Have whirlpool duet washing machine. Removed front panel, pulled on white tear shaped plastic lever., and door will still not release after pulling manuel switch. No error codes. What's the next step?
  • Washing Mach... Master
  • 8,220 Answers
Perhaps you have a item of clothing in the latch. Press against the door while pulling that rip cord.
I have a service manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 27, 2011
How can I unlock the door to my Whirlpool Duet washing machine?
try this link..Pull down on the bottom panel and pull it away from the washer. Reach through the open panel and up to the door lock. Find the release ring below the locking mechanism. Pull down on the ring to unlock the door.
How to Unlock a Whirlpool Duet Washing Machine ' Home Guides ' SF ...
homeguides.sfgate.com/unlock-whirlpool-duet-washing-machine-68645.html How can unlock the door to my Whirlpool Duet washing machine Google Search
Dec 12, 2016 | Whirlpool Washing Machines
How do I get the door to open on a whirlpool front load washer? It stopped in the middle of a cycle
remove front panel below the door reach up the right side of the door inside pull on a tear shaped ear connected to the door switch assembly pull down on this it will manually release the door lock
May 12, 2012 | Whirlpool Washing Machines
The front door is locked and I can't loacate the lever inside the machine
Remove the bottom panel and their is a pull ring yall can release the door.
Jun 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool duet washing machine. We had a
Unplug the machine.
Remove the lower front panel.
Reach your arm up inside on the door latch side. Feel for a pull ring and pull it to release the door.
Feb 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The lock for the door is stuck how can i unlock it
You need to remove the top cover, and release the door catch from inside with a screwdriver or similar.
Please rate my solution.
Thanks.
Nov 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wash cycle has ended and door will not unlock.
welll there are 3 screws across the bottom front of the panel (torx 15) the lower acees panel can be removed, from there you can gain access to the backside of hte lock assy and manually release it. simply run your hand up the right side, just below the lock/latch assy ther is a quarter sized/teardrop shaped pull cord. thos will release the door, for you
Dec 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Manual Release
if you're talking door release ..remove bottom panel reach up to lock location pull down on tear shaped plastic tab
Jun 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I can't get the door unlocked.
remove lower panel reach up to lock area tear shaped plastic tab pull down door released ..now remove big plug in pump housing and remove objects
May 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer door locked
After pulling the manual door release by removing the bottom door panel you are able to add 1 cap (1 tbsp) of liquid cooking oil to the water. The cooking oil will greatly reduce the amount of suds so you can complete the cycle.
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
