Question about Amana NGD5400TQ Dryer
Gas dryer wont stay lit and I already tried replaceing the gas valve coils.
  • 4,349 Answers
Staying lit is a control issue, consider getting a qualified gas appliance guy to look at it, as home explosion is the next exposure.....
Posted on Mar 27, 2011
Have a samsung gas front load dryer not heating. we replaced the ignitor, but still wont stay lit
check the flame sensor and the gas valve and coils if it comes on then goes off ? more than likely the gas coils are not working properly u can check them with a multi meter but not for continuity check for olms rating will need ur schematic to see what is output for ur machine should be around 1200 olms I believe
Aug 08, 2014 | Samsung DV328AG Gas Dryer
Kenmore gas dryer 80series model 110.c72852101
if you hear the valve clicking but no gas the valve is bad.when the burner lights theres a probe that senses that it is lit and sends a microvoltage back to the controller to tell its lit.check to make sure all ground wires are grounded to a clean metal surface.
Oct 03, 2007 | Kenmore 74602 Gas Dryer
I have a DLG8388WM LG dryer i have changed the ignitor and the thermostat twice now it still will not stay lit.it lites then goes out within a second what else could it be.
It's common for a problem like this with a gas dryer to be cause by a bad coil on the gas valve.
This is often a simple and cheap repair, but I looked up you model number and I don't believe you can get a replacement coil on this model LG dryer so you would then need to replace the gas valve, part # 5221EL2002A
Aug 02, 2011 | LG DLG5932W Gas Dryer
Flame on gas dryer comes on but does not stay lit?
one of 3 issues,1st-the high limit or cycling thermostat could be weak and opening 2nd-the radient sensor eye can be bad or dirty,try cleaning first,both of these are on the burner tube side, 3rd-the gas valve boost and secondary coils could be weak and not holding the gas valve open to let the gas flow,these coils are on the gas valve top body
Jul 14, 2010 | Whirlpool Dryers
Gas burner won't stay lit
The heat sensor will need to be replaced
Apr 03, 2010 | Dryers
Roper Model RGS7648EQ3 (gas) that wont stay lit.
if the ignitor is liting for the first 15 to 30 minutes and then it will not lite again you have bad gas coils,when they are failing they will work until they get hot then they shut down,the coils are located on top of the gas valve,take out the two phillips screws,remove the cover,change out one coil at a time,pull off the wire connector and install the new coils
Mar 19, 2010 | Dryers
Gas dryer only stay's lit 15 min.
We have an answer and for only $12.99, we will let you know the details.
Jan 12, 2010 | Kenmore Dryers
Dryer does not stay lit
Gas valve coils. There are 2 on the top of the gas valve,about $20 for the set.
Remove the front panel and the drum to access the gas valve. Turn off the gas and unplug the dryer.
Pay attention to the coil orientation on the valve.
Oct 05, 2009 | Maytag Dryers
Electric egnitor for a gas dryer lights but does not stay on
Check the following-
Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jun 03, 2009 | GE Dryers
Maytag gas dryer wont stay hot
Check the exhaust to see if it is clogged. If not, you may need a pair of gas valve coils (not very hard.)
Replace the coils if you see the ignitor glow and shut off, without the gas valve opening up.
Mar 09, 2008 | Kenmore 63942 Dryer
Amana NGD5400TQ Dryer Logo
143 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
