Question about Skeetervac SV-3100 Mosquito Exterminator
KINDLY TELL ME ABOUT HSD 965 7L IT IS FET TRANSISTER OR NORMAL,ALSO TELLME EQUILENT OF THIS
    Master:
  • 354 Answers
Its as 9657 and it is a rectifier,Look it up at NTE.com and you will find about 8 crosses I tried to put them here but it was too lengthy. But choose the one that fits your needs volts & amps are about the only ones you need to worry about in this app.
Posted on Mar 27, 2011
Parking brake equilizer assembly
Care to tell me what you call the equalizer? Also without any info as to make, model and year very hard to answer any question.
Sep 04, 2016 | Cars & Trucks
Power went out no power to ILO-32hd
yes posible power supply is defective if fuse blow then could be defective fet transisters as well shorting best way is to replace complete board if it was surge from electicity.
Mar 02, 2012 | iLO 3200 32 in. LCD Television
511-cpu fan not detected
check fan if fan ok then check hard ware near fan jack sarfaysamandit fet or transister
if fix your problem click yes for vote
Dec 27, 2010 | Compaq (283983-001) Motherboard
Every time i turn my truck off the equilizer resets
If you radio doesnt save the stations either when you turn off the truck then it could be your wiring.. For example; Normally you have two power wires.. A red one(Accessory).. and a yellow one(Battery). The yellow one is like the memory.. and the red one powers the stereo when you turn the key. Try switching yours over.. See if that helps. Easily confused and you wouldnt really notice the difference.
Jan 14, 2010 | JVC KD-R200 Car CD/ MP3 Player
Amp won't power up,anymore! Even with new parts installed,removed
Hiya, dont have a diag either what you will have to try and is compare the left channel with the right. There will be 2 driver transistors (also likely on heatsink) close to the outputs. Check which driver drives which output on the left, then match it on the right. Those same drivers could very well also be a problem on the right as they often go with the outputs. There is a possibilty they have smoked again. See here to test FETS
http://www.4qdtec.com/mostest.html
Basically the left will match the right but not similar locations but definitely by track joins.
Also check the power resistors at the output. Often also go.
Hope that helps
Jul 15, 2009 | Car Audio & Video
Philips 105E
I have philips monitor 107E there is a supply problem i want to repair it. I need circiut diagram for repair.
May 28, 2009 | Philips 107E61 17" CRT Monitor
Question about your asnwer to my issue.
I would replace both because the falting of HV reg can cause the FET transister to fail also!
I hope this answers your question!
have a good day!
Dec 13, 2008 | Mitsubishi WS-65809 65" Rear Projection...
15" CRT Monitor samsung totally dead
Dear munu007 good morning this is viswanath
Don't worry I can salove UR problem
1.First U can check any physical damage in power supply (220/400v)Main capacitor,
2.And also check LOT It's OK Than Remove H O/p Transister, check SMPS output voltages ,voltages are currect That means SMPS is OK.Check Boosting FET IRF630(Q402)Change it New One,and also change the IC604 7805 Regulator.
Finally change LOT.
check any dry points (SMPS&Hori.)
Oct 08, 2008 | Samsung SyncMaster 551 15" CRT Monitor
Skeetervac SV-3100 Mosquito Exterminator Logo
195 people viewed this question
Top Skeetervac Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Skeetervac Pool and Spa Expert? Answer questions, earn points and help others
