Question about IBM 3500 Typewriter
My Ibm typewriter will not return - IBM 3500 Typewriter
  • IBM Master
  • 3,594 Answers
I'm if the return key dose nothing or it just spaces up or it only returns part way. More info.
DickyO
Posted on Apr 04, 2011
HOW DO I CLEAR ALL TABS ON IBM WHEELWRITER 3500 BY LEXMARK TYPEWRITER
Tab all the way to the right, hold down the tab clear key, press return.
DickyO
Sep 19, 2014 | IBM Wheelwriter 3500 By Lexmark Electric...
Ibm wheelwriter 3 troubleshoot
If it growls on return and changes the margins spray some WD40 on the silver shaft that the carrier slides on. If it thumps on return the carrier motor gear needs replaced.
DickyO
Aug 29, 2012 | IBM Wheelwriter 3 Series Ii Typewriter...
IBM Lexmark typewriter carriage return won't return to left position
Hi:
Open the top cover and locate the shiny rod that the carrier moves back and forth across. Use some WD-40 on a rag to clean it well the apply a light coating of it to the entire shaft.
Jun 21, 2012 | IBM Wheelwriter 1500 by Lexmark Electronic...
I have a Ibm wheel writer selective typewriter that does not space or return. but it will tab.
There are Wheelwriter or Selectric Typewriters it's one or the other and the spacing is completely different.
DickyO
Jun 19, 2011 | IBM Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
IBM CORRECTING SELECTRIC II TYPEWRITER
Is the key stuck in the down position? If you pull the key off you should see a spring underneath. Maybe out of position or damaged.
Aug 10, 2008 | IBM 3500 Typewriter
Reset Tabs on an old IBM Wheelwriter 6 Typewriter ?
Tab to the tab you want to clear press tab clear (t clr) lower left side of the keyboard, to clear all tab all the way to the rt. press and hold tab clear and touch return.
DickyO
Mar 24, 2008 | IBM 3500 Typewriter
Margin Problems
You are in auto return. Press code and R
This should doit
DickyO
Mar 10, 2008 | IBM Wheelwriter 30 Typewriter
IBM wheelwriter 6 Series II
try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Oct 31, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
IBM 3500 Typewriter Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
