Question about John Deere 22HP Hydrostatic 42" Riding Mower
Tractor seemed to have a dead battery. I replaced the battery yesterday with the correct one, however I still have no electrical components working. The battery is charged however Tractor will not turn over, lights will not work no juice what so ever.
    Master:
  • 354 Answers
Check the seat switch ,it has an auto kill seat switch that if a little out of adjustment then it wont do anything. When you messed with the battery area you probalby messed up the switch unvoluntarily. Check that Check the voltage(12 volts DC) to the switch(start)and back ,its there you can find it
Posted on Mar 27, 2011
    Problem Solver:
  • 13 Answers
If you have NO power showing on the dash then I would say it is the solinoid. Simple to change. Has 2 prongs and two bolts one of the bolts attach to the positive battery cable the other to the starter cable. It is secured to the mower body with 2 bolts also. Takes maybe 5 minutes to change. Make sure you disconnect the positive battery cable before working on your mower.
Posted on May 07, 2011
Tractor quit starting so I replace the battery. New battery worked fine for a few days but now tractor won't start.
Seems the first thing to do would be to check the battery. If it's dead, either you got a bad one, or it's not getting charged on the tractor so there will be trouble shootinig to do.
Jul 09, 2015 | Garden
2004 Jeep Grand Cherokee Laredo: electrical system starting to fail?? Hi! I hope someone can point me in the right direction :) I have a 2004 JGC-L that I LOVE, but the electrical system seems to be...
note that you never once said car can be driven? why?
job1, can you do job 1?
battery is going dead
if head lamps are dim its battery going dead, (not dash HEADs?)
notice is did not say battery was bad only discharged.
if engine starts is charge.battery lamp glowing.
i engine is dead, can crank it.
get a jump, call AAATOW
or find a loaned battery that is charged.
buy a battery charger and use it.
also cars can have phantom drains, as you sleep battery goes dead. (ask)
Mar 15, 2017 | 2004 Jeep Grand Cherokee
The battery in my JD lawn tractor was dead; it started and mowed several times with a jump start but eventually only the tractor would run while the mower would not engage. With a new battery installed,...
I suspect that the alternator/generator has gone bad, preventing the battery from chargine, or generating enough voltage to keep the electric pto on your mower engaged.
I think that it is located on the engine beneath the flywheel.
I hope this helps you.
Aug 03, 2011 | John Deere Garden
Batt dead jump start does not seem to charge
Sounds like a dead or shorted cell battery. Charging system is probably working but is showing overcharge since it is trying to charge a brick. Replace the battery and all should be well.
Jun 02, 2010 | Toro Lawn Mower With Toro Power Tools
Starting issue with John Deere 108 lawn tractor
If it seems as if the engine will crank maybe one or half turn then stop turning it maybe that the valve lash needs to be checked.When valve lash is more than .004 the compresion release will not be affective therefore the cylinders will have too much pressure built up to crank over.Set intake/exhaust valves at .004 when piston is 1/4 inch past top-dead-center on compression stroke.
May 21, 2010 | Garden
Tractor engine clicks but will not start need a solution
hopefull your battery is just dead a new battery should fix that problem you can try charge the battery may be okay depending on how long it has sat without bein used.... otehrwise it mat be your starter solinoid it ts the block with 2 poles on it that your positive battery cable goes to, it will most likely be a dead battery tho...
Regards
Brad:)
Sep 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John Deere 22HP Hydrostatic 42" Riding Mower Logo
580 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
