Question about Dell Computers & Internet
MY CD ROM DRIVE DUSNOT SHOOWUP ON COMPUTER - Dell Computers & Internet
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 174 Answers
The first thing you have to do is to go to Device manager and see if your CD ROM drivers are installed correctly. if not give us information?model number of your CD ROM to find a correct driver.
Posted on Mar 27, 2011
Except_handler4_common msvcrt.dll xp download
Option (1)
To resolve this issue, use the Windows XP Recovery Console to replace the Msvcrt.dll file with the original version. To do this, follow these steps:
  1. Insert your Windows XP CD-ROM into the computer's CD-ROM drive or DVD-ROM drive, and then restart your computer from the CD-ROM.
    NOTE: Some computers may require that you modify the basic input/output system (BIOS) settings before you can start the computer from a CD-ROM. For information about how to modify BIOS, see your computer documentation.
  2. At the Welcome to Setup screen, press R to start the Recovery Console.
  3. Press the number key that corresponds to the installation that you want to repair, and then press ENTER.
  4. Type the Administrator password, and then press ENTER.
  5. With the Windows XP CD-ROM still in the CD-ROM drive or DVD-ROM drive, type the following commands, pressing ENTER after each command:
    • cd system32
    • ren msvcrt.dll msvcrt.old
    • CD-ROM_or_DVD-ROM_Drive_Letter:
    • cd \i386
    • expand msvcrt.dl_ BootDriveLetter:\windows\system32
    • exit
    NOTE: BootDriveLetter refers to the drive letter of the boot drive. In other words, it refers to the drive where the Windows folder is located, which is probably drive C. CD-ROM_or_DVD-ROM_Drive_Letter refers to the drive letter of the CD-ROM or the drive letter of the DVD-ROM drive. The CD-ROM drive or the DVD-ROM drive are frequently located in drive D.
Option (2)
Fix the registry issue with ADV Tweaks Suite Free.
Dec 02, 2013 | Microsoft Windows XP Professional
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Can't get into any folder because c:Windows/System 32/rundll32 .exe keep popin up
To resolve this issue, follow these steps:
1.
Put the Windows XP CD ROM disk in the CD ROM drive.
2.
Click Start , and then click Run .
3.
Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4.
Restart the computer
2.
3.
4.
1) Put the Windows XP CD ROM disk in the CD ROM drive.
2) Click Start , and then click Run .
3) Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4) Restart the computer.
Oct 27, 2010 | Computers & Internet
Computer no recognize CD-ROM Drive
If it is a "swappable" device, then first shut-down your computer. Remove the other device that currently is installed in the drive-bay. Insert the CD-ROM drive, and restart your computer, so that it can detect the "new" hardware.
Apr 25, 2010 | Compaq 255215-001 Plug-In Module 20x...
When i choose somewhere:
Hi there, This issue may occur if you accidentaly replaced the Msvcrt.dll file with a third-party version that does not contain the _resetstkoflw (recovery from stack overflow) function. inorder to resolved this issue please follow step by step procedure below.
    • cd system32
    • cd \i386
    • exit
Hope this resolved the issue. Thanks!
Apr 06, 2010 | Microsoft Windows XP Professional
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
Computer
Hi Diviola, you have no choice but to buy a CD-ROM drive. They are not as expensive as you might think. You're windows CD can format the hard drive in you're computer before installing windows. Some people can use a USB memory stick but in order to copy the windows CD software to the memory stick you'll still need a CD-ROM drive. A 2GB or 1GB memory stick will cost as much or more than a CD-ROM drive. Please click on the link to see some prices for a standard CD-ROM drive.
http://www.zipzoomfly.com/jsp/ProductList3.jsp
& here.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3287198&CatId=87
The link above is a CD-ROM drive & can also make CD-RW's (RW stands for re-write).
You can replace you're CD-ROM drive you're self. Just do not disconnect the cables from you're old CD-ROM drive untill you have the new drive. Connect the cables to the new drive (one at a time) as you disconnect them from the old CD-ROM drive.
Double check that the cables are tightly connected before you power up the PC. Load you're windows CD into the new CD-ROM drive & when you start you're PC up windows will start to load.
When you receive the new CD-ROM drive & if you need help connecting & running anything. You can come back here & ask questions. I'll help you through this.
Luck!
Mike
May 10, 2008 | Creative Labs Sound Blaster Live! 5.1...
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Cd rom 52x mtrp
check the driver version for an updated one on the internet
Feb 03, 2007 | AOpen CD 952E Internal 52x CD-ROM Drive
Computers & Internet Logo
75 people viewed this question
Alun Cox
