Question about Microwave Ovens
Please could you tell me if i have a reset button and where is this located
    Sergeant:
  • 192 Answers
If your microwave has stopped working it could be the automatic shutdown feature. This occurs when it has overheated. Just unplug it and open the door and wait for about 10 minutes for it to cool off and it should work fine.
Posted on Mar 27, 2011
Clock not working how do I reset it?
If rest of controls work here is how to set clock. Press clock button, enter correct time, It may ask for AM or PM and tell you to press a button to select. Then press either start or clock again. It may actually tell you which one to press to finish Depends on which model you have.
Mar 31, 2015 | GE Microwave Ovens
How to locate the kenmore microwave 721.85033111 fuse?
You must open it up. There is no reset. If fuse is blown then check the door switches.
Aug 30, 2014 | Kenmore Microwave Ovens
Locating reset button on my microwave
To my knowledge none have a reset button or circuit breaker. If the unit is total dead there will be (has to be) a fuse inside the unit.
Dec 06, 2012 | Whirlpool Gh5184xps Microwave Oven...
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    Help it just says reset and the buttons won't work .I took the panel off because it said or some one said it had a reset button , cant find it
    Microwave ovens don't generally have reset buttons.
    The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for about 5 minutes.
    If the keys still fail to respond, you have a bad keypad.
    There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
    You can find helpful exploded view diagrams and order parts by entering your full model number here.
    At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    Feel free to contact me
    directly (and please remind me of your full model number from the tag on the unit) for more information & help.
    Aug 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Sanyo microwave clock reset
    This is the generic instructions to set the clock. I have visited the sanyo site to aquire a owners manual with no success in locating one. This being said, here are the instructions.
    1. Unplug the unit for a minute then plug unit in.
    2. Press the clock (clock/timer) button once.
    3. Using the keypad, input the time you wish to set.
    4. Press the clock (clock/timer) button once.
    5. Press the stop/clear button, Time should remain.
    Hope this works, if not, let me know.
    Please take the time to give this solution a fix ya rating.
    clarkco
    Apr 12, 2009 | Sanyo Microwave Ovens
    Keypad Problems
    Sometimes a keypad may not work because the door switches are faulty. When the door switches are working correctly it will allow the keypad to operate. They tell the microwave that the door is closed and the unit is dafe to use.
    Many models have 3 door switches, it's wise to get all 3 replaced at once.
    Mar 27, 2009 | Samsung Microwave Ovens
    Mw8115ssw no power
    There's no reset button, only a a hard reset. Unplug the unit for a minute or so. Then plug it back in and see if ti works.
    A microwave can be dead for many reasons.
    It may be the fuse, which is usually located on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
    If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
    Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
    http://www.microwavedisplay.com/safety.txt
    http://www.microwavedisplay.com/disassembly.txt
    For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
    Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
    Jan 12, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
    Microwave display window shows locked!!!!
    Let us know if the hard reset does not fix it.
    There may be grease or soot on the control panel causing a lockup, and it may need circuit board cleaning / repair or a new keypad.
    Sep 01, 2008 | Microwave Ovens
    Microwave Ovens Logo
    85 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
