Question about RCA HD52W59 HDTV Projection Television
Will turn on and has good picture but no sound. if turn off and on several times sometimes sound will work.
Let me know if you find a solution. I have the same problem with my 52" Sony Bravia.
Posted on Mar 29, 2011
Hitachi 60FX20B
Shop repair and very unlikely to get fixed in home
Aug 28, 2012 | Hitachi 60FX20B 60" Rear Projection...
Sometimes sound but no picture
HHMMMMMMM. 12 error code is no fault code. This is very old set with a reputation of dumping it's memory setting for no particular reason. The board need is no longer available and if it was requires extensive setup. Very costly to repair. Replace the set. Very old. Tubes probably weakening.
Apr 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
LG LST-5100P set top box. Several times a day have
cap-grant, my friend has the same problem with set top box. When I phone maker I was told it is due to poor and weak signal. You must have 80% signal strength to maintain good picture. When signal strength dropped picture would freeze and had to be turned off at the power point to restart as nothing would work. So I guess what my experience says is you may need better aerial to boost signal and prevent dropout Leonard210
Oct 05, 2007 | Televison & Video
Panasonic screen problems
Then recently, these additional problems: 1. The picture cannot be restored by turning off then on. 2. Sometimes, several channels will have the same picture. 3. Sometimes several channels will have the same ghost-like picture. the above all problems are due to one that is weak signal. 1 check for antena or cable or satellite input is ok or wire might be defective due to old. 2 input socket is loose some where. 3 loose contact near tuner or some print break. 4 at last & final its tuner might be defective. hope this will help.
Oct 03, 2007 | Panasonic CT-36D32 36" TV
Please Help
call a tech your tv needs to to be repaired the problem is in the power supply and related circuit.good luck.
Apr 07, 2007 | Sony KV-27FV16 TV
No sound or picture now
The set may have shorted the horizontal out put transistor since it kept coming on sometimes. This could be cause by the driver transformer arcing causing a "spike" in voltage going to you horizoltal out put transistor. Stargazer
Mar 31, 2007 | Sony KV-27FV16 TV
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
TV solution
You may have a bad solder joint on the horizontal driver transformer or somewhere else in the set. I found this problem with this transformer several times. Stargazer
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
