Question about Maytag MER6772 Gemini Electric Kitchen Range
Oven does not work. I get an F-1 8 error message
    Genius:
  • 1,157 Answers
Hi michael_d_fo,
The F1:-8 error code description is Keypad Shorted. Check to see if steam or other moisture is getting into clock assembly. Replace keypad if necessary.
Hope it helps.
Thank you for using FixYa.
(Positive feedback will be greatly appreciated.)
Posted on Sep 23, 2011
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Runs 20 sec stops reads F1E5
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
When is bake mode, the oven heats and will shut off with an F3 error and blinking time. Totally unpedictable; works some times and not others with or without issues.
Disconnect the power supply for few minutes, say 15 minutes and then turn it ON. Do you still see the same error message. If yes, kindly revert with more information :-
1. Make and model of the oven?
2. How old the oven is?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 06, 2011 | Microwave Ovens
F-1 message
F1= Defective Touch Pad or Membrane Replace Touch Pad or Membrane
May 28, 2010 | Amana AES3760BAW / AES3760BAQ / AES3760BAB...
Over door locked
Error code F93 means the lock motor assembly spent too much time to lock. Someone needs to read the continuity of the lock switches and the door switch and apply 120 volts ac to the lock motor to see if it will run. If the oven is less than 1 year old you should schedule service and let a technician diagnose and repair the problem. If you want to repair the oven yourself make the checks with a volt/ohm meter and send another email if you need more advice.
Dec 17, 2008 | Frigidaire FGB24S5A Gas Single Oven
Kitchenaid YKGRT607HS6
F2:E0 is shorted keypad, and F2:E1 is no keypad connection, you need to replace the keypad.
You can find schematics and find replacements by entering model number here.
Dec 14, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Microwave error message
unplug your unit for 1 minute and plug it back again, you'll be surprised ...it will work again cheers
Nov 26, 2008 | Whirlpool GH5184XPQ Microwave Oven
Error F1E2 Whirlpool Super Cap Gas Range 465, oven crazy!
F1 E2
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Nov 22, 2008 | Whirlpool GS460 Gas Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
123 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
