Question about Garden
Hi, I have a Karcher 730 pressure washer and it just suddenly stopped working. I have checked the fuses etc can you give me any idea's please. Rick
  • Brian Manuel Mar 27, 2011
    When you say just stopped working do you mean wouldn't start? Does it mean it starts but the water won't pump out or???
  • syl1951 Mar 27, 2011
    It wont start, water comes out of gun but no motor or pressure sounds
  • 569 Answers
The problem could be a pressure sensor that is operated by the water pressure connected to the inlet. This sensor switches the motor on only when there is sufficient water pressure on the inlet, and switches the motor off when there is insufficient pressure.
You will need to take the casing off the machine and find the sensor. It should be readily apparent as a switch attached to the incoming water supply which is operated by a small plunger. This can become corroded and stick, and will need to be removed and cleaned before the machine will operate again. If you are able to undertake this type of repair I suggest you lubricate the plunger with silicone grease when you re-assemble it.
I can't guarantee this is the problem but in my own experience it is worthwhile invetigating.
Posted on Mar 27, 2011
    Thanks I will give this a try
  • John Coleman Mar 27, 2011
    Not sure if this an electric model but I found a bad GFCI plug on a Karcher pressure washer that belongs to a friend of mine. The symptom was that the plug could not be reset. Since he was plugging into a GFCI protected outlet in his garage anyway, I simply replaced the GFCI plug with a standard plug.
I have a karcher k2.65m pressure washer which is leaking from inside after removing the outside covers i could not see how to separate the black plastic case to get into the pump etc any ideas ??
A picture might help.
You could always find the part and number here http://www.ereplacementparts.com/karcher-226m-16016020-pressure-washer-parts-c-33388_33389_33977.html Karcher 2 26M 16016020 Pressure Washer Parts
Aug 11, 2015 | Karcher Garden
Hi, My karcher 5.86 has suddenly stopped working. No power/ noise from washer when power is switched on. Fuse & source is obviously fine. Im going to obtain relevant torx screwdriver this week to open...
If its not the fuse in the plug it might be the on/off switch. I would check switch for continuity with a multimeter to rule it out first.
Feb 01, 2015 | Karcher Garden
Karcher pressure washer doesn't work
it;s normally a switch interrupter must replace with actual with for motor protection.
Aug 14, 2014 | Karcher Garden
I have a Karcher B402 Pressure Washer and when i plug it in and turn it on - nothing happens, not a sound. I have checked the fuse and the plug itself and this did not help. I contacted a service...
hi if you remove the torx screws that hold the electric box on and then bypas the on/off switch join wires together. and check the pressure swicth if it is the pressure switch you can bypass this but the machine wont shut down regards
Jan 19, 2010 | Karcher K2.26 Electric Power Washer
Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
Karcher prssure washer motor will not start
try going to www.karcher.com
then click on europe
the international,
then service and will then see spare parts, enter k620
tick the button for you are a engineer and you are on your machine
download.
micro switch might be at fault.
Mar 25, 2009 | Karcher Garden
Karcher washer went dead
Dear jimbocom,
The problem is that the spill valve got stuck. When the machine is working and the gun is closed, a valve( spill valve) moves with the accumilated pressure and switches the machine off. So what happened is that when the spill valve did its job, it found no water...and remained stuck. This leaving the machine in an off position. Service and lubrication to the spill valve must be done or completely replacing with a new spill valve. In my opinion you have no serious damage, but this job must be carried out by an expirienced technician.
Regards,
MG.
Oct 17, 2008 | Karcher K2.26 Electric Power Washer
Garden Logo
207 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
