Question about Samsung Washing Machines
Describe your Problem samsung washer wont spin out
  • Samsung Master
  • 8,220 Answers
Items between tubs can cause the motor to stall on a lot of machines.
Overuse of detergent or clogged filter can also cause this.
Will not spin diagnostics and suggestions are found in Samsung's Front loading washer service manual page 43
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 27, 2011
My Samsung top load washer will not spin water out, when gets to 9 min left it starts shaking so bad and knocking it will stop and then jumps back to 22 min and rinse restarts!
indicates that the air dampeners on the ends of the suspension rods have failed and the out of balance system is not functioning
have a technician check the rods as without that dampening effect the unbalanced situation is not controlled and in effect multiplies itself causing what you describe
May 19, 2018 | Samsung Washing Machines
Samsung washer has code f 103 can you tell me whats wrong wont spin trys thenstops
I could not find code f103 but u said that it tries to spin but stops. is the drain pump coming on and removing the water from the washer? if there is to much water in the tub clothing it wont spin. check all drain lines to be sure they r clear.
Jun 02, 2014 | Washing Machines
Washer front loader wont spin or unlock
Find your book that came with the washer, and it will have trouble codes. Your lights are probably flashing a code. Count the flashes then look up your code in the book. That is a good place to start.
Mar 06, 2014 | Samsung WF203ANW Front Load Washer
Samsung washer wont spin
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Check this link for tips;
Jun 28, 2012 | Samsung WF337AA Front Load Washer
Wont spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 14, 2011 | Samsung WF337AA Front Load Washer
Samsung energy star silver care will wash wont spin
heatman101
Apr 01, 2011 | Samsung Washing Machines
I have asamsung washer model 3f316lasxaa sr 230854al400097w that wont spin
There is a recall by Samsung for your washer. Here is a link to the site where you can get your machine taken care of. I checked your model and serial number and yours is on the recall list.
Dec 21, 2010 | Samsung 4.0 cu. ft. Washer
Front loader wont spin
Hello there:
It doesn't spin If your washer won't spin, check these: If the motor is running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.
May 15, 2010 | Samsung Washing Machines
Washing machine wont spin
If when you say it is new, then if it is under a year old, then you should contact your service agent, or the retailer. There are many reasons that would stop it spinning.
Dec 08, 2008 | Zanussi FJS1225W Front Load Washer
Samsung WF 338 washer
Hello.
These are usually shipped with a number of "shipping bolts" to lock the drum in position during transit. If they are not removed when it is installed, then the washer will behave exactly as you describe. Check the manual or look for a sticker on the back or the washer showing which bolts to remove,
-ellie
Jun 26, 2008 | Washing Machines
Washing Machines Logo
519 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
