Question about Microwave Ovens
Beko ab910w getting eo fault code on the display
We have a may tag convection oven tat is displaying error code F5E2
This is a door lock error code. The same error code is also used on top loader laundry washers.
Whirlpool Fault Codes
Oct 04, 2016 | Microwave Ovens
ERROR CODE F6-EO
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 02, 2016 | KitchenAid Kehu309Sss 30" Microwave...
Error Code F9.Q (Touch Communication).
KitchenAid Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Kitchen-Aid-Appliance-Fault-Codes.aspx
Fault codes for a number of KitchenAid appliances, including two and four digit codesfor ... F9 - Oven Door Lock Failure - Check door lock switches and wiring.
Jul 27, 2015 | KitchenAid KHMS2050SSS Microwave Oven
----c fault on display
I am not trying to stop you from trying to repair your Oven; however, the cost to replace circuit boards including your time and effort exceed the cost of a new Microwave.
Lowes has some as low as $150.00 and dent or blemish for far less.
Dec 23, 2013 | Microwave Ovens
Sears microwave m/n 721.63663300, displays F9 code ,what does that indicate?
The F9 error code indicates an inverter failure. This can sometimes by caused by a power surge or glitch through the electrical lines. You can sometimes clear this fault by completely unplugging the microwave for 1 minute.
Dec 23, 2011 | Microwave Ovens
I have phoned 08000094837 to report i have a fridge freezer 0610422010, CDA539F, which i beleive is on the list of faulty ones, but i keep getting cut off. what do i do now. Thanks missJ Gilmour
You have a Beko model which may have the fire risk fault as the serial number begins 06.
The story has been going for a while now, but as it was widely reported yesterday then you will definitely have problems calling the Freephone line as many other owners will also be worried.
You only have two options:-
1. Continue to try and call the helpline, or;
2. Visit the Beko recall website and click on the link at the bottom of the page. You'll effectively get exactly the same response as for the phone number.
You may also wish to read the BBC News report which gives details of the fault.
Jul 06, 2011 | Microwave Ovens
My beko wm6123s is washing and spining but is making very loaud nosies please can you tell me the prom and how to fix it?
It the fault is only about noise then it is important that you need to get a good look at the moving parts when the machine works.
Once you have some idea of the area of noise then shut down and remove the mains plug. Now manually turn the washer drum or the motor to confirm the place of noise. It can be poor bearings, displacement of the drum rubbling against the washer body or even faulty motor bearings.
Sometimes a drop of oil or grease ont he moving part will remove the noise.
Jun 06, 2011 | Microwave Ovens
AEG Fault code E202 On opening the door of my microwave combi oven the interior light flashes accompanied by what sounds like a relay chattering and the display flashing between the normal display and...
I would suspect a bad door switch or door switch mount, or possibly a bad electrolytic capacitor on the control circuit board.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
Beyond that, I could only speculate, since I don't have experience or information on AEG products.
Jan 09, 2010 | Electrolux Microwave Ovens
My new Whirlpool oven Model number GBD 279 PVS02 error code EO F2
F2 E0 is a shorted keypad. Replace the keypad which is your entire touch pad. In rare cases your ERC or electronic range control can also be bad, unlikely though. Hopefully this is still under warrantee as the part alone is over 150.00. I recommend you have a technician replace this as most parts houses will not warrantee a electical part if a customer installs it. Good Luck, Appliance Specialists.
Dec 15, 2009 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
