Question about Refrigerators
Process tube on a compressor should that be the low side to check the pressure? I put in a tap in valve stem on process tube pressure is obout 90 psig why is the presure so high.
    Scholar:
  • 116 Answers
Hi what brand and model, and it sounds like the compressor isnt running and and that there is way too much gas in the system. Are you sure you tapped the process tube?
Sean
Posted on Mar 27, 2011
Location of bullet piercing valve on sanyo sr4433s compact refrigerator
Does the unit have a manufactures process stub on the compressor casing. That is where I put piercing valves to add refrigerant. Remember that EPA does not allow piercing valves to remain on system and the hole it forms has to be brazed shut. So if it does have a process stub place the peircing valve close enough to the end so you have enough stub to pinch off to braze thehole shut.
If there is no process stub, then install piercing valve in a convenient location in the suction piping and pierce the line. Remove the refrigerant and install a "tee". On one leg of the "tee" install a schreader valve pressure tap and rebraze the joints. Perform and pressure and vacuum test to check for leaks and weigh in the correct amount of refrigerant. Once your proficient at this procedure, it should take about 60 to 90 minutes depending on obstructions around compressor.
Just a comment, low air flow on evaporator give that same indications as a low charge. Make sure the evaporator fan is working and you have good air flow through evaporator section.
Hope this helps
Dec 09, 2014 | Sanyo Refrigerators
Where is the low pressure switch
Locate the compressor, then follow the hoses, one goes to the firewall and the other goes to the front of the vehicle. The one that goes to the front of the vehicle is the low pressure side. It should have a connection on the metal part of the tubing that looks like a valve stem for a tire. It will have a cap on it.
Oct 23, 2014 | Cars & Trucks
I need a diagram of the A/C low pressure port on my 1996 chevy blazer. I know it is aways on the larger diameter tubing but it seems the port seems tube seems to be coming right off the side of large...
Find a shiny aluminum canister under the hood thats bigger than a soda can and follow the tubing that comes out of it back towards the front, you will come to a valve similiar to an air valve stem on a tire. The valve has a black plastic screw off cap. That is the low pressure port. The high pressure port is located behind or near the a/c compressor
Sep 24, 2010 | 1996 Chevrolet Blazer
Im trying to charge my air conditioner in my 1996 Toyota Camary LXE that has a V6, but I can't find the air conditioner or the low pressure side.
THE LOW PRESSURE SIDE IS THE LARGER OF THE TWO LINES COMMING FROM THE AC COMPRESSOR, THE AC COMPRESSOR LOOKS LIKE THE PHOTO BELOW.64512e2.jpg
Jul 14, 2010 | 2003 Toyota Camry
04 Saturn Vue AC blows cool air for about one minute then hot air
Above solution is correct, had the same problem with mine and it was the expansion valve.
Jul 06, 2010 | 2004 Saturn VUE
Have 134a refrigerant and shop where I bought it said owners manual will have the how to instructions. Unfortunately it doesn't. I see on the line there is a stem to screw the hose into but want to make...
No,you won't find it in the owner's manual. It charges through the low pressure side,which is the larger of the 2 available ports. You can't hook it up wrong. I suggest you buy a Hayne's manual for the truck. It has 90% of any answer you might need. A/C can be tricky to fix for the novice. If charging doesn't work,take it to the shop.
Jul 13, 2009 | 2001 Dodge Durango
Problem with Bostitch air compressor Rilsan tube? Low pressure!
THE PRESSURE SWITCH HAS A RELIEF VALVE ON IT THAT DRAINS THE PRESSURE WHEN IT ELECTRICALLY SHUTS OFF. IT HAS A LEVER STICKING OUT THAT HITS A "SCHRADER" VALVE. COMMONLY KNOWN AS A "TIRE STEM" IN ANY VALVE STEM IN THE TIRE ON YOUR CAR. THIS VALVE COULD BE BAD OR THE LEVER STICKING OUT COULD BE BENT PRESSING ON IT ALL THE TIME. I WOULD REPLACE THE PRESSURE SWITCH, IT WILL FIX BOTH OF THESE PROBLEMS. TAKE YOUR SWITCH WITH YOU TO ENSURE YOU GET THE SAME THING (SIZE, PSI RATING, ETC) HOPE THIS HELPS. JODY
Jun 28, 2009 | Stanley Air Tools & Compressors
Location of low side A/C port on 2001 Lincoln LS V8
2002 is what I have. should be similar
Service Gauge Port Valves
The high-pressure service gauge port valve is located on the A/C receiver drier manifold and tube assembly.
The low pressure service gauge port valve is located on the manifold of the A/C compressor manifold and tube assembly at the A/C compressor.
23d30e7.gif Item Part Number Description 1 19860 A/C evaporator core 2 19849 Thermostatic expansion valve 3 19A834 Manifold and tube assembly—thermostatic expansion valve 4 19D850 Manifold and tube assembly—A/C compressor 5 19E762 A/C charge port valve (low side) 6 19E762 A/C pressure relief valve 7 19703 A/C compressor 8 19D594 A/C pressure transducer 9 19712 A/C condenser core 10 19D701 A/C charge port valve (high side) 11 19N585 Manifold and tube assembly—receiver drier 12 19959 Receiver drier 13 19C734 Sensor—evaporator air discharge temperature
Jun 11, 2009 | 2001 Lincoln LS
Coleman 5Hp Compresser
All electric compressors share a basic design with ac power pressure switch with unloader and checkvalve between the pump and the tank. When the pressure switch powers off, it unloads the compressor by releasing the air in the discharge hose. You will notice a small tire stem pin and a lever to engage it somewhere on the pressure switch. If the compressor stops before reaching set cutoff point, the air pressure remains in the discharge hose not allowing the motor to start, thus the hum you hear. Solution is to check for the proper function of pressure switch /unloader, tank check valve (if check valve leaks air back to compressor it will load motor causing hum) and extra measure check capacitor for at least 90% of rated valve. Finally, do not run this compressor with an extension cord, use more hose instead. enjoy
Oct 22, 2008 | Coleman CP0302013 20 - Gallon Portable...
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
