Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
My Frigidaire dishwasher will not start. It was working fine about a month ago. The lights on the panel are working and I had the water line checked and it is o.k. I cannot find a serial number but the book that came with it is for the 500, 1100, 1400 & 1500 series with fully electronic control.
My Frigidaire 500, 1100, 1400, 1500 & 2400 Series Dishwasher was purchased a month ago and it will not start either. The 8 second lock under "Heat Dry" is lit, but nothing happens when you press any of the other buttons. Any ideas?
Posted on Apr 04, 2011
My 2 year old frigidaire dishwasher is not filling up with water, goes through cycle but no water is coming out, valve is open all the way?
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Click on : Inlet valve
Jan 25, 2013 | Dishwashers
Dishwasher will not start andthe green lights on control panel on front of dishwasher door blinking. I have look for obstructions and the door seems to shut good.
I have had this problem with a different make of dishwasher. The light came on but then it did not work.
It turned out to be the water had been turned off to the dishwasher.
Check your water supply is on!
Sep 01, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
My Frigidaire fghd2433kf1 is not draining. I replaced my old dishwasher for this one two months ago due to the same problem. It appears that it might not be the dishwasher. What else could it be? Pump...
If you recently replaced the garbage disposal the dishwasher knockout has not been removed. OR the dishwasher drain hose is not high enough and water is leaking back in from the sink.
Aug 27, 2011 | Dishwashers
My dishwasher (Model # FDB520RHB0) is not quite 2 years old. We had the water pump replaced a few months ago because it had been making a grinding noise. Then we tried to run it a few days ago and it...
Did you check the outlet with a voltmeter? If you did and have 120Volts then it sounds like your latch switch could be defective which would kill the power to the unit.
But remember that in most houses that the outlet under the sink is wired for a garbage disposal where the top outlet is controled by a switch and the bottom one is wired for the dishwasher.
Jul 27, 2011 | Frigidaire FDB520RH Builtin Dishwasher
Dishwasher won't fill with water
Check the power supply to the water pump through a pocket electrical line tester or volt meter.
Poer reaches and the pump mot rotating, check the capacitor associated with the motor.
May 27, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Water into washer
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 05, 2009 | Roper 24 in. RUD3000 Built-in Dishwasher
Dishwasher will not turn on/ start cycle
i would ck incoming power at hook-up behind the lower access panel. maybe a wire nut loosed, if power present there next i would check the door latch switches, if they are not making contact with striker, or switch has gone bad, the machine is not recognizing the door closed and will not operate
Mar 09, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire Dishwasher
Find your main stop cock in your household for cold water supply and make sure it is fully open(anti clockwise).If this makes a difference to rest of house, then your washers pressure should be fine too.If still same problem, check your washers fill hoses have not been shut off.Try this when you set the machine to wash, you should here water pressure when filling.Hope this is helpful to you.
Sep 02, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
435 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
