Question about Gold Medal Kitchen Appliances - Others
Wanted to find a wiring diagram for the 3 main power wires,red,black and white,going to the switches. they were disconnected at the terminals for cleaning the top side and weren't labeled. I have it narrowed down by the scratch marks from the re3moval but want to be sure.
  • 5 more comments
  • stephen_w533 Mar 27, 2011
    citation 2001
    sorry, it is an older citation 2001,3 power supply terminals just need to be slid over the posts. but there are quite a few.
    have an older citation 2001 popcorn machine. 3 main power wires are slid off the posts on the switches buss bar.there are quite a few posts and i want to be sure they go back on the correct ones ,so i either need a diagram or a way of tracing.they are red,black and white, no green.
    Citation 2001.No green coming out of the main cord.
    Its a citation 2001,older. Its got quite a few posts on the "bussbar" to the switches that weren't being used. Just the three of them wires need to be slid back on to the posts to reconnect main power.How would i know for sure which ones to go to?
  • stephen_w533 Mar 29, 2011
    Thank you, although my 2001 is much older.
    Here's the thing. The diagrams of most models show the black and white going to the same switches , no matter how modern, but if you look closely to the picture in the parts manual you can see a red wire from the main power, mine also has a red from the main three. The schematics i have seen do not address the red wire and where it goes. They all show green. Am I wrong? What am i missing, it's got to be very simple.
    Thank you again so much for your time.
    from Steve.
    excellent advice.and so superbly simple and fool proof. the only question is where would it go on the bussbar if it is ground. i will start there though, thank you.
    Guru:
  • 262 Answers
What is the model number?
Posted on Mar 27, 2011
  • 1 more comment
  • Keith Drake
    Keith Drake Mar 27, 2011
    What a cool machine.
    here is a link to your machine.
    click on the link http://www.mypopcornmachine.com/gold-med...
    you can download your spec manual,installation manual,and parts manual.
    the connections have a nice picture in the installation manual.
    If you have further questions please post.
    Keith
  • Keith Drake
    Keith Drake Mar 29, 2011
    If you plugged in the cord without hooking up the other end,using your volt meter,you could find the hot wire and neutral wire and the ground wire.
    My guess it would be black is hot...white is neutral and red is ground.
    However to find out for sure....disconnect the plug...it should have two screws on each side and see what wire is hooked up to ground....the one prong on the bottom of the cord. That one will be the ground wire.
  • Keith Drake
    Stephen.....
    Let me know what you find out please.
    We will figure it out.
    President:
  • 1,961 Answers
Need to know the brand and model number....
please post back!
Switching 3 prong cord to a 4 prong cord
if theres a wire from the center terminal on the dryer terminal board going to the dryer case disconnect it,then Red & Black on the cord go to the outer 2 terminals on the dryer terminal board,the White goes to the terminal in the center between where you put the Red & Black wires this is the Neutral wire,then the Green wire connects to any metallic portion on the dryer case as this is the SAFETY Ground wire and also Red & Black can go on either outer terminal on the dryer terminal board as these are not polarity sensitive because its A.C. power so wire it on the dryer terminal board as in (RED-WHITE-BLACK) on the dryer terminal strip and connect the GREEN to any Metallic portion of the dryer case
Dec 30, 2012 | GE Profile Harmony DPGT750EC Electric...
What are the color code of the wires to switch terminals
Almost!
the black screw is the "common" so the hot wire or the colored wire (usually black or red) bringing power in goes on to the black screw and all white wires (neutral) get connected together. you need to verify which wire has constant power when all wires are disconnected and separated first.
*White wires all connected together separate of the switch
green screw = ground or bare wire
black screw = hot wire/ wire with constant power
silver screws = (switched terminals) black or colored wire from each device being powered (eg. light) per screw
Dec 22, 2012 | Leviton 003-1755-W Three Rocker Switches
The Casablanca 88U33M Scandia Ceiling Fan only has three wires, a black, a white, and a green wire (ground). How do you wire the fan and light on seperate switches?
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
Jul 04, 2011 | Casablanca Fan (88U33M) Ceiling
I bought a Leviton 1201-PLC 15 Amp, 120 Volt, Toggle Pilot Light, Illuminated ON to replace a traditional 3 way switch (without a pilot). I replaced it by connecting the existing wires to the new switch in...
Your screw terminals are 2-brass and 1-dark.
Dark screw is considered 'common'
http://waterheatertimer.org/ST01C-program.html#3-way
Leviton shows a 3-way 1203-2, but not 1201
Wiring diagram indicates that pilot light is ON whenever switch has power.
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=2681§ion=10046&minisite=10026
Check your instruction sheet that pilot light is supposed to turn on-off with Load.
I don't think it is, without additional terminal on switch for neutral wire.
And then it would only work on switch located closest to light.
You can wire this type of thing separately.
Buy ordinary pilot light or indicator light from WW Grainger.
Look at diagram on following image:
http://waterheatertimer.org/images/3-way-circuit-with-pilot-indicator.jpg
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 08, 2011 | Leviton Snap On Mount Switch Pilot Light -...
The 3 way switches I purchased say to hook the hot wire to the dark colored screw but it is not in the location on the switch show in the diagram. Do I use the dark color screw or the position shown on the...
the darker colored screw is always the hot terminal no matter what,and the other silver or lighter colored are for the traveler pair to the other 3way switch,if the switch and diagram seem to differ,you can go to the manufacturers website and contact them for further info on this question,it could also be the wrong diagram with this particular switch unless its marked identical on both the switch and diagram
Mar 23, 2011 | Cooper Wiring Devices INC #C7503W-SP WHT...
Do I connect the black and red wires coming from my first 3 way switch to each of the black IN screws on my 4 way switch and connect the other black and red wires to the gold OUT screws going to my last 3...
http://www.leviton.com/OA_HTML/ibcGetAttachment.jsp?cItemId=sPOj1y4-FvozD26dzcf2mQ&label=IBE&appName=IBE&minisite=10026
Here is the wiring diagram.
It looks like you connect the black & red wires on the sides as you state.
The black coming from one 3-way connects to the top terminal on one side, the red coming from the same 3-way connects to the bottom terminal on the same side.
The black going to the other 3-way connects to the top terminal on the other side and the red going to the other 3-way connects to the bottom remaining terminal.
Dec 27, 2010 | Leviton 112-05604-2WS 15A 4-Way Decora...
I need a wiring diagram for a double switch
The following applies to the Pass and Seymour Legrand 1595-2SWT combination two switches with GFCI receptacle device ONLY.
Sorry for the long post, but the manufacturer's wiring diagram for that device is very difficult to follow and I want to make sure that you understand what's what. A basic description of how the device works may help.
At the top of the switch is where one connects the incoming ( HOT circuit from the circuit breaker or source) (LINE) wires. The black is connected to the HOT terminal and the white is connected to the WHITE terminal. That powers up the GFCI receptacle.
On the bottom of the switch there are two (LOAD) terminals (HOT and WHITE). This is where one connects _any_and _all_ loads which are to be GFCI protected, including any downstream receptacle outlets that one may want to GFCI protect.
The thing to understand about GFCI's is that BOTH the hot and the "neutral" white wires for the load(s) _must_ be connected to the LOAD connection on the GFCI in order for it to function correctly. Think two wires IN from the (LINE), two wires out to the (LOAD).
Also, at the bottom of the switch should be 3 wires which are permanently attached to the device, black, red, and yellow. These wires are _not_ connected internally to anything related to the GFCI. The black wire is common and the red and yellow wires are the switch legs (pick one). In other words, individually, these wires function just like a regular switch. If one supplies 120 volts to the black (common) wire, when one switch is turned ON one or the other red or yellow wires (pick one, let's say the red wire) will be energized. When the other switch is turned ON the yellow wire will be energized. Understand that if the black (common) wire is not supplied with 120 volts you will _never_ power the red and/or yellow switch leg wires.
For equipment grounding, of course, the bare (or green) equipment grounding wires are all twisted together with 2 pigtails using a red or gray wire nut; one pigtail goes to the green screw on the switch and the other pigtail goes to the green screw on a metal box (if you have a metal box). There are other ways to do this, but that's the general idea.
OK, after all that, we're ready to wire the 1595-2SWT. Understand that there are many scenarios for wiring that device. I will describe the most common one.
The following assumes that you have only ONE circuit supplying 120 volts to the box. It also assumes that you have separate cables going to each switched load and that these loads are _NOT_ connected to any power source other than the one supplied by the switch itself. It's OK to have a 3-wire cable with ground (black, red, white, and bare) going to the loads. Additionally at this time we will also assume that there are no downstream receptacle(s).
After making all the equipment grounding connections;
LINE connections:
Connect the white wire from the incoming (LINE)120 volt cable from the breaker or source to the the white (LINE) terminal at the top of the switch. Connect the black wire from the incoming (LINE) (HOT) 120 volt cable to the HOT terminal at the top of the switch. You should now see that the wiring for GFCI receptacle outlet itself is accomplished.
LOAD connections:
The two white neutral wires in the box that are in the two outgoing cables that go to the loads are twisted together with a pigtail that is connected to the (LOAD) WHITE terminal at the bottom of the device. OPTIONALLY, if you have a 3-wire cable with ground (black, red, white, and bare), just connect the white wire to the (LOAD) White terminal at the bottom of the switch.
Here's where it gets tricky. Connect the black (common) wire that is permanently attached to the device to the (LOAD) HOT terminal at the bottom of the switch.
Do you see now that any loads connected to either the red or yellow wires will be switched _and_ GFCI protected? If not, please STOP what you are doing and post back here, or called a qualified electrician.
You may then connect the red wire to one of the switch legs and the yellow wire to the other switch leg.
Do you now also see that you can easily add a downstream receptacle to the deal by simply bringing a cable into the box from that downstream receptacle and connect it to the load side of the GFCI?
I hope this helps. BE SAFE and don't forget to turn OFF the circuit and test it to make sure it is OFF.
Feb 27, 2010 | Pass & Seymour / Legrand 1595-2SWT...
Lakewood heater 7101 schematic
The power cord goes the switch terminal 1 and 3.
Terminal 2 must be the opposite of terminal 1, such that when switched on, 1 & 2 connects. Terminal 4 must be the opposite of terminal 3, such that 3 & 4 connects.
Under this setup, you may connect red to terminal 2
and black to terminal 4.
Be sure of the 1 & 2 pair, as well as the 3 & 4 pair.
then, connect the red and black wires.
Hope this will help you.
Jan 06, 2010 | Lakewood Oil-Filled Electric Radiator...
Need help with the wiring on the reddy heater 110 btu
CIRCUIT CARD-
-Photocell blue wired go to two terminals marked BLUE PHOTOCELL (any order)
-Motor red wire plugs onto terminal marked MTR MAIN, motor white wire plugs into terminal marked WHITE MOTOR.
-potentiometer (thing with knob) two white wires plug into terminals marked TEMP SEL
-Black wire from switch to terminal marked L1 BLACK
-White wire from power cord goes to terminal marked N White
-Ignitor (used to be yellow wires) goto terminals marked IGNITOR and IGNITOR RET (any order)
OTHER-
-White wire from power cord goes to switch terminal marked 3A , other pigtail of the white wire goes to board as described above.
-Black wire from power cord goes to swtich terminal marked 4B
Nov 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
10-3 w/ ground wiring diagram
your 2 hots phase wires RED and BLACK need to go to the L1 and L2 terminals,the white goes to the "N" neutral terminal and green or green w/yellow stripe is case safety ground---now at the breaker the RED/BLACK are connected under each one of two screws on the breaker the white goes to the NEUTRAL BUS BAR on the palel surface where all the white wires are already, also the green goes to the neutral bus bar,this only applies if this is the MAIN house power panel, is you wire it to a sub box panel then the neutral must be isolated from the sub panel chassis and ground can still be connected to panels case
Oct 04, 2009 | Dryers
Kitchen Appliances - Others Logo
241 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
Oloyede Monsuru
john h
Tom Chichester
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
