Question about Pioneer VSX-819H-K A/V Receiver
My Pioneed VSX-819H is less than 1 year old. Stopped switching from TV/SAT to any other mode. It used to have a slow response, but now it does not respond at all. Have checked all components attached and they are not the problem. Is there a bad relay that I could replace?
    Genius:
  • 1,114 Answers
It is usually a computer board issue which controls the unit. You could attempt to replace the bad relay, but you would have to test each part to find out where the electrical break is. You may get lucky and just have a bad switch which controls the selections, or even a bad fuse. Take the cover off and see if there is a faulty fuse, or lose connection. You may be better off taking it to an electrical repair shop.
Posted on Mar 27, 2011
How too reset pioneer 4800
Check page 69 of the manual :
Resetting the main unit
Use this procedure to reset all the receiver's
settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the BAND button,
press and hold the STANDBY/ON button
for about two seconds.
3 When you see RESET? appear in the
display, press 'AUTO SURROUND/STREAM
DIRECT'.
OK? shows in the display.
4 Press 'STEREO/A.L.C.' to confirm.
OK appears in the display to indicate that the
receiver has been reset to the factory settings.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-819H_OperatingInstructions0508.pdf
Jun 15, 2014 | Pioneer VSX-819H-K A/V Receiver
Pioneer 409 setting up for surround sound
I think there is a switching problem in the surround receiver. I would take the receiver to a qualified servicer. There is nothing user serviceable in the unit. Question .Why are you using optical output from ps3. I recommend you connect all you a/v devised to the tv. Then connect the opt out of tv to receiver. that way what ever you are viewing will send audio via opt out of tv to receiver. that way you do not have to switch input on receiver. Hope this helps.
Jan 07, 2014 | Pioneer VSX-D511 Receiver
How to reset pioneer vsx-819h
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx819hk.html
It's in the manual. Page 12.
Resetting the Main Unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this.
2 While holding down the BAND button, press and hold the STANDBY/ON button for about two seconds.
3 When you see RESET? appear in the display, press AUTO SURROUND/STREAM DIRECT.
4 Press STEREO/A.L.C to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory settings.
Sep 08, 2011 | Pioneer VSX-819H-K A/V Receiver
My vsx-819h shut down and wont turn back on
hold "Advanced Surround" button, press "Standby" button for 3 seconds, unit will power back.
Jan 17, 2011 | Pioneer VSX-819H-K A/V Receiver
Is there a fuse for the VSX-819H
yes all appliances have a fuse , try to dettach all the speakers and plug it on ,if it work one of your speaker had a problem.( if your unit had a warranty bring it back to the dealer )
Mar 03, 2010 | Pioneer VSX-819H-K A/V Receiver
Twice now my Pioneer VSX-819H has shut down. Can not get any power to it. The first time I'm sure the phono pre-amp caused a surge. I no longer have it hooked up. The servicer said nothing was wrong and...
I found this for the VSX918, 818. Perhaps it's similar.
The power does not turn on. • Disconnect the power plug from the outlet, and insert again.
• Make sure there are no loose strands of speaker wire touching the rear panel. This could cause the receiver to shut off automatically.
The receiver suddenly switches off and the power indicator
blinks.
• After about a minute (you won’t be able to switch the unit on during this time), switch the receiver back on. If the message persists, call a Pioneer authorized independent service company.
Use this procedure to reset all the receiver’s settings to the factory default. Use the front panel controls to do this.
2 While holding down the ADVANCED SURROUND button, press and hold the
STANDBY/ON button for about three
seconds.
3 When you see RESET? appear in the display, press ‘
ST –’. OK?
4 Press SOUND RETRIEVER to confirm.
OK
Mar 02, 2010 | Pioneer VSX-819H-K A/V Receiver
Installition manuel for vsx-819h-k
Here is the official link for your receiver. In case you need further help don't hesitate to post back.
Feb 24, 2010 | Pioneer VSX-819H-K A/V Receiver
Pioneer digital tuner Z92 not working year 1989, would it be worth repairing or buy new tuner. regards Michael.
It may just need an adjustment. Check for audio in mono mode. If you get audio, then it needs an adjustment of the IF can. If still no audio pioneer commonly used an LM7001 14pin (might be16pins) IC, that goes bad.
Dec 30, 2009 | Pioneer VSX-819H-K A/V Receiver
Pioneer vsx-819H: MCACC setup won't display on tv
I would say check the cable version not everyone knows this but there are different version HDMI cables such as 1.0,1.1,1.2 and the newest 1.3 cable these are band-with depended cables and if you use a lower version this should work if not you might have a issue with video.
Other then that you might have a issue with the unit if all other signals are working on the monitor.. Ruling out this will be hard if you do not have another monitor to test it on. I would be conducting a test on other output monitors and see if you get any results.
please press the accept button as I worked hard to answer you question.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 24, 2009 | Pioneer VSX-819H-K A/V Receiver
Pioneer VSX-819H-K A/V Receiver Logo
71 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
