Question about Whirlpool 24 in. DU920PW Built-In Dishwasher
Dishwasher not draining and hoses are clear. - Whirlpool 24 in. DU920PW Built-In Dishwasher
  • 822 Answers
Can you hear the pump start up..?............
if not,.....pump blocked or duff.............
cheers
Posted on Mar 27, 2011
Why kenmore elite dishwasher will not drain?
If it is connected to a disposal remove the drain hose and check for a restricted area in the hose or disposal this is common also check the drain hose for kinks be sure to elevate the hose before the drain area. If the drain hose is clear and the drain is clear then you could have a bad drain pump in the dishwasher.Most problems are a restricted drain or hose
Jul 22, 2014 | Kenmore 24" Built-In Dishwasher with...
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
Clogged dishwasher?
disconnect the drain hose from the disposal or under the sink use a 5 or 6 foot long piece of plastic ice maker hose run it down the dishwasher drain hose till it want go any more also put one cup of bleach in the bottom of the dishwasher and let it set for at least 1 hour then turn the dishwasher on to drain and see if that cleared your clog
Mar 30, 2010 | Maytag 24 in. MDB5600A Jetclean II...
The GE Profile Dishwasher does not drain completely. The bottom drain shows no obvious clog and the screens are clear. The overflow drain in the back of the washers the only reason the dishwasher does not...
Uncouple the drain hose connection under the sink and use a wet/dry vacuum to **** out the drain hose and the stub on the sink drain plumbing to clear any possible clogs. There may be a blocked check valve near the pump that might have to be cleaned or replaced. Check the hose itself for any kinks or collapsed section. There might be a damaged drain impeller on the pump. Hope this helps!
Mar 11, 2010 | GE Profile PDW8400J Built-in Dishwasher
Dishwsher wont drain. never happened before. do not use dishwasher very often.
I would first check where the drain hose from the dishwasher connects to the drain stub under the sink. Remove the hose from under the sink and place it into a bucket. Close the dishwasher door and cancel the cycle to put the dishwasher in a drain cycle. Listen for the drain pump to activate. If water comes out of the hose check the stub where the hose connects under the sink with a screw driver to make sure the spout is clear of debris. If no water comes out of the hose, empty the dishwasher by hand using a plastic cup and when empty remove the hose at the pump under the dishwasher and check to see if there is any debris at this point. Make sure hose is clear from the dishwasher pump to the drain stub under the sink. You will need to place a towel or two on the floor as water left in the bottom of the dishwasher will come out when you remove the hoses. If still no water comes out you may have to disassemble the bump assembly. Not knowing what make and model you have I can't help you past this point.
I hope this is of some help.
Jan 25, 2010 | Dishwashers
Standing water in bottom of dishwasher
The first thing to try is to clear out debris from strainer area, you may need a Philips head screw driver for this. Clear out and then attempt to put the unit through its cycle.
The second thing I would try, is unattach drain hose from drain to sink, either blow in it or use a blower side of shop vac to force air into the hose. Reset dishwasher, and try again.
Not knowing how handy you are, you can pull the dishwasher out, please turn off circuit before doing so, also make sure you have towels handy. Unattached drain hose at base of drainage pump. Clear out hose and remove debris on bottom of pump. Reattach the hose and run through cycle..
If these do not work your issue is with a bad pump.
If there is a
Oct 13, 2009 | Dishwashers
Drainage problem
I had similar problem and rerouted the drain hose like papps54 said. I still had the condition and decided to pull out the drain hose completely to see if there was any debris trapped inside the hose. There was! I removed the hose from the machine completely, cleared out the debris, and let the hose soak in white vinegar overnight. In the meantime, I looked back up the drain outlet and found evidence of debris lodged in there as well. I didn't completely dismantle the dishwasher at this point but I did eventually clear it out as well as the drain filter located inside the dishwasher. After reassembling the drain hose and dishwasher, I cleaned it with baking soda for three nights and now it runs very well with no odors. Runs quieter as well.
Oct 10, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Not draining...hose clear
not really, it sounds like you have done all the basics,
Oct 09, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Standing Water in Dishwaaser
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 15, 2007 | GE 24 in. GSD4060JSS Built-in Dishwasher
Dishwasher
Sep 03, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Whirlpool 24 in. DU920PW Built-In Dishwasher Logo
53 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
