Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
What can I use to run through my clogged hose on a Kenmore Progressive 21514 canister vacuum? A hanger doesnt make it as it seems the clog is towards the middle
    Master:
  • 354 Answers
I use a pool cue ,but a broom handle or any handle will do or just a nice straight stick about 3 or 4 ft. long.
Posted on Mar 27, 2011
Testimonial: "Thanks, lol I decided on a curtain rod I had!"
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Disconnecting the hose and holding the opposite end to the intake can sometimes **** the clog back they way it came more easily than trying to push it all the way through the other way.
Posted on Nov 08, 2012
    New Friend:
  • 4 Answers
If you access to an air compressor blow the hose out, a high powered nozzel on a garden hose to force out debri, or if you have pets that shed groom them more often
Posted on Dec 18, 2012
Why would the vacuum have no suction?
if the motor is running it could be a belt a clog or a hole somewhere else in the hose
Feb 16, 2012 | Kenmore 23612 Progressive PowerMate Bagged...
My Kenmore Progressive Canister turns on but there is no suction
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Aug 22, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
Kenmore Progressive with direct drive model 116.36923502 stopped picking up debris and empted it into the floor and is there something you need to do to switch from floor to using the hose. It does not...
sounds like you have a clog in your hose, full bag, or dirty filters. take the bag door off and feel inside at the bottom for suction or air movement. if you have suction there chances are its a clog in the hose. You can use a coat hanger or something similar to reach into the hose just be careful not to puncture the hose. First just try turning the unit on and stretching the hose as far as you can. try to feel for a clog and try to free it with the hose stretched.
Jan 22, 2010 | Kenmore 31913 Progressive Direct Drive...
I have kenmore progressive and it is clogs is there a way to unclog it
The easiest way we unclog this machine is to take another canister vacuum and use its' hose to put on the hose of your machine then switch it on and **** the clog out of your machine. Works great.
Dec 01, 2009 | Kenmore Vacuums
My Kenmore Progressive is making a noise that sounds as if something is blocking the suction. I have checked the tubes and can't find any obvious blockages
Have you changed out the bag? Checked the air filters? When you run it and hold your hand over the hose opening, do you feel suction?
Check the head for blockages, you said the tubes are good, so check the hose, if no obstructions there, open the canister and check the bag, if it's full change it, if not, pull it out and check the filter that's under the bag, if it's not clogged re-run the above steps but this time look for possible vacuum leaks. Let me know if this helps.
Oct 19, 2009 | Kenmore 25512/ 25513 Progressive Canister...
No suction
If the motor is running and is not full of dirt, and the hose is not plugged, the canister must be cracked or open somehow.
May 08, 2009 | Kenmore 22812 Bagged Canister Vacuum
Flapping noise behind where hose wraps up/suction but junk sticki
you have a clog in the hose take the screws out of the hose retainer and take a yard stick and run it into the hose to get the clog out
Jan 24, 2009 | Kenmore 31913 Progressive Direct Drive...
I have the upright kenmore progressive with direct drive and the filter canister stops bringing in air and picking up when hose is put into vaccum, when you remove hose and use as an attachment it starts...
Check the hose after the brushes. With this problem there is normally a clog in between where you disconnect the hose (to use attachment) and the brushes that clean the carpet.
Dec 21, 2008 | Kenmore 31913 Progressive Direct Drive...
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
1,003 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
