Question about Karcher Garden
I have a karcher 7.85 jet washer that has been unused for a while and now fails to work. I have checked plug fuse and replaced the on off switch and condenser as advised previously however there is no life from the motor at all. When the lance trigger is pressed water does flow however this is minimal.
5 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: I can use my Karcher K3 jet wash as long as i hold trigger down
Most pressure washers have ball lock type fittings on the hose connections. What happens is the little steel balls get a bit of corrosion and do not lock the male fitting properly with the female coupling. Load up the fitting with some Oil or WD 40. Then connect and disconnect the fitting several times to losen up the balls and springs. Should the spring in the coupling break you will get the exact symptom your describing.
If the OIL / WD 40 does not do the trick then you may have to change out the quick disconnect coupling.
Kelly
Posted on Apr 18, 2010
  • 92 Answers
SOURCE: Karcher pressure washer won't start
Dear ralph_birtwi,
Most pressure washers when their gun is released, the machine stops automaticaly. This is done ny means of a control valve. When the gun is closed...pressure is built and the control valve moves and switches a micro switch off. In your case the micro switch is still closed in off position. Now this happens if a machine is left and stored with pressure in it., This control valve could get jammed and leaving the micro switch in off position. It could also stay in off position by sticking, due to incorrect chemical.
So the control valve or even called spill valve, must be renewed.
Sometimes a little lubrication with the right type of silicon grease will get the control valve working again. This job is sometimes delicate and better done by a qualified technician.
Regards,
fulltech.
Posted on Apr 12, 2009
  • 92 Answers
SOURCE: I have an old kew pressure washer and when I pull
Dear dennis_partr,
In general all pressure washers have a control valve. This is sometimes refered to as the Spill Valve. When the trigger is pulled, the spill valve is in normal position. When the trigger is released, the spill valve compresses to let water circulate from its bottom part. If when the trigger is pulled and the bottom part of the spill valve does not close, then water keeps on circulating and hence no pressure. In this case change the spill valve with a new one. Also there could be a fault in the sucktion valves. If the sucktion vaves do not close, also water keeps on circulating. One also can examine the delivery valves. If these are not closing, then water is being sucked while delivering. Hence no pressure. Another cause but very rare, is that the swash plate that is pushing the pistons got loose. The electric motor will be turning, but the pistons stay in the same position.
I mentioned many causes, but usualy it is the spill valve. If with a new spill valve, there is still no pressure....then you must tackle the sucktion and then the delivery valves.
I wish to add that I assume that you have the correct lance and correct nozzel size. A worn out nozzel, will result in low prssure too.
Regards,
Fulltech.
Posted on Apr 22, 2009
  • 56 Answers
SOURCE: as soon as I turn on my karcher electric power it sprays full for
You can get a new trigger gun from here:
link
Posted on Dec 23, 2009
NT48/1 professional karcher not working. Changed fuse in the plug yet still not working. Replaced the filter. Still not working. Could be the motor not working?
Is the motor running? If not, did you check the starting capacitor?
Did you check motor windings for continuity? Did the pump seize? Is electricity reaching the unit - wire ok?
Nov 16, 2015 | Karcher Garden
Hi, My karcher 5.86 has suddenly stopped working. No power/ noise from washer when power is switched on. Fuse & source is obviously fine. Im going to obtain relevant torx screwdriver this week to open...
If its not the fuse in the plug it might be the on/off switch. I would check switch for continuity with a multimeter to rule it out first.
Feb 01, 2015 | Karcher Garden
Where s the fuse karcher k2.180
I doubt there's an internal fuse other than in the plug fitted if it has one. Karcher don't expect you to dismantle anything to get at a fuse but if you go online to the main Karcher website check out the parts list this may help identify anything. If it doesn't start and there's no humming noise like the motors struggling to turn then you need an appliance dealer or engineer to check the electrical side. Be careful what you do, water and electricity are a dangerous combination. Check the likely cost of professional help though, it may be more than a replacement washer?
Oct 20, 2014 | Garden
Karcher pressure washer doesn't work
it;s normally a switch interrupter must replace with actual with for motor protection.
Aug 14, 2014 | Karcher Garden
Water coming out of detergent pipe from top for karcher 3030 b jet wash
DISCONNECT HYDRO OR WITH ENGINE NOT RUNNING DISCONNECT SPARK PLUG THEN RE-LEAVE WATER PRESSURE BEFORE SERVICING the detergent pipe plugs into a pipe on the pump, under which is a spring and ball bearing (stuck open, debris) WEAR YOUR SAFETY GLASSES
Apr 01, 2014 | Karcher Garden
My karcher 310 will not switch on and fuse is good
you need to check you nozzle for blockage or wrong size you could be throwing the overload switch on the motor
Oct 10, 2012 | Karcher Garden
Karcher 4.91 checked fuse that is ok but no power
Check and see if you are getting power to the on/off swith. These switches have been known to go bad. Also, check the Ground fault breaker in the plug. Let me know how you make out.
Jul 26, 2011 | Karcher K2.26 Electric Power Washer
Karcher K2.36 Pressure Washer I've just fired up my Karcher for the first time since last year and the motor started running fine, I then switched on the tap to allow the water through and the motor cut...
The water must be switched on, and seen to be running freely from the nozzle for a few seconds before switching on the power - suggest you check the fuse in the plug, and then try the above.
Apr 17, 2010 | Karcher K2.26 Electric Power Washer
I started working with the Karcher KB4040 pressure washer and all was well for 1-2mins, then it sputered a bit and all power died. All hoses were still attached properly, it hadn't blown a fuse in my house...
if the water is in anyway impeded, like kink in hose the unit turns off and goes into protection mode. That it it shuts down for a pewriod of time depending on how hot it may have got.
When its rested try it again ensuring you definitely have water flow.If the solenoid has failed it costs about !60-200 to fix as they replace all seals regardless
Jul 22, 2009 | Karcher 1750 psi Electric Pressure Washer
Karcher washer went dead
Dear jimbocom,
The problem is that the spill valve got stuck. When the machine is working and the gun is closed, a valve( spill valve) moves with the accumilated pressure and switches the machine off. So what happened is that when the spill valve did its job, it found no water...and remained stuck. This leaving the machine in an off position. Service and lubrication to the spill valve must be done or completely replacing with a new spill valve. In my opinion you have no serious damage, but this job must be carried out by an expirienced technician.
Regards,
MG.
Oct 17, 2008 | Karcher K2.26 Electric Power Washer
Garden Logo
485 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
