Question about Garmin nuvi 255W GPS Receiver
How do I find POI for a city that I am going to visit ? I can only find POI within my vicinity. I went to where am I then programmed the new city I was going to be in but it kept looking for an address. With my previous garmin I know I was able to get the POI of another city that I programmed.
  • 464 Answers
To find distant POI's or one close to your destination all that you need to do is when in the "Points of Interest" section under "Where To?" change the near setting to recent destination or any of the other selections.
Hope this helps!
Posted on Mar 29, 2011
Santa sent his reindeers, Prancer, Dancer, Comet, Vixen, and Rudolf, each to a different city, each with a sleigh of a different color, to bring various gifts to good children. Comet was sent to Chicago,...
The trick to this is to list all the reindeer.
Write down what you know about each reindeer. Tick the list.
Then use a process of elimination to work the rest out.
The answer is here.
Discussion Board View topic Santa sent his reindeers
Mar 01, 2017 | Miscellaneous
Tip
Garmin POI, GPI, GPX, GDB and CSV and how not to be confused
GPX or CSV file can be converted to the proprietary Garmin format GPI format (Garmin Points of Interest) format using the Garmin POI loader v2.54 OR use the one bundled with the Garmin Map Source v6.15.11 at the time of posting if there is also a BMP file of the same filename then this will be added to the Waypoints Symbol.
If you put all your POI that you want to be added to the Garmin POI then place all them in the same folder prior to starting the POI Loader and they will be placed into sub-menus otherwise it will select the single file entries only.
However the Garmin Mapsource can't open this GPI format it is specifically for the SATNAV Device only open GDB, MPS, GPX and LOC files can be opened as standard. There are two ways that I know of that will convert this GPI back into CSV or the POI format if required you might like to open the POI content in the Map Source program.
First this can be done using GPI2GPS it does however cost 15 EUROs or its older brother GPSConvertor for an extra 20 EUROs will convert to all formats for all makes of device including Tom-Tom, Garmin and many others.
Secondly you can convert POI file in CSV format directly to GPX (exchange format) using the excellent GPXtoPOI Convertor v1.1.8 then import directly into the Map Source if you also want to use BMP that has been downloaded in Map Source you can replace the 8 default custom waypoint symbols located on your computer with your own or from the Tescos.ZIP file in this example that contains the CSV and BMP.
You can open these symbols with a graphic editor and use them as templates for creating your own symbols.You can add up to 64 custom waypoint symbols. These symbols must be in .bmp format and must be named numerically from "000.bmp" to "063.bmp." Custom waypoint symbols can be 16 x 16 pixels (small) or 24 x 24 pixels (large) and up to 32-bit color
Also check out my other POI tip HERE for help on how to create your own BMP's for use with your Garmin using Adobe Photoshop
It will also convert any GPX format into CSV format for use with the POI loader using the other button on the menu maybe this program would be best called GPXtoCSV instead to avoid confusion
And this one I saved for last If you want to transfer images from the Garmin use xImage and have your Garmi SATNAV connected.
For a full list of all POI sources then visit the Gamin POI Source another great website full of loads of useful tools is www.freegeographytools.com
If you are unable to use xImage it means that you unit is not compatible for example the Nuvi 250 will not be found and you may see this window
on Apr 18, 2010 | Garmin nuvi 250W GPS Receiver
Unlock samsung soltice
Since your phone is locked, it means you need to unlock the phone to be able to use it again. It is certain that you cannot unlock this phone for free, anywhere or on any site.
Though there are some Samsung phones that can be unlock for free, but unfortunately, yours cannot be unlocked for free because it is a new model phone.
Some sites offer to unlock phones and charge some amount of money, but I won't recommend that for you because those unlock codes are not reliable.
I would advice that you take the phone to a phone tech within your area/vicinity, and your phone will be unlocked there within a couple of minutes. The phone code will be reset with with computer using a phone cable. I'm sure you do not have the facilities to unlock your phone that's why I'm referring you to a phone tech.
But if you want to unlock your phone online, you can visit this link:http://mobileunlocked.com/index.php or http://www.unlockadvantage.com/index.php or http://www.mobile-unlocker.com/
In summary, there are two was methods by which you can unlock the phone. 1. it's either you take it to a phone repair shop and get it unlocked or 2. visit any of the above links, and follow instructions to unlock.
So you can either take the phone to a repairman within your area/vicinity or try any other the above links.
Good luck.
Jun 11, 2011 | Samsung Cell Phones
I have a nokia E63 (optus) and i don't know how to unlock it
Though there are some Nokia phones that can be unlock for free, but unfortunately, yours cannot be unlocked for free because it is a new model phone.
Take care.
Mar 22, 2011 | Nokia E63 Cell Phone
Hi, ive recently had a friend visit my town and
Try reconnecting, might be your wfc connection went down, check if the settings correspond to your internet router's settings.
Aug 15, 2009 | Nintendo Animal Crossing: Let's Go To The...
I bought Garmin nuvi 765T after having Viamichelin navigator in my car fo some years. . In the old GPS I could navigate to "city center" which was quite useful, when you travel and want to visit a place...
Check in the settings/setup options to enable all the POIs (Point of Interests) and then check if you can find the "city centers" If not then maybe the maps of this GPS device does not have this POI.
Aug 10, 2009 | Garmin GPS
I want to just put in post code but then it asks for house no. and street which i dont have. Can I get to destination with only postcode. Its new to me!
use the POI ( points of interest ) feature. select poi / category / pick a poi, ie. gas station / near city, enter city! that will get you in the city(zip) you want..if you dont know the city name, type the zip in google to locate it.
Aug 08, 2009 | Garmin GPS
Maps Still Not Updated?
You are confusing map updates with POIs (Points of Interest). Garmin does not keep up with restaurant openings and closings, to the best of my knowledge. Updating your maps will give you the latest street information (such as new subdevelopments, one-way streets, newly opened bridges, etc.) but will not let you know that the KFC closed or that the Chalet de Alpina closed last year. Your POI information is current as of the initial programming of your unit. You can enter POIs manually, if you chose to do so, but they will only be good as long as you keep up with them.
Mar 04, 2009 | Garmin StreetPilot c550 GPS Receiver
Used Garmin 750 once without problem... then prob with POI menu
TOOK IT BACK TO SAM'S CLUB AND GOT ANOTHER NEW ONE......... THANKS
Dec 27, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin nuvi 255W GPS Receiver Logo
64 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
