Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
Mccullogh model# 600032-15 fuel tank replacement how hard is this
  • McCulloch Master
  • 2,239 Answers
There is certainly an amount of work to do, the starter cover, the left hand side cover complete, the anti vib springs, the fuel hoses, the tank then pulls out from the left hand side of the saw once these components are removed.
Posted on Mar 27, 2011
Need bar adjustment part
Hi Anonymous.
Fixya is not a retail area, so there will not be parts here. If you use a search engine to put in your particular make and model of saw along with 'replacement parts ' i.e. 'McCullogh 3250 16" Replacement Parts' with your saw model subbed for the McCullogh part, there are plenty of places selling parts, usually with exploded views of the saw so you can trace down which exact part it is that you need.
If the whole assembly is bent, and not just the peg, please consider taking the saw to a professional. A chainsaw is not something you ever want to operate with damaged parts. Terrifying injury or death are real possibilities of a sharp chain, with or without saw attached, jumping off in an unexpected direction. The peg may not be a big deal to fix, but, lacking the fine detail on my end, I just want to underscore that this is something to take a lot of care and caution with.
Good Luck
D
Dec 10, 2015 | Garden
Where in Corpus Christi can I get my McCullough 14" electric chainsaw oil tank replaced?
You can't. McCullogh was bought out by a division of Singer (yes, the sewing machine parent company). I still buy parts for mine on-line. It will require some sleuthing, but you will find a source.
Oct 22, 2015 | Electric Garden
How do I repair the fuel pump
It is in the fuel tank, and you don fix it, you replace it. You have to drop the tank to replace it.
If you need further help, reach me via phone at https://www.6ya.com/expert/tom_1788908372a4836f
Jun 02, 2014 | 1999 Jeep Grand Cherokee
HARD TO START THEN ACTS LIKE ITS STARVING FOR GAS. ALREADY REPLACED PLUGS, FULE FILTER AIR CLEANER.
Had problem like this check the graumet for fuel line pick up tube that goes in fuel tank if it is deteriorated losses vacuum check inside fuel lines put clear fuel filter if it dont stay above half full the line could be restricted if your not using no ethanol fuel and always premium non ethanol fuel . Other will make fuel lines i.d. shrink take pick up tube out of tank see if any black stuff on bottom of tank if so replace all lines pump clean tank rebuild carb buy only premium no ethanol gas
Jul 02, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What is correct Fuel mixture for a McCullogh MiniMax 6?
The recommended fuel to oil ration is 40:1. That means 100 ml oil to 4 litres of fuel.
Jun 30, 2011 | Garden
Trying to locate fuel filter to replace
It is located below your seating area under the vehicle.It is mounted on the fuel line above the rear end of the fuel tank. Its pretty hard to locate it in this model.
Apr 04, 2011 | 2002 Nissan Xterra
My McCulloch chainsaw 3200 internal fuel line in
Try your friendly neighborhood chainsaw seller/mechanic. Take a piece of the old hose with you.
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
Oct 13, 2009 | Garden
Cant figure out where fuel lines go on mccullogh chain saw
Fuel lines: one comes from the tank...has a filter in side the tank...runs up to the intake of the carb... you can tell by hooking up the lines to the carb, and put one into a gas supply... press the prime bulb... if it pulls gas, thats the one to hook into the tank...if not it 's the other... there should only be two lines a fuel supply and a return pressure line. Clean the air filter while you've got it apart....
k
Jul 01, 2009 | McCulloch 26cc Gas Blower Mcb3208
Fuel leak
hi jaspunkin
check the fuel line,tubes and the integrity of the fuel tank,
regards savumihai71
Nov 21, 2008 | McCulloch Garden
Fuel Pump Replacement
On a 1996 Jeep Cherokee you have to pull the fuel tank.I am not sure on your model. It is not very hard to do. The tank on my vehicle is plastic and is held on by straps. Just put a jack under the tank and loosen the straps. As you lower the tank you can get to the connections to unplug the wiring. Once you have it on the ground, the fuel pump has a retaining ring that holds it in. It will unscrew and the fuel pump will come out.
Oct 04, 2008 | 1993 Jeep Cherokee Country
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
