Question about Mitsubishi Diamond Plus 73 17" CRT Monitor
Monitor problem actually,I am now using another monitor and i have no problem with my computer,i use it everyday in my cellphone repair shop. But I want my 17' mitsubishi flat crt monitor back,because i'm not comfortable with this 15' IBM crt monitor. I've already changed the horizontal transistor with the same value(C5587)because it is shorting but it doesn't work and theres no changes.so please please.. help me. i want to repair it my self.
    Genius:
  • 1,056 Answers
The reason I had asked if you had tried a different monitor was to determine if it was the monitor or the computer that actually had the problem. That wasn't clear in the first question.
A computer that is having issues will cause the same symptoms you described.
Repairing CRT's is beyond my level of expertise. When I get into a situation like this, I would just replace the monitor. Sorry I couldn't have been more help.
I stopped using CRT's when the price of LCD's dropped.
Posted on Aug 04, 2008
6ya staff
SOURCE:
Model M17ANA shuts off intermediatly Turns on ok but after a few seconds shuts off then back on again.
The issue you describe is a power supply gone bad. Actually it is a capacitor inside the PS that is now defective (it may be more than one). This seems to be a frequent problem with this particular monitor as I have personally had the same issue with one a owned.
Unfortunatly there is no good solution as there are basically only two options available to you.
1. Find an 'electronics /computer shop' that will remove the PS and repair it.
2. send the monitor to Star-Logic for repair.
The basic issue with either scenario is that the cost to repair may be more than the unit is actually worth. For instanse, you can purchase a new 20" LCD monitor for less than $90 form places like newegg.com.
I hope this helps you in some way.
Good Luck!
Oct 20, 2011 | Star Logic 17" LCD Monitor
MONITOR WORKS ON HEATING I have a HP vs15 lcd monitor . One day it stopped working , so i took it to a repair shop when the repair guy plugged the monitor in , it started working . After few days the...
When the bad caps (not completely gone but have high ESR) will start working when heated up, the ESR goes down, that is one of the trick I have been using for 30 years to locate bad caps by heting them with hair dryer.
I am surprised that 3 shops cannot find and fix the problem.
As you can see in my albums, most failure are due to bad caps. Can you poat the pictures of the board?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 12, 2011 | HP vs15 15"LCD Flat Panel Monitor
When I power up my computer the Gateway icon shows up but monitor stays black...I repeatedly hit the power button on the monitor until the screen finally shows up..and once its on it stays on all day until...
hi, these are exellent monitors. i have repaired and made good profit on these. there is about 8 capacitors on the main board that go bad. all are 470uf 25 volt. if you have good knowledge of soldering, you can perform this repair. even broken, these monitors go for 100 dollars on ebay. contact me back if you want more info on how to repair yourself.
Feb 08, 2010 | Gateway FPD2275W LCD Monitor
Internal Screen for LG Shine KE970
http://www.cellphone-repair-shop.com/products/lg-shine-ke970-cellphone-replacement-repair-parts_334.htm
Dec 13, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor always become blank screen
May be worth changing the monitor VGA cable
Aug 29, 2009 | Computers & Internet
No display on Windows Vista need driver?
Make sure that the settings in the new video card are actually set to run both monitors.I see this happen in my comp. repair shop quite often. It is a common mistake.
May 04, 2009 | Dell 1703FPT 17-inch Flat Panel Monitor
I dropped my phone yesterday and its screen is creacked and the actual lcd screen is also broken (i blieve) how much will it cost to replace on a Samsung mobile SGH-D520 model?
It will depend on where you are going to purchase your phone, if you'll purchase it in a store near you, it could be less higher than purchasing it online/in the internet. I t may also depend on your location.
It costs $99.95 dollars today in this sites:
Click the link to check it:
Cellphone Repair Shop
http://www.cellphone-repair-shop.com/products.php?cat=139
CellularDr.com:
http://www.cellulardr.com/products.php?cat=139...
I hope this could help...
Kindly rate this solution if it helps....thank you!
Sep 29, 2008 | Cell Phones
Monitor problem
To do an internal repair on a CRT is beyond my level of expertise.
I would leave repairs like that to those that do know. I've heard too many horror stories about what can happen if you don't know your way around the inside of a CRT.
Aug 04, 2008 | Computers & Internet
Samsung Blackjack SGH-I607
You can get a Samsung Blackjack I607 Window Lens at www.cellphone-repair-shop.com
Here is the exact link for the part: http://www.cellphone-repair-shop.com/GH72-30531A.htm
You can also send your phone to them and they will perform the repair for you.
Here is the link for the Samsung Blackjack Cellphone repair service they offer:
http://www.cellphone-repair-shop.com/Housing-Lens-Cellphone-Repair.htm
Nov 15, 2007 | Samsung Blackjack SGH-I607 Smartphone
Open Questions:
Aol verizon Tech support number -+1855~536~5666 Aol verizon Customer Support- HCTKRTC [email protected] is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the [email protected] email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. [email protected] support number When you are using the [email protected] for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the [email protected] support number and ask for the help. Once you dial the [email protected] customer support number, you come in contact with a team of experts at the [email protected] customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the [email protected] support phone number will help you with that simply and quickly. This is [email protected]'s best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a [email protected] agent. Features of [email protected] support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the [email protected] customer support phone number. Here are some of the features of customer service: The [email protected] customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the [email protected] customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this [email protected] provides you the facility of [email protected] support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the [email protected] Here are some of the issues that you are going to face when you are using the application:
Oct 22, 2019 | HIS Computers & Internet
SBCglobal MAil help {1-/855/*536/*5666/}#[email protected] desk NuMbER KENTUCKY This SbcGlObAl mAiL USA phone number is ranked #2 out of 2 because 7,728 SbcGlObAl mAiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbcGlObAl mAiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbcGlObAl mAiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbcGlObAl mAiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbcGlObAl mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbcGlObAl mAiL USA Calling SbcGlObAl mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbcGlObAl mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbcGlObAl mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbcGlObAl mAiL USA's phone numbers against each other. Contacting SbcGlObAl mAiL USA in General While I********** is SbcGlObAl mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbcGlObAl mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbcGlObAl mAiL USA.
Oct 22, 2019 | Best Computers & Internet
See all Mitsubishi Diamond Plus 73 17" CRT Monitor Questions
Mitsubishi Diamond Plus 73 17" CRT Monitor Logo
41 people viewed this question
Top Mitsubishi Computers & Internet Experts
Alun Cox
John Waters
John Waters
Tom Chichester
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
