Monitor problem actually,I am now using another monitor and i have no problem with my computer,i use it everyday in my cellphone repair shop. But I want my 17' mitsubishi flat crt monitor back,because i'm not comfortable with this 15' IBM crt monitor. I've already changed the horizontal transistor with the same value(C5587)because it is shorting but it doesn't work and theres no changes.so please please.. help me. i want to repair it my self.
    Genius:
  • Computers & ... Master
  • 1,056 Answers
To do an internal repair on a CRT is beyond my level of expertise.
I would leave repairs like that to those that do know. I've heard too many horror stories about what can happen if you don't know your way around the inside of a CRT.
Posted on Aug 20, 2008
Model M17ANA shuts off intermediatly Turns on ok but after a few seconds shuts off then back on again.
The issue you describe is a power supply gone bad. Actually it is a capacitor inside the PS that is now defective (it may be more than one). This seems to be a frequent problem with this particular monitor as I have personally had the same issue with one a owned.
Unfortunatly there is no good solution as there are basically only two options available to you.
1. Find an 'electronics /computer shop' that will remove the PS and repair it.
2. send the monitor to Star-Logic for repair.
The basic issue with either scenario is that the cost to repair may be more than the unit is actually worth. For instanse, you can purchase a new 20" LCD monitor for less than $90 form places like newegg.com.
I hope this helps you in some way.
Good Luck!
Oct 20, 2011 | Star Logic 17" LCD Monitor
MONITOR WORKS ON HEATING I have a HP vs15 lcd monitor . One day it stopped working , so i took it to a repair shop when the repair guy plugged the monitor in , it started working . After few days the...
When the bad caps (not completely gone but have high ESR) will start working when heated up, the ESR goes down, that is one of the trick I have been using for 30 years to locate bad caps by heting them with hair dryer.
I am surprised that 3 shops cannot find and fix the problem.
As you can see in my albums, most failure are due to bad caps. Can you poat the pictures of the board?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 12, 2011 | HP vs15 15"LCD Flat Panel Monitor
When I power up my computer the Gateway icon shows up but monitor stays black...I repeatedly hit the power button on the monitor until the screen finally shows up..and once its on it stays on all day until...
hi, these are exellent monitors. i have repaired and made good profit on these. there is about 8 capacitors on the main board that go bad. all are 470uf 25 volt. if you have good knowledge of soldering, you can perform this repair. even broken, these monitors go for 100 dollars on ebay. contact me back if you want more info on how to repair yourself.
Feb 08, 2010 | Gateway FPD2275W LCD Monitor
Internal Screen for LG Shine KE970
http://www.cellphone-repair-shop.com/products/lg-shine-ke970-cellphone-replacement-repair-parts_334.htm
Dec 13, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor always become blank screen
May be worth changing the monitor VGA cable
Aug 29, 2009 | Computers & Internet
No display on Windows Vista need driver?
Make sure that the settings in the new video card are actually set to run both monitors.I see this happen in my comp. repair shop quite often. It is a common mistake.
May 04, 2009 | Dell 1703FPT 17-inch Flat Panel Monitor
I dropped my phone yesterday and its screen is creacked and the actual lcd screen is also broken (i blieve) how much will it cost to replace on a Samsung mobile SGH-D520 model?
It will depend on where you are going to purchase your phone, if you'll purchase it in a store near you, it could be less higher than purchasing it online/in the internet. I t may also depend on your location.
It costs $99.95 dollars today in this sites:
Click the link to check it:
Cellphone Repair Shop
http://www.cellphone-repair-shop.com/products.php?cat=139
CellularDr.com:
http://www.cellulardr.com/products.php?cat=139...
I hope this could help...
Kindly rate this solution if it helps....thank you!
Sep 29, 2008 | Cell Phones
Monitor problem
The reason I had asked if you had tried a different monitor was to determine if it was the monitor or the computer that actually had the problem. That wasn't clear in the first question.
A computer that is having issues will cause the same symptoms you described.
Repairing CRT's is beyond my level of expertise. When I get into a situation like this, I would just replace the monitor. Sorry I couldn't have been more help.
I stopped using CRT's when the price of LCD's dropped.
Aug 04, 2008 | Mitsubishi Diamond Plus 73 17" CRT Monitor
Samsung Blackjack SGH-I607
You can get a Samsung Blackjack I607 Window Lens at www.cellphone-repair-shop.com
Here is the exact link for the part: http://www.cellphone-repair-shop.com/GH72-30531A.htm
You can also send your phone to them and they will perform the repair for you.
Here is the link for the Samsung Blackjack Cellphone repair service they offer:
http://www.cellphone-repair-shop.com/Housing-Lens-Cellphone-Repair.htm
Nov 15, 2007 | Samsung Blackjack SGH-I607 Smartphone
Computers & Internet Logo
398 people viewed this question
David Payne
David Payne
