Question about KitchenAid Washing Machines
I have a Quiet Scrub ex-lg/heavy duty. The tub isn't straight. It tips to the front/left. Is that somethin I can fix or do I have to call a repair man. I live an 1 1/2 hours from nearest repair place and I don't really have to money to pay what they will charge to come to my house. Everything else works great on it except it tilts. I stopped doing full loads to see iif that helps and it still tips. Thank you for any help you can give. Denise P
    Problem Solver:
  • 4 Answers
Try lifting the basket and moveing it around alittle they sit on a triangle it may have slipped off
Posted on Mar 27, 2011
My LG front-load washing machine does not completely wet the clothes in the speed cycle. I set to heavy soil and three extra rinses. How do I get more water?
When I was looking for a new washer, I looked at front loaders and was told that they are not really for dirty clothes, it is more for sprucing up an outfit or shirt. They are supposed to be energy efficient read this less water and shorter wash cycle.
I would go for a top load heavy duty, stainless steel tub.
You are just wasting money trying to get this one to wash over and over again. good luck.
Jan 03, 2017 | LG Washing Machines
Maytag heavy duty washing machine quiet series 100 leaks water from the top panel
Older maytags were equipped with an "air-gap" that can leak if the rubber sleeve part of it gets too stiff and cannot flex. It is along the left hand side of the machine fastened by a 5/16" screw between the machine cabinet and the upper panel... Maytag Injector Tube 12001677
If you remove the front panel and set the machine to fill, you should see water dripping off of the plastic frame the injector is sitting in.
If it is a newer maytag, check the fill spout for cracks or sediment build-up Maytag Water Supply Tube WP3360977
Jun 06, 2016 | Maytag Washing Machines
My maytag oversize capacityplus quiet pack heavy-duty with lifetime tub will not drain the water on spin so i am left to ring out my laundry wat could possibly be wrong with it and how could i fixit
If the fault is not emptying the water out check the pump & also hoses for blockages. If the washer is pumping all the water out but not spinning fast enough, check belt tension & clutch.
If you have a drip dry switch check that it is turned off.
Apr 10, 2015 | Maytag Washing Machines
Can t turn stearing left or right takes all my strength to turn
check out the steering connecting rod. its the rod that goes from left to right front wheels. if it is not completely straight, either bend it straight or buy a new one.
Also, could be your front axle if you dont have the cast iron heavy duty axle.
Jun 24, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a Maytag Heavy Duty /supersize capacity/Quiet Series 100/ 10 cycle dryer. It is not so Quiet when it is turned on, It has a very loud squeak for about 5-10 min. Then it quits and does not have A...
my daughter had same problem. maytag used to be build to last but no more. the dryer tub sits on the front lip around the door opening the support breaks and then the tub has no support and ride around rubbing on opening lip squeeking and causes a lot of friction and will either break the belt or a plastic piece on the motor. it broke all the above on my daughters dryer. we just junked it good luck
Sep 10, 2012 | Dryers
Dependable care model no LAT9806BGE Dependable care Heavy duty Now very noisey when spin drying.Have to stop machine. Viabration bad in the tub. Belts have been replaced. thanks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Maytag Washing Machines
Hello, I love my Ktchen Aid washer and have had it for over 17 years! It is a 3 speed, quiet scrub, extra capacity/heavy duty. The water fills the tub, but does not shut off and over runs onto the...
All you need to do, is see if you can find a Pressure Switch available at a Spares Depot. This is the problem with your Washing Machine. I do not know if you will still be able to get one though. The pressure switch notifies the Timer/Module when there is sufficient water in the Tub to commence washing.
Hope this helps.
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | KitchenAid Washing Machines
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
LG WM2355C water leaking under machine after washing finished.
HI, you will want to Inspect the water supply connections. this is a good spot to check first. there may be a loose connection here, causing the leakage. Next, Inspect the drain hose. Check to make sure that it is tightly connected to the drain pump. replace if needed. Last. Inspect outer tub/basket for cracks or corrosion.
You will find the issue in one or all of the above stated check points.
Jul 23, 2009 | LG WM2277H Front Load Washer
Washing Machines Logo
85 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
