Question about Miele G 2872 SCVi 22 in Builtin Dishwasher
Miele G 2872 dishwasher display shows 'door opening fault '
Krazytech
  • 725 Answers
SOURCE: i have a miele g2220
the clogged circulation pump (error code F14)
Posted on Jun 16, 2008
dragonsthatk
  • 547 Answers
SOURCE: Change miele dishwasher door seal
http://www.partstap.com/ please go to this site for diagram please rate me thank you for useing fixya
Posted on Feb 25, 2009
  • 10865 Answers
SOURCE: the door to my miele dishwasher does not spring
The operative word is spring[s]. There are two springs to assist in lifting the door. One on each side. If your dishwasher is an older modell it is time to replace the springs because they are worn out.
Posted on Jul 18, 2009
SOURCE: Miele dishwasher drying problem
Great advice, one build on the G646SC Plus; the 4 screws are the lower 2 screws either, on the stainless steel inside of the door
Posted on Jan 02, 2010
ZJLimited
  • 17970 Answers
SOURCE: Have just bought a secondhand
F11 - Drainage fault
This code means that water present in appliance and is not being drained off. The display shows Drain fault F11. The buzzer is activated for 2 minutes.
Background information:
After each drain pump step, the circulation pump operates for 2 seconds and heater pressure switch B1/13 checks the water level. If it is too high (large quantity of residual water remaining in the cabinet), the drainage time is extended. If, after a further check, the water level is still too high, then the program is interrupted, the fault code is saved and the drain pump is activated. Fault code F11 is also registered if heater relay 1K1 is not activated after the fault code F51 register check; see Section 080-3.18. Drain hose kinked. Remedy: Check the drain hose for correct positioning.
Cause: Drain blocked.
Remedy:
1. Clean the on-site drain.
2. Check the sump drain.
3. Check the filters.
4. Check the heater pressure switch and replace it if necessary.
Cause:
Ball in non-return valve in sump has not opened (e.g., jammed).
Remedy:
Clean the non-return valve in the sump or replace it if necessary. Cause: Foreign objects in the drain pump.
Remedy:
Clean the drain pump and its impeller.
Cause:
Drain pump defective.
Remedy:
1. Check the voltage supply to the drain pump.
2. If correct voltage is present, check the drain pump motor winding.
3. Replace the drain pump, if necessary.
Cause:
Foreign objects in heater pressure switch.
Remedy:
Check the heater pressure switch for blockages and correct switching point.
Cause:
Heater relay defective. Heater relay (coil or contacts) becomes defective during the drainage step (after fault code F51 register check).
Remedy:
Replace the heater relay.
In other cases, owners found a piece of wood inside the door latch mechanism and removed it. The F11 error has not appeared since.
Hope ths helps.
Posted on May 20, 2011
Why is my Miele dishwasher displaying "Open stopcock", even though water is flowing and I've cleaned the inlet filter?
There are 2 possible main causes for lack of water, given that you have checked water availability at the dishwasher.
1. The water solenoid valve in the machine is faulty or failed.
2. The motherboard in the control panel has a fault and needs replacing.
Unless you are a DIY'er I suggest you call a serviceman
Apr 06, 2017 | Miele Dishwashers
Tip
My Miele washing machine is locked.
Recently I received many requests from users in troubles because they could not unlock their washing machine.
I decided to publish a tip illustrating the unlock procedure.
These instructions apply to most Miele front loading washing machines. They will work on all the W4800 series washers.
Instructions on how to set on and off your Miele’s child lock function are also contained in the user manual.
If you attempt to open the door while the Child Lock function is activated you will get the message "Machine locked" and the picture below on display:
If the door lock is locked during the wash cycle, press the pause button, and the door will open.
In order to deactivate the Child Lock:
  • Press and hold the "Heavy Soil" button until the display shows an unlocked pad lock picture and says Ready to Use (hold up to ten seconds, it should be less).
If you want to re-activate the Child Lock:
  • Press and hold the "Heavy Soil" again, until the display shows a locked pad lock picture and says Ready to Use .
The drum door cannot be opened, and the machine may stay locked if one of conditions below is occurring:
  1. The water temperature is more than 55°C (130°F).
  2. The water level is too high.
  3. The Child Lock function is activated.
  4. There is a fault.
If the washer is in one of the above conditions, you will get the machine locking even if child lock is off.
If the door is locked because of a fault, and there is water in the drum, the machine will also lock up.
In that case the door will open only after accessing the drain pump.
The pump service door is opened using a tool stored behind the dispenser drawer.
The tool must be used only after disconnecting power.
I think I will post a detailed procedure on how to fix a blocked drain pump on the next tip.
I hope this tip has helped you to fix your problem.
Goodbye.
on Dec 10, 2009 | Miele W4840 Front Load Washer
How do I fix a Miele G2470 SCVi with an intake/drain fault
Look for item(s) blocking the drain, inside bottom, and remove them.
May 24, 2014 | Miele Dishwashers
Arm won't retract and door will not close.
hi
here can be two main problems
1) if once you close the door is a continuous click then your problem is the the electric/mechanic lock from top of your dishwasher
2) if once you close the door nothing happening is the switch from inside of the door this one can be tested making a bridge bet-twin the 2 wires are connected to the switch ( please make sure you unplug the dishwasher from mains before you carry any work on it )
once bridge done and dishwasher plug back to the mains the arm will retract in even if you not close the door
Aug 24, 2013 | Miele G 2872 SCVi 22 in Builtin Dishwasher
F78 error - alarm went off dishwasher stopped
hi
after dishwasher take water the red light start to flash and fault f78 is show on the display ( let me now if i am right )
the f78 is the electronic board on the main pump or pump itself is busted
Oct 14, 2012 | Miele G 2872 SCVi 22 in Builtin Dishwasher
Miele LaPerla Dishwasher showed fault code F174 at 27 hours operation. How can I get a copy of the Miele fault codes? I pay for Remote Monitor and did not receive an alert. What is fault code F174?
Hi - I have not come across a fault code F147 on a miele dishwasher, the highest being F112, are you sure its not F47 instead, this relates to a faulty electronic controller unit.
From what I know of LaPerla the model G2830 series and even the faults does not have a F147 amongst the chart.
Jun 08, 2011 | Miele Premier-Plus Built-in Dishwasher
23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
Miele Dishwasher door release problem
I switched the dishwasher off at the mains and then back on again. At this point the plastic arm started making a noise like it was trying to retract so I pulled the door to help it along. The door opened and the arm fully retracted - much to my relief.
Mar 15, 2008 | Miele Dishwashers
Miele G 2872 SCVi 22 in Builtin Dishwasher Logo
109 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
