Question about Toshiba Satellite A70: A70 Intel Pentium 4 processor (HT) 3.06GHz, 512MB RAM, 80GB hard drive, DVD-RW multi... (SATELLITEA70A70INTELPEN) PC Notebook
What wireless router do I need for my Toshiba A70/A75 series laptop?
    Novelist:
  • 107 Answers
I checked the specification of this notebook PC and it uses a 802.11 b/g wireless adapter. You can purchase any brand of wireless router just make sure that it supports 802.11 b/g.
You can get a D-Link WBR-2310 108Mbps 802.11g Wireless 4-Port Router at ebay for around $20.00
Hope this help. Goodluck!
Posted on Mar 27, 2011
Testimonial: "Thank you so much for your quick response!"
Web cam not been detectered
Probably you haven't installed the camera driver. Try searching for it on Google! :)
Dec 03, 2012 | Toshiba Satellite A70 A75 M35 Series...
Have good wirelesssignal, but wont allow me to browse the internet?
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 01, 2012 | Toshiba Satellite A70 A75 M35 Series...
Hola, mi problema con mi pc es el siguiente.. tengo una toshiba satelite A70/75. y despues de unos minutos de estar funcionando bien repentinamente se apaga, vuelvo a encenderla y despues de unos minutos...
Desmonta y vuelve a colocar la bater?a, verifica que el cargador est? bien conectado y encendido, usualmente tiene una luz en la caja. Mantenlo conectado.
Se apaga cuando no se esta usando solamente? Comprueba las opciones de administracion de energ?a (power options) en el panel de control
Si el problema persiste y las luces de la computadora se apagan por completo puede ser el ventilador interno, se escucha algun ruido? Se sobrecalienta?
Apr 05, 2011 | Toshiba Satellite A70 A75 M35 Series...
Intermittent power supply, problems whit the jack, how I can change that? thanks, Ing. Elton Vargas
1) Check to make sure the problem isn't the cable going into the plug, from the AC adapter. (Charger)
A lot of times, where the wires meet the back of the plug, that goes into the laptop DC Power Jack, is bad.
The wires have a break from becoming stretched. Makes an intermittent contact.
Same thing for where the wires meet the charger body.
AC adapter plugged into power, unplugged from laptop, use a multimeter set to the DC voltage scale.
Use the alligator clip attachments for the probe leads, attach the probe lead's to the AC adapter's plug, and wiggle the wire, check for an intermittent break.
2) AC adapter (Charger) unplugged from laptop, Battery removed, see if you can wiggle the center pin of the jack.
You may find the entire DC Power Jack will move a little.
If the center pin does not move, but the entire body of the jack does, the jack may just need to be
resoldered to the motherboard. The solder connections may be cracked.
If the center pin moves, replace the jack.
To replace the DC Power Jack, or repair the solder connections,
1) Remove all power to the laptop. AC adapter and Battery.
2) Observe Anti-Static Precautions:
Buy and wear an ESD wrist strap. (Electro Static Discharge) Connect the alligator clip to a good ground source. I connect mine to the metal frame of an open, empty desktop computer case.
(You don't need an Anti-Static Mat)
The price of an ESD wrist strap is around $3 to $8. Found in a multitude of places.
Example,
http://www.costcentral.com/proddetail/Cables_Unlimited_Anti_Static_Wrist_Strap/ACC1400/10720671/froogle/
3) Completely disassemble the laptop down to the bare motherboard in your hand.
No Processor, Heatsink assembly, peripherals, nada.
TIPS:
A) You may wish to take photos, or make a video as you disassemble, for your first time. Also make notes.
After the first laptop the next one becomes easier.
(All of them follow a basic path when disassembling. Toshiba, HP, Acer, Gateway, you name it)
B) Use a multi-container for the various screws. Label each container for the area the screws came out of.
There may be 60 or more screws, and 12 different types of screws. Some look VERY similar to each other, but are NOT. DO NOT mix them up.
You can use a clean egg container in a pinch. Label each egg holder.
C) Take your time, use patience. Practice your soldering, de-soldering skills before working on the Toshiba's DC Power Jack, if you're rusty.
Use Desoldering Braid, and not a Desoldering Tool. (Solder S-ucker) The desoldering braid works MUCH better! (Also known as solder wick)
Pictorial, with details on how to disassemble the Toshiba Satellite A70, or A75 series of laptops,
http://www.irisvista.com/tech/laptops/ToshibaA75/satA75_1.htm
You can click on each photo to enlarge.
Page 2, and 3 icons are at the bottom.
(You are on Page 1.
Page 1::Page 2::Page 3 )
One source for a Toshiba Satellite A75-S209 DC Power Jack,
http://www.laptopjacks.com/view_part/For-Toshiba-Satellite-A75-S209-DC-Power-Jack-TS51625.html
Toshiba Satellite A70 series Service Manual, (Free)
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the line that begins with Satellite A10.
Scroll across to A70, and click on it.
This is a PDF file. May take up to 30 seconds before you see the first page.
May take additional time to fully download.
(Took me around 40 seconds before I saw the first page, with a medium speed DSL connection)
Regards,
joecoolvette
Oct 20, 2010 | Toshiba Satellite A75-S209 Notebook
Toshiba lcd series 6, 18 month old tv will not
consult manual for troubleshooting it could be that lamp in tv takes long time to cool down or that it is bad they usually last about 2-3 years depends on how you use your tv
Dec 31, 2009 | Toshiba Toahiba Satellite A70 A75 M35...
Satellite (A75S206) runs well from outlet but never from battery. Was told that mobo can't accept dc. Need new mobo. True?
hello loyd516,
Have you tried a new battery? They are much much cheaper, and a whole lot easier to replace than a motherboard.
Here are replacement batteries that I found searching with Google.
http://www.google.com/products?q=Satellite+A75-S206+battery&hl=en
According to Toshiba, there has been a battery recall for your specific model.
If that is the case I would definitely contact Toshiba support about it. Maybe you will get a free battery out of the deal. Who knows.
Here is the link and the list(your model is highlighted)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=1501060
Sony Battery Pack Recall Programs Document ID: 98082080 Posted Date: 10/10/06 Last Updated: 10/30/08 Operating System: N/A Category: Battery Distribution: Public
Applicable Models:
Satellite A70-S256, A70-S2561, A70-S2362, A70-S2491, A70-S2591, A70-S2482TD, A70-S2492ST, A70-S259, A70-S249, A75-S206, A75-S2091, A75-S2292, A75-S2291, A75-S229, A75-S209, A75-S2061, A75-S226, A75-S2261, A75-S276, A75-S1255, A75-S1254, A75-S1252, A75-S1253, A75-S1251, A75-S125, A75-S2131, A75-S213, A75-S2112, A75-S2293, A75-S2311, A75-S231, A75-S2111, A75-S211, A75-S2761, A75-S2762, M30X-S1592ST, M30X-S1593ST, M30X-S191TD, M30X-S181ST, M30X-S171ST, M30X-S221ST, M30X-S221TD, M35X-S149, M35X-S1491, M35X-S109, M35X-S309, M35X-S3091, M35X-S329, M35X-S1631, M35X-S163, M35X-S1143, M35X-S1142, M35X-S114, M35X-S3111, M35X-S311, M35X-S1611, M35X-S161, M35X-S111, M35X-S1492, M35X-S3291, M35X-S349, M35X-S3491, M35X-S3112, M35X-S1141, M50-S418TD, M50-S4182TD, M50-S5182TD, M50-S5181TD, M55-S135, M55-S325, M55-S3262, M55-S2253, M55-S3251, M55-S1351, M55-S1352, M55-S3511, M55-S351, M55-S3294, M55-S3293, M55-S3292, M55-S3291, M55-S329, M55 Series, M55-S2252, M55-S3512, M55-S3315, M55-S3314, M55-S321, M55-S3313, M55-S3312, M55-S3311, M55-S331, P30-S6362ST, P30-S6363ST, P35-S609, P35-S6091, P35-S6111, P35-S6311, P35-S631, P35-S6112, P35-S6053, P35-S6052, P35-S6051, P35-S605, P35-S611, P35-S6292, P35-S629, P35-S6291
Tecra A3, A3-S731, A3-S611, A3-S711, A5-S416, A5-S237, A5-S516, A5-S136, A5-S3291, A5-S3293, A5-S3292, A5-S329, A5-S118, A5, A5-S6215TD, A5-S116, S2, S2-S511TD
Jul 11, 2009 | Toshiba Computers & Internet
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
How do I replace a keyboard on a Toshiba Satellite A75-S211 laptop computer. I cant see any way to get it out. Also, the power button needs to be repositioned... same problem.
How to take apart Toshiba laptops. Instructions with pics ... 10 posts - Last post: 21 Mar 2006 Toshiba Satellite A70/A75 Toshiba Satellite P25 Toshiba Tecra A1 .... Toshiba Portege 3500 Tablet PC manual. How to remove and replace the ...
www.thinkcomputers.org/forum/showthread.php?t=632 - 76k -
Dec 31, 2008 | Toshiba Satellite A75-S211 Notebook
A70 recover disc in A35 Laptop? (Toshiba Satellite)
Recovery disks are model-specific, mainly because they have different devices and drivers. Setup drivers are downloadable, and copied to a CD at an Internet cafe.
May 16, 2008 | Toshiba Satellite A35-S159 Notebook
Computers & Internet Logo
62 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
