Question about HP Compaq nx5000 Notebook
Not working I am not sure what the problem is, but its when i turn the laptop on it doesnt work. the only thing that works is the power light it goes on and then thats it, the light stays on, but the monitor and laptop do not do anything. the monitor stays plain black and thats it. i tried taking out the battery, and putting it back in, but it didnt do anything. my problem sounds similar as well. it's an hp/compaq nx5000. when i try to power on, a green light flashes at the bulls eye symbol, i hear the fan for a couple of seconds and then everything stops. i have tried it with the battery in place, with the battery not in use but still no go. i can try and try and have nothing happen and then, like today, it'll fire up perfectly the first time. yes, i've jiggled the power cord, unplugged/replugged, etc but this is driving me bonkers!! any/all assistance much appreciated.
  • 2 more comments
  • adneris_m07 Aug 26, 2008
    When I try to turn on my laptop I can hear the fan and the bullseye light comes on but nothing happens. I tried to unplug the charger I've wiggled the wires and nothing....
  • Anonymous Sep 07, 2008
    The screen/monitor on the laptop does not light well enough to read it. It has flickered for weeks and I have been able to fix it by simply adjusting the angle of the cover. No luck with that now!
  • drew Mar 27, 2009
    same problem, mine starts first time the next day for some reason, iv jiggled everything possible and am going bonkers too, its nearly met the concrete driveway today,lol
  • drew May 11, 2010
    iv wiggled everything, and even will start the next day without power plugged in so power chord does not sound rite to me
Hey guys
solution is very simple, your power socket in notebook is not working properly, either get it resolder
by professional, or you want to start by yourself then push your power conector cable up and down
at end of it where it enter power socket and while doing this click power on button, your laptop will start, i have same prob in my nx5000 , i am using this by same method since last year
Posted on Sep 28, 2008
  • 7 Answers
THE COMMON PROBLEMS WITH THIS LAPTOP IS THE PROCESSOR WARPS FROM THE HEAT SING TO TIGHT, THEY WAS DISIGNED BAD.. COMMON PROBLEMS 1. WHEN YOU POWER UP COMES ON NO SCREEN NO SOUND THAN POWERS DOWN. 2. POWERS UP NO SCREEN NO SOUND. TRY THIS REMOVE KEYBOARD INSPECT PROCESSOR BOTTOM SIDE FOR CRACKS OR WARPED...IN ANY CASE REPLACE PROCESSOR THAT WILL FIX YOUR PROBLEM..REMEMBER THE PROCESS MUST BE THE SAME OR ELSE THE BIOS WONT SEE IT...GOOD LUCK
Posted on Oct 22, 2008
    Scholar:
  • 133 Answers
Remove the ram clean it put it back yor problem will solvs
Posted on Aug 04, 2008
My Laptop doesnt turn on how do i fix this...help!
Already answered today - take battery out and try.
Mar 16, 2015 | HP Compaq 2510p Notebook PC
I turn on my Laptop and the fan will spin and the Hard disk light will turn on as well as the power light (obviously) But the Hard drive doesnt spin up and the screen stays blank no lights no nothing i...
Remove all of the ram, turn the laptop on if it does not beep you have a bad motherboard. If it beeps replace the memory and remove the hard drive turn on the laptop and see if it posts. If it posts without the hard drive then the hard drive is bad. Otherwise it is probably still a bad motherboard.
Apr 24, 2011 | Computers & Internet
My toshiba satellite laptop hasnt been turning on for ages and charging doesnt work, its not even charging! What do I do!?
Hi friend, this could be due to bad battery. Just remove the battery and connect the power to the laptop and see whether it works. If it works without battery, then replace the battery.
Thanks,
Shiva
Dec 19, 2010 | Toshiba Computers & Internet
As i turn on my laptop everything works except there is no display . before it happans sometime and when it turned on it works well. as i put it for 1-2 months after that it get started with display but...
Hi ,
The best possible thing which you can do right now is to check few more things ....As the problem doesnt have much to do on.
Try this::
1>Try to Notebook adapter to a different power outlet.
2.>If still doesnt work you can try to connect an external display us.
(if the external display doesnt work might be other issue but if the display works you have take it to the shop where they can work on this.
Hope This will work.
God bless you.
Sep 29, 2010 | Compaq Presario M2000 Notebook
My fujitsu A3130 screen doesnt turn on. the only thing it does is that the 3 lights in the top right corner turn on and off.
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 15, 2010 | Fujitsu LifeBook A3130 Notebook
My Toshiba laptop will not turn on.
this could be a number of things. the first thing to check would be the lcd inverter. to check this simply hold a flash light up to the screen while it is powered on and see if you can see anything. If not the next thing to check would be RAM. turn off your laptop and remove 1 stick at a time, or replace with a known good stick of RAM. If one stick is bad it will cause your video to not work. If replacing the RAM doesnt work then it is probably your video card which is part of the motherboard
Aug 20, 2009 | Toshiba Satellite A60 Notebook
HP Pavillion dv9005us screen stays dark
Lets start with the power, make sure it is charging by looking at the ring on the side that lights up when the power cable is plugged in. If this is on, then make sure the light on the front of the laptop is on. If it is charging and it is detecing power(2 lights will be lit) then you are okay with power. If the lights are not turning on, then it might be your charger. This is rare, but its worth a try. Get your hands on another identical one. Make sure the Watts line up or else you might blow something out. If it is not your charger, then it is probably an internal part such as the power plug or the motherboard. In either case, unless you really know what you are doing, then you would simply need to replace these. Before you order a new one online, keep reading.
[skip this part if your power is not working]
Pull out one stick of RAM, then try to start up. If this doesnt work, then try the other stick(put the first one back in). If that doesnt work, then try the hard drive. If this doesnt work, then try the wireless card an any other attachable devices(that connect directly to the motherboard). If this does not work, then the problem is in your motherboard and you will probably need to replace it.
[If your power is not working and/or it looks like you need a new motherboard, read this]
Be sure to contact HP first, they are doing a recall or as they call it a "service enhancement" to some of their malfunctioning laptops that are having motherboard issues. You might want to research what the service enhancement covers first. This will be important when dealing with the representative. Also make sure you try a lot of things with fixing it, even if it seems rediculous such as cleaning out the fan. The more it looks like you tried to fix it, the more likely they are to service your laptop under the 'service enhancement'.
Here is more info on the service enhancement. Be sure to read as much of it as possible. Sometimes the representative on the phone will try to say it isnt covered beucase it doesnt match the symptoms exactly. Try to show them as much as possible that it does fall under one of the defects listed and they will most likely fix it. This is a one time shot though, be sure you dont screw it up!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&dlc=en&cc=us&product=3439691&lang=en
Aug 03, 2009 | HP Pavilion dv9005us Notebook
Took cmos battery out
The battery is dead... please replace it.
this keeps all your system settings for start up.
Apr 06, 2009 | Toshiba Satellite L305D-S5904 Laptop
Not working
press f8 when you hear the beep, that should bring up a menu that will allow you to choose your boot up, select safe mode, that will bring up windows in safe mode, this is just to see if it will do anything if now reinstall windows, if that does not work you have a video card problem, if it is still under warranty get it fixed
Nov 04, 2007 | Toshiba Satellite 2400-S251 Notebook
I CANNOT OPEN!!!
Hi, Try running you laptop with the battery and the AC adapter. If by plugging in your adapter there is no light indicator likewise or no powering up, then presumably there is a problem with the power supply circuitry in the motherboard. Normally the laptop should work with just the adapter, just the battery or both the battery and the adapter. If it will not perhaps your best bet is to seek professional repair service since this would require opening the motherboard. In most instances, this involves an smc fusible link, regulator transistors or even just cold solder or loose connections. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Sep 24, 2007 | Acer Aspire 5500 5570-2609 Laptop
HP Compaq nx5000 Notebook Logo
263 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
