Question about HP w2207 Monitor
My monitor goes into Sleep mode and it says there is no signal input. I have turned on and off and unplugged as well as disconnected. Does this sound like a common monitor problem or a computer issue?
  • 822 Answers
Check power options in control panel...........
check monitor turn off is set on NEVER...........
cheers
Posted on Mar 27, 2011
When I turn the monitor on I get a message "In
Most Dell LCDs have multiple inputs and they will go into "standby" while waiting for a signal from your PC. This happens when your PC goes into "sleep" mode or if you are sure your PC is not in "sleep" mode then usually the LCD is not in the correct input selection. Check the input selection for the appropriate input. As always, make sure the cables are securely connected. Hope this helps.
Jun 15, 2011 | Dell E173FP 17" LCD Monitor
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
Monitor will not awake from sleep mode. Pilot light is amber when asleep. If the monitor is turned off pilot light goes from amber to off or black or nothing. Turning the monitor back on the pilot light...
That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
Sep 03, 2017 | LG L196WTQ-BF 19" Monitor
It sayin no input and goes input into sleep mode
That means the monitor is not getting any signal from the computer. Check the video cable, make sure it's not loose or disconnected.
Dec 21, 2010 | HP Computers & Internet
Monitor goes to sleep when computor is turned on no input signal
If the monitor is going into sleep mode the normal power led will change to another color. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays on, you have a backlight malfunction. It can be bad capacitors causing an inverter power fault or it may have worn out backlights causing a shutdown condition.
Monitor Mike
Aug 17, 2010 | HP w1907 LCD Monitor
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
Monitor says no input signal going in sleep mode
TRY UNPLUGGING COMPUTER AND MONITOR AND DISCONNECTING MONITOR FROM THE BACK OF THE COMPUTER. BE SURE TO UNPLUG AND NOT TURN OFF. WAIT ONE MINUTE THEN PLUG COMPUTER BACK IN . RECONNECT MONITOR TO THE BACK OF THE COMPUTER AND PLUG IN. IF THIS WORKS, WAIT FOR NEW HARDWARE RECOGNIZED TO COME ON. FOLLOW INSTRUCTIONS, IF ANY. RESTART COMPUTER.
Feb 08, 2010 | HP vs15 15"LCD Flat Panel Monitor
Monitor goes blank coming out of power save mode
I found this on the Internet...
"Press the "Input" button on your LCD monitor's front panel repeatedly at three- or four-second intervals until your monitor wakes up. If your monitor is set to an incorrect input mode, it won't receive a video signal. After you reset the monitor to the proper input mode, it will receive the signal and wake up automatically."
I have provided a Link with more info for you!
A
How to Get Your LCD Monitor Out of Sleep Mode
Dec 24, 2017 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
Monitor comes on and says no input signal, then goes into sleep mode. Unplugging cables and replugging has worked in the past, but not this time.
Get another known good cable and plug that in. If that fails, then plug into another known good computer. If that fails, then either your monitor is bad, or your video card is bad.
Nov 01, 2009 | HP w1907 LCD Monitor
Desktop monitor
Hi
Disconnect the monitor from the tower and then turn on the monitor.
If u get a msg like no input signal or check video cable then the monitor is fine. If this is the case, it could be a problem with the tower or the cable.
Dec 31, 2007 | Compaq Presario 5BW284 (202493-003) PC...
HP w2207 Monitor Logo
684 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
