Question about Toshiba 72HM195 72" HDTV
Toshiba 72HM195 blue light blinks thre time the yellow light come on and blue light blinks three times and the yellow light goes off and sequebce repeats.
  • Toshiba Master
  • 19,396 Answers
Hi.
Rather than the number of blinks you need to count the blinking time intervals.
If the yellow is staying on 3 seconds, and the blue blinks last half second, then the problem is the lamp cage door. In that case:
  • Disconnect power cord for ten minutes.
  • If problem persists, disconnect again and check lamp cage door.
  • Replace door switch (must be done by technically trained person).
I uploaded here the full error code troubleshooting for this model. Click on the link, then click on the picture again to enlarge. Alternatively print out the error codes page.
Regards.
Ginko.
Posted on Mar 27, 2011
Dlp TV model no. 72HM195 blue light blinks three times repeating. fan comes on. replace color wheel , ...?
Those blinks are fault indications. If you wish to get more details, visit the site linked here. http://electronicshelponline.blogspot.com/
Blinking code details of many brand TVs are given in detail.
Jan 16, 2017 | Televison & Video
How do i determine if my ballast board or capacitor is bad in my toshiba hd tv model no 57HM167?
The chances of the ballast failing are small on this model. Count how many times the Yellow light flashes before it pauses. Then google 57HM167 and the amount of blinks. ie " 57HM167 Yellow light flashes 3 times" That will tell you what you need to know. You can also post it here and we can help. I suspect you have a stuck fan(the fans are monitored to see if they are spinning. If not, they will not allow the TV to start up). Or you have the cover for the lamp not installed all the way. There is a switch that the lamp cover activates and the the TV will not turn on without it secured.
Apr 02, 2015 | Toshiba Televison & Video
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Toshiba 56HM66. Picture freezes, then picture goes out. The blue light stays on and the yellow light blinks 15 times, 15 times, 15 times and then the picture comes back. The voice never goes out. This...
this is a digital board problem. Part# 75004946.
has to be data transferred from dmd board. options menu in service mode. scroll down to dmd>digital transfer. press left arrow on remote to initiate. when says ok exit on remote an shut off................. Meder's Tv
May 01, 2010 | Toshiba 56HM66 56" Projection HDTV
My Toshiba 72HM195 72 in. HDTV powers on but no picture comes up, but it has sound and wants to turn back on after turning power off
Won't shut off ah, sounds like a Toyota, you can't stop those either, if you are getting flashing green or red lights your lamp is burnt out, time to replace.
May 01, 2010 | Toshiba 72HM195 72" HDTV
TV will not turn on Yellow power ind. Light blinks three times tried to reset no luck took to repair shop diagnosed with bad SEIN module internet post suggest bypassing Sein module but I don't know where...
TV will not turn on Yellow power ind. Light blinks three times...
cc46e8cd-c98d-439a-bc78-207613c68534.png 76bab8a5-e5dc-4d5d-9d56-589661460254.png
Jan 13, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
My toshiba 42HL167 won't turn on
Try this fix from the toshiba website. Q. I have no picture or sound, but I have a blinking power light?
Models: LCD-2007
REF:FAQLCD00090
1. Try resetting the TV by disconnecting the power for 30 seconds and then plugging it back in. If this has no
effect, try moving the TV to a different power outlet that has been tested and is known to be good.
2. If your unit continues to fail, please contact our Customer Solutions Department at 1-800-631-3811 Monday
through Friday, from 8 a.m. until 7 pm CST for a local Toshiba Authorize Service Station Hope this helps you with your problem.
Feb 27, 2009 | Toshiba 42HL167 42 in. LCD Television
Toshiba 72HM195 72" HDTV Logo
366 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
