What cables do I need? I used a vga to vga cable and received a picture on the tv but no sound.
    Sergeant:
    Champion:
  • 218 Answers
If you are trying to hook your computer to your tv you need an hdmi cable if your tv or computre has no hdmi port than you need to use a 1/4 to 1/4 in cable running from your headphone jack on the computer to a 1/4 input on your tv as the vga cable you are using does not carry audio.
Posted on Mar 27, 2011
I hooked up my laptop C300 to my tv. I get picture but, no sound. Do I need a sound card? If so, which one?
It all depends on how you connected to the TV. There are 3 common ways, using HDMI, DVI or a VGA cable. Of the 3, only HDMI transmits sound from the computer to the TV. If you are using DVI or VGA, you will need to connect a cable from the audio out (headphone) jack on the computer to audio in on the TV. If you are actually using a HDMI cable, it is probably a setting somewhere.
Jan 22, 2017 | Computers & Internet
When I connect my PC to my TV using a VGA audio video cable, I get a picture but no sound
If you are only using VGA, you will not have sound. VGA is only video. The only cable I know (except for AV cable) that has sound and video is HDMI
Dec 28, 2012 | Toshiba 37RV525R 37 in. LCD HDTV
I have a V-zon digital tv that I can't get the sound to work when I am on the internet or in other words I don't know how to hook the cable box to the tv to get the sound. The tv can only get the pictures...
When you are using the TV as a monitor (VGA) you need to connect the audio out from the computer to the VGA audio in of the TV. (Otherwise connect computer speakers to the computer (if a desktop) and use those speakers.) The audio out for a desktop is usually marked by a green 3.5 mm jack. The VGA audio in will be a 3.5 mm jack as well; so an audio patch cable (3.5 mm M/M) is needed. (The green port is normal for computer with Line-In, Line-Out and Microphone ports. If the computer has an option for surround sound, check the manual to make sure which port you should use for Line-Out.)
If your cable box has an internet connection (like some DVRs, blu-ray players and TVs), the HDMI cable will carry the audio without separating it out unless you feed the signal through a home theater system (or audio receiver) for a surround sound system.
Which model TV do you have? That will help track down where the VGA audio in port will be. Some models have the VGA audio in next to the VGA port. On other TVs, it is near other audio input and output jacks. Usually it is clearly labeled but you may need a magnifying glass to read the text. (Sometimes it will be labeled VGA/DVI audio in.)
I hope this helps.
(I have one TV in my household where the DVI audio in uses 2 RCA jacks, even with a computer as the source (so there may be some TVs with that for the VGA source as well). For that situation, I use a 3.5 mm to 2 RCA (M/M/M) cable or an adapter - either 2 RCA (F/F) to 3.5 mm (M) at the computer with an RCA audio cable or 2 RCA (M/M) to 3.5 mm (F) at the TV with a 3.5 mm audio patch cable.)
Apr 01, 2011 | Televison & Video
I bought a Sanyo DP46849, lcd tv, 1080. and I'm getting a fuzzy picture. It helps when i put my cable receiver on hd channels, but even my blu-ray looks better on my 720 plasma???? any suggestions, I...
I gather from the information given that you are getting the proper signal from the cable receiver but there may be a settings issue with the LCD TV. If the 720 plasma is giving good performance then it has to be settings on the lcd .
I would review the instruction manual to see if you have over look something that is a proper cable select ( hdmi or vga).
If you have selected vga you will not get a clear picture in that mode. HDMI is High definition which works properly with 1080P mode. If you have further issue the manufacturer troubleshooting or Knowledge base will give answers also.
1. check your HDMI cables make sure they are properly seated in the input ports
squarely not at an angle.
2. If you are using a cable receiver check the connection there. Make sure you have the proper cable for your receiver to the TV
3.check channel to see if you TV is selected for channel 3 or 4 as recommend in the instruction manual
4. check the V-chip setup it may be blocking certain channels
5. check you picture modes each channel can have desire picture setup modes.
6. If you are using rca cables you may not get the proper picture as you would with HDMI cable that are specially designed for High Definition TV
Mar 13, 2010 | Sanyo DP46849 46 in. HDTV
How do i use my computer and pc to tv at the same time
Connect the computer to the TV
1. Through an S-Video cable or
2. A VGA cable,
depending on the input option of you TV, and the output options of your computer.
Then from Graphic properties, extend your desktop to a TV if S-Video, or to a second monitor if VGA cable. For older TVs resolution on computer screen may have to be set to 800x600.
Hope it helps.
Sep 24, 2009 | Acer Computers & Internet
Hi I have a samsung 50inch plasma my asus laptop is connected with a vga cable I have picture but no sound through tv just laptop. Can someone help do I need another cable?
you need to have RCA cables to get sound. I use my labtop the same way. VGA cable is only for the picture RCA cables are for sounds. you can by them anywhere.
Jun 10, 2009 | LG 42LC2D 42 in. LCD HDTV
Not to computer saavy so please keep it simple. I have a Sony Vaio VGC RA840G desktop with 5.1 surround sound. Also have a Samsung LN46A850 S1F HDTV. Also a home theater system. This is hooked up to cable...
From the looks of the TV manual you have everything right, so it's very odd you're running into this problem.
Have you tried swapping through the sources? I find with one of the TVs we have on display at work that any time I'm having some troubles with it I will change the source from PC to something else, then back to PC.
If that doesn't work then I'd suggest you try reseting the sound settings back to factory default. The instructions are on page 45 of the TV manual. From the TV menu select "Sound", then "Sound Reset", then either "Reset All" or "Reset Sound Mode". I would suggest reseting all.
Last option would be to try using the headphone jack in the side of the TV, though this is a last resort kind of thing since you would have to unplug it every time you wanted to use the cable box.
Hope this helps :)
Apr 16, 2009 | Sony Computers & Internet
Hooking up from hd receiver to hdtv ready projection tv. what cables do I use? vga or rca component red, blue, green and sync white/black? My hd receiver has output of :hdmi, rca component, s-video ,...
This particular television puts you in a tough bind - you can use Component cables in AV-1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot (AV-4), but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot - if the picture doesn't roll, you're in business.
Once again, I doubt that your model # is a 60pp9202, since that model doesn't have a VGA or DVI slot. If the picture rolls after trying the above, you will need to purchase a HDMI-to-DVI-D cable and hook it up from the HDMI output of your HD receiver to the DVI slot (that looks like a VGA slot) on the back of your Philips or Magnavox.
-Tha Mp3 Doctor
-Tha Mp3 Doctor
Mar 07, 2009 | Philips 60PP9202 60" Rear Projection...
I wanna hook my laptop to my tv. used a vga cable and get picture but no sound
You also need an audio cable to go along with the VGA cable. You will need a 3.5mm audio jack cable. Plug one side into the headphone jack of your laptop, the other side into the 3.5mm audio jack that is right beside the VGA connector.
Jan 29, 2009 | Televison & Video
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
