Question about Espressione CA4865 Supremma Super Automatic CoffeeBeverage System Silver
Espressione CA4865 Supremma Super Automatic machine will not transfer water into the system, but rather leaks out the bottom! What can be done to fix this?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 156 Answers
I have same unit. Produced by Solac in Spain. No longer sold in U.S. Solac won't help.
I had leak out bottom of machine. Removed brew group and tightened phillips head towards front which was loose. This stopped the leak on mine. Hope it works for you.
Posted on Mar 21, 2016
3 Suggested Answers
guru_fixya
  • 944 Answers
SOURCE: We understand that your problem
This valve will differ based on the DeLonghi models
If the machine is still under warranty you may void the warranty any time you take it apart.
When water heats it expands which creates more pressure in the boiler. This pressure may allow some water to sneak by.This valve is located behind the shower screen and keeps the water from being forced out of the boiler as it heats and the water expands. When you want to make coffee and turn the pump on the valve will stay closed until enough pressure is built up to push it open allowing the water to flow. When you turn the pump off, the pressure reduces and the spring on the valve pushes it closed. When the steam button is pushed the boiler heats up to a higher temperature and the pressure in the boiler increases putting more strain on the valve.So this valve may be loose or some time may be defective one.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 01, 2010
espressonist
  • 1711 Answers
SOURCE: water leaks from the bottom of the machine...
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Posted on Sep 27, 2010
Delonghi magnifica leaking water
First I'm not a Delonghi tech. But I have worked on similar table top "Super Automatic" machines. You should call your vendor for service as there is no customer serviceable parts in this machine.
*** the following is for information only. ***
* If your leaking at or under the water tank then check for crack or you may be missing a rubber seal, o-ring, or washer. Replace the whole tank as a unit.
* If your leaking into the dregs or drip tray then there is a problem with the brewing system. Call for service. They may need to replace the brew valve or PC board.
* If your leaking at the bottom, drip tray, or side only when the pump buzzes (pumping water) then there is a cracked or disconnected hose line or fitting. Call for service and replace.
* If your leaking when the steam wand is in use then there is a similar problem with the 2nd pump system. Call for service and replace.
* If your leaking liquid coffee into the dregs tray or drip tray. Then you have a worn or missing group gasket(s). Call for service and replace. (you may find gasket kits from Amazon.com or online.)
* Final; Leaking water and electrical equipment is not a good idea. Best to be safe. Unplug and call for service.
Aloha, ukeboy57
Feb 04, 2018 | DeLonghi Coffee Makers & Espresso Machines
My Jura Ena 3 is leaking out the bottom.
First I'm not a JURA tech. But I have worked on similar table top "Super Automatic" machines. You should call your vendor for service as there is no customer serviceable parts in this machine.
Aloha, ukeboy57
PS: I've found the following video of a look inside the Jura;
https://www.bing.com/videos/search?q=jura+ena+3+leak&&view=detail&mid=741EFC1C3BEF3B6D9A49741EFC1C3BEF3B6D9A49&&FORM=VRDGAR
Feb 03, 2018 | Coffee Makers & Espresso Machines
Leaking xp7240
There are many places for the water to leak out the bottom on those. You are going to need to remove the covers and have a look. Is the water clean or is it part of your brew? In order of most likely to least likely
1) Barista seal at bottom of brew chamber
2) Distributor
3) Tank seal
4) Tamping piston seals
5) Flexible hose or connection
6) Hydraulic Ram
7) Relief valve on end of pump
You are not going to figure it out with the covers on and you will have great difficulty running it with covers off to be certain where it is coming from but that is what most of those issues is going to require.
Jul 14, 2014 | Krups XP7230 Compact Super Automatic...
How to fix leaking water tank removable?
Most likely the rubber o-ring at the bottom of the machine is defective and needs to be replaced with a new one.
May 03, 2014 | Krups Super Automatic XP 9000 Espresso...
I have a Krups XP 7230 Expresso Machine. Water is...
I have a xp7240 which I believe has the same housing as yours. I can remove the bean container by pulling off the grind selector knob and removing the only screw.
Then remove the scute for the cleaning tablets. Then remove the two screws that were covered by the scute. Remove the water tank. Under the tank remove the two screws.
Then the trick where everyone seems to look for: The facade of aluminum can be moved off. Set the machine on the floor and pull hard upwards at the facade. This comes off (pull hard!) and four screw are uncovered. Remove them and pull then back housing of the machine (remove first the containers/drawers). Now the inner parts are freely accessible. Take photos and remove the components from top till bottom to get to the bad parts that need replacement. The valve that leaks is on the bottom of the machine (will cost you a lot of time to get to it. Don't know the replacement price.) Good luck!
May 16, 2010 | Krups XP7230 Compact Super Automatic...
Water flows, but there is no heat!
Hi
There might be a reset button on the top of the boiler or a fuse that is blown. You could check you element if you have an ohms meter. It should read 12. to 16. ohms if its a 110v machine or 50 to 56 ohms if its 220v. Unplug the machine before doing any work inside.
Jun 20, 2009 | Espressione XP1 Espresso Machine
Espressione Retro Clogged?
I had the same problem with mine. unfortunatly you will need a special tool to remove the diffuser head. It' a very small spanner wrench that turns the special screw. I was able to make a spanner out of a screwdriver, but I'm a toolmaker by trade. Your best bet is to have it done by a qualified repair service. Also, if you damage the screw, it's imposible to get parts from them.
Nov 22, 2007 | Espressione Retro 1385 Espresso Machine
Espressione CA4865 Supremma Super Automatic CoffeeBeverage System Silver Logo
108 people viewed this question
Top Espressione Coffee Makers & Espresso Machines Experts
Douglas Dinnebeil
Douglas Dinnebeil
Tom Chichester
Are you an Espressione Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
