able to pull the old wire out of the connector and press the remaining section of wire into the connector securely and fix the mistake (use tweasers to prevent this).
As for the LCD information connector strip: Take all of the tape covering this connector off before proceeding because then you will be able to see and use the connector "gate". the gate pivots upward to allows you to place the connector strip in place then you can gently push the gate down to lock the connector strip in place. I tried sliding the connector in and it did not work. Instead it gave me a red screen. I did install my LCD, turned the camera on and it worked, Then...
After dissasembling the camera more that nessesary to be able to insert the menu board's connector strip back into place the camera failed to turn on. I have not found and dissconnected wires and suspect Electrical Shock Discharge for the failure.
If you try this procedure wear a grounding ******** your wrist, or take off the minimum nessessary to preform the work( backplate, sideplate near lense only). You do not need to remove the menu display panel to connect the lcd panel information strip, just remove the tape covering the connector.
Posted on Apr 20, 2008
  • 22 Answers
SOURCE: Pentax Optio 50L Lens Error
I have the same problem, which is not one but only a symptom : this problem occurs if the camera doesn't appreciate the batteries you feed it with ! use another brand, another model, or if rechargeable use another set of fully charged batteries...
I consider this problem coming from faulty design of the camera which consumes batteries very fast AND is very sensitive to the battery type you're using :-(
Posted on Apr 18, 2009
tommya300
  • 724 Answers
SOURCE: Pentax Optio M20 in Green Mode switches off after turning on
battery
Posted on Jul 27, 2009
Lens won't stay out on Pentax Optio A10
This happen after a hard hit on the floor
Jul 24, 2014 | Pentax Optio A10 Digital Camera
Pentax Optio a10 turns off automatically after I turn it on
It sounds like you may have a bad lens assembly. If it is sticking, it will buzz. If it fails to open all the way, it will turn itself back off. This is what it sounds like you are saying. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Contact me at: mrfixitmark at comcast dot net
Jul 19, 2009 | Pentax Optio T10 Digital Camera
Pentax camera optio a10 won't retract
It sounds like you may have a bad lens assembly, or a bad main board. If it is sticking, it will buzz. If it fails to open or close all the way, it will turn itself back off. This is what it sounds like you are saying. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Jun 19, 2009 | Pentax Optio A30 Digital Camera
Pentax Optio A10 Camera Lens won't retract
It sounds like you may have a bad lens assembly. If it is sticking open or closed, it will usually make a buzzing noise. If it fails to open or close all the way, it will turn itself back off. This is what it sounds like you are saying. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Mar 27, 2009 | Pentax Optio A30 Digital Camera
Power keeps shutting down.
It sounds like you may have a bad lens assembly, but you did not mention if it seems to be fully extending or not. If it is sticking, it will usually buzz. If it fails to open all the way, it will turn itself back off. This sounds like what may be happening. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Oct 05, 2008 | Pentax Optio A10 Digital Camera
Dude 1st of all did you charge your batterires. if yes and still not working try changing your battery pack and try to turn it on again. hope im not too late.
Jun 15, 2008 | Pentax Optio A30 Digital Camera
Pentax optio m20 .. on-off immdly
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 25, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio M20: won't work.
ok have same problem press the power button and and the play> button at the same time. your screen will come on but not lens. then hold the play button down untill lens come out. this will work for you , you may have to do it a couple of times but it will work
Jan 20, 2008 | Pentax Optio M20 Digital Camera
Dead?
Have exactly the same prob, my camera worked for 3 years without any probs, except that the alkaline batteries didn't have a long life...tried rechargeable batteries as well, but since three weeks ago it simply says, "batteries depleted", nothing works, tried everything...sending it to Pentax after the warranty is over is far more expensive than buying a new cam...really sorry for that, but don't think I gonna buy a new Pentax again...
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Pentax Optio S Digital Camera Logo
50 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
