Question about Schwinn Cycling
How do you shift - Schwinn Cycling
    Brigadier General:
  • 8,546 Answers
Google "how to shift a bicycle gears" and find many vids and text-splanations.
Posted on Mar 27, 2011
Will not come out of park. Button stuck
Automatic Transmission Shift Lock Control Description and Operation.
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
• The automatic transmission shift lock solenoid (serviced as the automatic transmission shift lock actuator), as well as the body control module (BCM) and the engine control module (ECM). The shift lock solenoid is located within the floor shift control assembly with vehicles equipped with floor shift.
• The BCM controls the voltage supply circuit of the shift lock control solenoid. The following conditions must be met before the BCM will supply voltage to the shift lock control solenoid.
The BCM controls the voltage to the shift lock control solenoid through the shift lock control solenoid controlled voltage circuit. The following conditions must be met before the BCM will supply voltage to the shift lock solenoid:
• The ignition is in the ON position.
• The ECM sends an input via GMLAN serial data to the BCM indicating the transmission is in the PARK position.
• The BCM determines the brake pedal is applied according the brake pedal position.
Since the shift lock control solenoid is permanently grounded, the BCM supplies voltage to the automatic transmission shift lock control solenoid, mechanically unlocking the shift lever allowing the driver to move the shift lever out of the PARK position as the solenoid energizes. When the brake pedal is not applied, the BCM turns the control voltage output of the shift lock control solenoid OFF, de-energizing the shift lock control solenoid. The de-energized solenoid mechanically locks the shift lever in the PARK position.
During remote start operation, the BCM will de-energize the shift lock control circuit, locking the shift lever in the PARK position.
Circuit/System Description
The body control module (BCM) controls the shift lock solenoid by providing battery voltage to the shift lock control solenoid. The BCM utilizes a smart driver to control the voltage supplied to the shift lock solenoid. The smart driver monitors the voltage and current flow of the control circuit.
Diagnostic Aids
• Use a scan tool to verify there are no brake pedal position sensor and/or transmission internal mode switch (IMS) DTCs set that could cause the BCM not to provide battery voltage to the A/T shift lock solenoid.
• If the automatic transmission shift lock control circuit is shorted to battery positive voltage, the A/T shift lock solenoid will be inoperative. The vehicle will shift out of PARK without depressing the brake pedal.
Your best bet is have it towed to a repair shop !
Feb 03, 2016 | 2008 Saturn Aura
Tip
WORD 2003 Shortcuts
All Caps Ctrl+Shift+A
Annotation Alt+Ctrl+M
App Maximize Alt+F10
App Restore Alt+F5
Apply Heading1 Alt+Ctrl+1
Apply Heading2 Alt+Ctrl+2
Apply Heading3 Alt+Ctrl+3
Apply List Bullet Ctrl+Shift+L
Auto Format Alt+Ctrl+K
Auto Text F3
Auto Text Alt+Ctrl+V
Bold Ctrl+B
Bold Ctrl+Shift+B
Bookmark Ctrl+Shift+F5
Browse Next Ctrl+Page Down
Browse Prev Ctrl+Page Up
Browse Sel Alt+Ctrl+Home
Cancel Esc
Center Para Ctrl+E
Change Case Shift+F3
Char Left Left
Char Left Extend Shift+Left
Char Right Right
Char Right Extend Shift+Right
Clear Del
Close or Exit Alt+F4
Close Pane Alt+Shift+C
Column Break Ctrl+Shift+Return
Column Select Ctrl+Shift+F8
Copy Ctrl+C
Copy Ctrl+Insert
Copy Format Ctrl+Shift+C
Copy Text Shift+F2
Create Auto Text Alt+F3
Customize Add Menu Shortcut Alt+Ctrl+=
Customize Keyboard Shortcut Alt+Ctrl+Num +
Customize Remove Menu Shortcut Alt+Ctrl+-
Cut Ctrl+X
Cut Shift+Del
Date Field Alt+Shift+D
Delete Back Word Ctrl+Backspace
Delete Word Ctrl+Del
Distribute Para Ctrl+Shift+J
Do Field Click Alt+Shift+F9
Doc Close Ctrl+W
Doc Close Ctrl+F4
Doc Maximize Ctrl+F10
Doc Move Ctrl+F7
Doc Restore Ctrl+F5
Doc Size Ctrl+F8
Doc Split Alt+Ctrl+S
Double Underline Ctrl+Shift+D
End of Column Alt+Page Down
End of Column Alt+Shift+Page Down
End of Doc Extend Ctrl+Shift+End
End of Document Ctrl+End
End of Line End
End of Line Extend Shift+End
End of Row Alt+End
End of Row Alt+Shift+End
End of Window Alt+Ctrl+Page Down
End of Window Extend Alt+Ctrl+Shift+Page Down
Endnote Now Alt+Ctrl+D
Extend Selection F8
Field Chars Ctrl+F9
Field Codes Alt+F9
Find Ctrl+F
Font Ctrl+D
Font Ctrl+Shift+F
Font Size Select Ctrl+Shift+P
Footnote Now Alt+Ctrl+F
Formatting Properties Shift+F1
Go Back Shift+F5
Go Back Alt+Ctrl+Z
Go To Ctrl+G
Go To F5
Grow Font Ctrl+Shift+.
Grow Font One Point Ctrl+]
Hanging Indent Ctrl+T
Header Footer Link Alt+Shift+R
Help F1
HHC Alt+Ctrl+F7
Hidden Ctrl+Shift+H
Hyperlink Ctrl+K
Indent Ctrl+M
Italic Ctrl+I
Italic Ctrl+Shift+I
Justify Para Ctrl+J
Left Para Ctrl+L
Line Down Down
Line Down Extend Shift+Down
Line Up Up
Line Up Extend Shift+Up
List Num Field Alt+Ctrl+L
Lock Fields Ctrl+3
Lock Fields Ctrl+F11
Macro Alt+F8
Mail Merge Check Alt+Shift+K
Mail Merge Edit Data Source Alt+Shift+E
Mail Merge to Doc Alt+Shift+N
Mail Merge to Printer Alt+Shift+M
Mark Citation Alt+Shift+I
Mark Index Entry Alt+Shift+X
Mark Table of Contents Entry Alt+Shift+O
Menu Mode F10
Merge Field Alt+Shift+F
Microsoft Script Editor Alt+Shift+F11
Microsoft System Info Alt+Ctrl+F1
Move Text F2
New Default Ctrl+N
Next Field F11
Next Field Alt+F1
Next Misspelling Alt+F7
Next Object Alt+Down
Next Window Ctrl+F6
Next Window Alt+F6
Normal Alt+Ctrl+N
Normal Style Ctrl+Shift+N
Normal Style Alt+Shift+Clear (Num 5)
Open Ctrl+O
Open Ctrl+F12
Open Alt+Ctrl+F2
Open or Close Up Para Ctrl+0
Other Pane F6
Other Pane Shift+F6
Outline Alt+Ctrl+O
Outline Collapse Alt+Shift+-
Outline Collapse Alt+Shift+Num -
Outline Demote Alt+Shift+Right
Outline Expand Alt+Shift+=
Outline Expand Alt+Shift+Num +
Outline Move Down Alt+Shift+Down
Outline Move Up Alt+Shift+Up
Outline Promote Alt+Shift+Left
Outline Show First Line Alt+Shift+L
Page Alt+Ctrl+P
Page Break Ctrl+Return
Page Down Page Down
Page Down Extend Shift+Page Down
Page Field Alt+Shift+P
Page Up Page Up
Page Up Extend Shift+Page Up
Para Down Ctrl+Down
Para Down Extend Ctrl+Shift+Down
Para Up Ctrl+Up
Para Up Extend Ctrl+Shift+Up
Paste Ctrl+V
Paste Insert
Paste Format Ctrl+Shift+V
Prev Field Shift+F11
Prev Field Alt+Shift+F1
Prev Object Alt+Up
Prev Window Ctrl+Shift+F6
Prev Window Alt+Shift+F6
Print Ctrl+P
Print Ctrl+Shift+F12
Print Preview Ctrl+F2
Print Preview Alt+Ctrl+I
Proofing F7
Redo Alt+Shift+Backspace
Redo or Repeat Ctrl+Y
Redo or Repeat F4
Redo or Repeat Alt+Return
Repeat Find Shift+F4
Repeat Find Alt+Ctrl+Y
Replace Ctrl+H
Research Lookup Ctrl+Shift+O
Reset Char Ctrl+Space
Reset Char Ctrl+Shift+Z
Reset Para Ctrl+Q
Revision Marks Toggle Ctrl+Shift+E
Right Para Ctrl+R
Save Ctrl+S
Save Shift+F12
Save Alt+Shift+F2
Save As F12
Select All Ctrl+A
Select All Ctrl+Clear (Num 5)
Select All Ctrl+Num 5
Select Table Alt+Clear (Num 5)
Show All Ctrl+Shift+8
Show All Headings Alt+Shift+A
Show Heading1 Alt+Shift+1
Show Heading2 Alt+Shift+2
Show Heading3 Alt+Shift+3
Show Heading4 Alt+Shift+4
Show Heading5 Alt+Shift+5
Show Heading6 Alt+Shift+6
Show Heading7 Alt+Shift+7
Show Heading8 Alt+Shift+8
Show Heading9 Alt+Shift+9
Shrink Font Ctrl+Shift+,
Shrink Font One Point Ctrl+[
Shrink Selection Shift+F8
Small Caps Ctrl+Shift+K
Space Para1 (single spacing) Ctrl+1
Space Para15 (one-and-a-half line spacing) Ctrl+5
Space Para2 (double spacing) Ctrl+2
Spike Ctrl+Shift+F3
Spike Ctrl+F3
Start of Column Alt+Page Up
Start of Column Alt+Shift+Page Up
Start of Doc Extend Ctrl+Shift+Home
Start of Document Ctrl+Home
Start of Line Home
Start of Line Extend Shift+Home
Start of Row Alt+Home
Start of Row Alt+Shift+Home
Start of Window Alt+Ctrl+Page Up
Start of Window Extend Alt+Ctrl+Shift+Page Up
Style Ctrl+Shift+S
Style Separator Alt+Ctrl+Return
Subscript Ctrl+=
Superscript Ctrl+Shift+=
Symbol Font Ctrl+Shift+Q
Task Pane Ctrl+F1
Thesaurus RR Shift+F7
Time Field Alt+Shift+T
Toggle Character Code Alt+X
Toggle Field Display Shift+F9
Toggle Master Subdocs Ctrl+\
Toggle XMLTag View Ctrl+Shift+X
Translate Pane Alt+Shift+F7
Un Hang Ctrl+Shift+T
Un Indent Ctrl+Shift+M
Underline Ctrl+U
Underline Ctrl+Shift+U
Undo Ctrl+Z
Undo Alt+Backspace
Unlink Fields Ctrl+6
Unlink Fields Ctrl+Shift+F9
Unlock Fields Ctrl+4
Unlock Fields Ctrl+Shift+F11
Update Auto Format Alt+Ctrl+U
Update Fields F9
Update Fields Alt+Shift+U
Update Source Ctrl+Shift+F7
VBCode Alt+F11
Web Go Back Alt+Left
Web Go Forward Alt+Right
Word Count List Ctrl+Shift+G
Word Count Recount Ctrl+Shift+R
Word Left Ctrl+Left
Word Left Extend Ctrl+Shift+Left
Word Right Ctrl+Right
Word Right Extend Ctrl+Shift+Right
Word Underline Ctrl+Shift+W
on Dec 03, 2009 | Computers & Internet
1996 plymouth breeze transmission wont go into 2nd Gear
Have you check fluid level ? Is your check engine light on ? You have a bad shift solenoid inside the transmission ,more then likely . Have codes checked ,you mite have P0700 + code
  • P0750 - Shift Solenoid A
  • P0751 - Shift Solenoid A Performance or Stuck Off
  • P0752 - Shift Solenoid A Stuck On
  • P0753 - Shift Solenoid A Electrical
  • P0754 - 1-2 Shift Solenoid Intermittent
  • P0755 - Shift Solenoid B
  • P0756 - Shift Solenoid B Performance or Stuck Off
  • P0757 - Shift Solenoid B Stuck On
  • P0758 - Shift Solenoid B Electrical
  • P0761 - Shift Solenoid C Performance or Stuck Off
  • Nov 08, 2015 | Plymouth Cars & Trucks
    2001 Pontiac Bonneville won't shift out of park
    Automatic Transmission Shift Lock Control System
    The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the ignition is ON. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
    The automatic transmission shift lock control solenoid
    The automatic transmission shift lock control switch
    The brake to shift relay
    The rear integration module (RIM)
    With the ignition in the ON position, battery positive voltage is supplied to the brake to shift relay coil. When the RIM energizes the brake to shift relay, the brake to shift relay switch contacts close suppling battery voltage to the automatic transmission shift lock control switch. The circuit continues through the normally --closed switch to the automatic transmission shift lock control solenoid. The permanently grounded solenoid is energized. This locks the shift linkage in the PARK position. When the driver presses the brake pedal, the contacts in the automatic transmission shift lock control switch open. This causes the automatic transmission shift lock control solenoid to release. This allows the shift lever to move from the PARK position.
    Shift Lever Does Not Move with Brake Pedal Depressed ?
    Jun 30, 2015 | Pontiac Cars & Trucks
    Changing gears
    Hi, Dave and the usual suspects are:
    1. Clutch not disengaging.
    2. Bent shift shaft.
    3. Shift fork bent or seized.
    4. Gear seized on the shaft.
    5. Gear positioning lever binding.
    6. Shift return spring weak or broken.
    7. Shift return spring pin loose
    8. Shift mechanism arm spring is broken.
    9. Shift mechanism arm is broken.
    10. Shift drum is broken.
    For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
    http://www.r3-forums.com/forum/522-drivetrain/14065-shifting-issues-thread-problems-your-shifts.html
    Gear shifting problem
    OEM parts for Yamaha
    Gears stuck up shifting
    My Motorcycle can shift up or down anymore Is the problem bent shift lever
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
    Mar 09, 2014 | Yamaha Motorcycles
    How difficult is it to change the shifter cable
    Take the rubber boot off the gear shift inside the vehicle and lift it up, exposing the area where the gear shift and the transmission connect.
    Look for the shift cable and the shifting arm. A single bolt and nut connect the shift cable and shift arm.
    Twist the nut connecting the gear shift and the transmission. Use a socket wrench and remove the gear shift. Use an open-end wrench to loosen the nut holding the shift cable and the shift arm together.
    Slide off the sleeve on the shift cable and loosen the shift cable at the other end with an open-end wrench. Both ends of the shifting cable attach to the shifting arm in different locations.
    5
    Hitch the new shift cable to the 2 anchor points on the shift arm using the same bolts and nuts. Reconnect the gear shift to the transmission and push the rubber boot back into place around the gear shift inside the car.
    6
    Test the functionality of the shifting cable by moving the gear shift in and out of gear.
    Jan 03, 2013 | Saturn Cars & Trucks
    How to install a transmission shift cable in a 2000 Cavalier
      • 1 Take the rubber boot off the gear shift inside the vehicle and lift it up, exposing the area where the gear shift and the transmission connect.
      • 2 Look for the shift cable and the shifting arm. A single bolt and nut connect the shift cable and shift arm.
      • 3 Twist the nut connecting the gear shift and the transmission. Use a socket wrench and remove the gear shift. Use an open-end wrench to loosen the nut holding the shift cable and the shift arm together.
      • 4 Slide off the sleeve on the shift cable and loosen the shift cable at the other end with an open-end wrench. Both ends of the shifting cable attach to the shifting arm in different locations.
      • 5 Hitch the new shift cable to the 2 anchor points on the shift arm using the same bolts and nuts. Reconnect the gear shift to the transmission and push the rubber boot back into place around the gear shift inside the car.
      • 6 Test the functionality of the shifting cable by moving the gear shift in and out of gear.
    Sep 23, 2011 | Chevrolet Cavalier Cars & Trucks
    My transmission will not go into park. how do i fix that
    1. Install the shift cable end of the shift cable to the transmission shift lever stud ball.
    2. Install the retainer to the shift cable and transmission bracket.
    3. Feed the shift cable through the floor panel.
    4. Lower the vehicle.
    5. Adjustment Procedure
      1. Ensure that the shift cable is not restricted.
      2. Place the shift lever into the NEUTRAL position.
      3. Position the shift cable to assume a natural routing. The shift cable must be free to move 20.0 mm (0.80 inch) axially during the adjustment under adjustment spring loads.
      4. Pull the cable end completely forward and release it. (When the cable is pulled completely forward and released, the adjustment spring will position the cable to its most rearward position.) Notice: Do not pull the shift lever ball stud forward of the transmission shift lever ball stud during installation. Pulling the shift cable end forward of the transmission shift lever ball stud before installing the shift cable end to the transmission shift lever ball stud will result in a poor adjustment.
      5. Connect the end of the shift cable to the transmission shift lever stud ball.
      6. Press the locking tab IN in order to secure the shift cable to the transmission bracket.
    Oct 13, 2009 | 1984 AMC American Motors Eagle
    3d frog frenzy 1
    I cant find anything which lets you skip or select levels, sorry.
    But this is the best I could find:
    Press [Ctrl] + [Shift] + L during game play Easy Win Press [Ctrl] + [Shift] + T during game play. Freezes The Time Press [Ctrl] + [Shift] + I during game play. Gives You Unlimited Lives, Makes It So You Can't Run Into Traffic Press [Ctrl] + [Shift] + P during game play. Pauses The Game
    Press [Ctrl] + [Shift] + L during game play Easy Win Press [Ctrl] + [Shift] + T during game play. Freezes The Time Press [Ctrl] + [Shift] + I during game play. Gives You Unlimited Lives, Makes It So You Can't Run Into Traffic Press [Ctrl] + [Shift] + P during game play. Pauses The Game Press [Ctrl] + [Shift] + L during game play Easy Win Press [Ctrl] + [Shift] + T during game play. Freezes The Time Press [Ctrl] + [Shift] + I during game play. Gives You Unlimited Lives, Makes It So You Can't Run Into Traffic Press [Ctrl] + [Shift] + P during game play. Pauses The Game
    Press [Ctrl] + [Shift] + L during game play Easy Win Press [Ctrl] + [Shift] + T during game play. Freezes The Time Press [Ctrl] + [Shift] + I during game play. Gives You Unlimited Lives, Makes It So You Can't Run Into Traffic Press [Ctrl] + [Shift] + P during game play. Pauses The Game Press [Ctrl] + [Shift] + L during game play Easy Win Press [Ctrl] + [Shift] + T during game play. Freezes The Time Press [Ctrl] + [Shift] + I during game play. Gives You Unlimited Lives, Makes It So You Can't Run Into Traffic Press [Ctrl] + [Shift] + P during game play. Pauses The Game EASY WIN: Press [Ctrl] + [Shift] + L during game play.
    FREEZES THE TIME: Press [Ctrl] + [Shift] + T during game play.
    UNLIMITED LIVES: Press [Ctrl] + [Shift] + I during game play.
    PAUSES THE GAME: Press [Ctrl] + [Shift] + P during game play.
    I hope they help
    Mike
    May 14, 2009 | Cosmi 3D Frog Frenzy for Windows
    2002 Kia Sedona XL suddenly downshifts
    What was the codes exactly that Auto Zone gave you.??? it might just be a simple wire harness that may have gone loose since you did some work on the speed sensor.
    Here are the trouble codes for your car.  Good Luck and get the car scanned again for a more define information.
    P0751 Shift Solenoid A Performance or Stuck Off
    P0752 Shift Solenoid A Stuck On
    P0753 Shift Solenoid A Electrical
    P0754 Shift Solenoid A Intermittent
    P0755 Shift Solenoid B Malfunction
    P0756 Shift Solenoid B Performance or Stuck Off
    P0757 Shift Solenoid B Stuck On
    P0758 Shift Solenoid B Electrical
    P0759 Shift Solenoid B Intermittent
    P0760 Shift Solenoid C Malfunction
    P0761 Shift Solenoid C Performance or Stuck Off
    P0762 Shift Solenoid C Stuck On
    P0763 Shift Solenoid C Electrical
    P0764 Shift Solenoid C Intermittent
    P0765 Shift Solenoid D Malfunction
    P0766 Shift Solenoid D Performance or Stuck Off
    P0767 Shift Solenoid D Stuck On
    P0768 Shift Solenoid D Electrical
    P0769 Shift Solenoid D Intermittent
    P0770 Shift Solenoid E Malfunction
    P0771 Shift Solenoid E Performance or Stuck Off
    P0772 Shift Solenoid E Stuck On
    P0773 Shift Solenoid E Electrical
    P0774 Shift Solenoid E Intermittent
    P0780 Shift Malfunction
    May 05, 2009 | 2002 Kia Sedona
    Cycling Logo
    Top Schwinn Cycling Experts
    Michial Gueffroy
    Jim Goldsmith
    Jim Goldsmith
    michael
    michael
    Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
