Question about Microsoft Xbox 360 Console
I have a thomson TG585 V7 and i am trying to connect an xbox 360 to xbox live through an ethernet cable and i am having the mtu error come up and cant find the mtu setting on my router
SOURCE: PC Selected - Failed
Click Start, click Run, type cmd.exe, and then click OK. a. At the Command Prompt, type the following text all on one line: reg add HKEY_LOCAL_MACHINE\SYSTEM\CURRENTCONTROLSET\CONTROL\CLASS\{4D36E967-E325-11CE-BFC1-08002BE10318} /v UPPERFILTERS /t REG_MULTI_SZ /d PartMgr /f You receive the following message in the Command Prompt window, to indicate that this command was accepted: The Operation Completed successfully After you done that restart and download xboxxpsp2-enu.exe...and you should be good to go if your firewall ports are open 1900,10280,10281,10282,10283,10284 dup and 2869,10243 tcp good luck Restart the computer. 4. After the computer restarts, you can run the Media Center Extender for Xbox 360 application
Posted on May 07, 2008
SOURCE: xbox live cant connect mtu failed
Hi can you please help me i was on xbox live tryed to connect with a router and now my 360 is askin for an ip address,but we do not no it can you please help thanks Paul
Posted on Aug 02, 2008
thegoshem
  • 61 Answers
SOURCE: XBOX 360 LIVE Won't Connect
Is the modem also a router?
You need to login to the IP address of your device... if the modem is only a modem, try going to your own IP address.
http://whatismyip.com will help you find it. This may bring you into the settings of the modem. If it is a router as well, then you will need to go to your default gateway's IP address.
Go to start, then run.
Type cmd, then click ok.
type 'ipconfig' and hit enter. Look for your Default Gateway
type that ip into your browser (IE/Firefox/whatever) and login
adjust the MTU to recommended settings. If its at 1500, try 1364 of 1492
Posted on Jun 16, 2009
  • 34 Answers
SOURCE: trying to set up xbox live.
you need to make an xbox live profile not mtu for offline. You have to make a new profile.
Posted on Jun 23, 2009
  • 5 Answers
SOURCE: Xbox not recognizing ethernet presence
did you buy a new ethernet cable if you didnt i recomend the cat 5 (blue from staples depending on your length get what you think is good trust me it lasts and mine was only 15 bux (100 footer) if youve already tryed this cord it might b the socket of the plugin try blowing on it or have it sent in (if the warranty is good your on the house if its not your goona have to pay a lil cabbage ;) ) dont worry its not sent in forever
Posted on Aug 17, 2009
Hey i have a thomson TG782T and i am trying to connect an xbox 360 elite to xbox live through an ethernet cable and i am having the mtu error come up. i already have an xbox 360 slim connected which works...
Maximum transmission unit is 1500, but for the Xbox 360 it "must" be set within the range 1364 - 1492
Since there's no MTU settings for the TG782T. your only choice is to replace it with routers like Linksys, Belkin, Netgear.
Jan 05, 2011 | Microsoft Xbox 360 Console
I m having trouble cobbecting my xbox I have a thomson tg585 v7 wireless router
Do you have a wireless adapter for your 360. If not then you need to make a wired connection
Oct 24, 2009 | Video Game Consoles & Games
Non connectivity with thomson tg585 v7 modem with bsnl broadband.
what is bsnl broadband if you have thomson to acsess the setup and all it freater just type speedtouch.lan in your browser this may help you
i think
Jul 02, 2009 | Thomson RCA DCM245R Modem
Have the n+ wireless router/modem trying to connect via a cable to xbox live but keep gettin insufficient MTU even though the actual MTU of the router is higher than required
You may have to use trial and error to find the best MTU fit:
MTU Default of 1500 to 1492
Tart the setting the MTU @ 1400
MTU setting. Xbox LIVE requires a minimum MTU setting of 1364.
The information your console sends and receives is broken up into "packets" for transmission over your network. MTU is a setting that controls the size of these packets. If it's too small, you won't be able to connect to Xbox LIVE.
Top Solutions Try these solutions in order. If you give each one a shot and you still can't connect, contact Xbox Customer Support. Note that they will ask you try the suggestions on this page first.
Solution 1: Check your router MTU settings Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Solution 2: Connect directly to the modem If your router's MTU is set correctly, try bypassing it by connecting your console directly to the modem. This will help determine whether there's a problem with your router or something else on your network.
Note
This may require you to move your console to a location close to your modem. This is a temporary arrangement, meant only to troubleshoot your connection. If your console is connected wirelessly, you'll need an Ethernet cable for this step.
To connect your console directly to your modem (wired connection):
  1. Find the Ethernet cable that runs between your console and the router.
  2. Unplug the cable from the router, leaving it connected to the console.
  3. Find the Ethernet cable that runs between the router and the modem.
  4. Unplug the cable from the modem, and plug the cable from your console in its place.
To connect your console directly to your modem (wireless connection):
  1. Unplug the USB connector for your adapter from the console. The adapter can remain attached to the console.
  2. Plug an Ethernet cable into the Ethernet port on the back of the console.
  3. Find the Ethernet cable that runs between your router and the modem.
Try to connect to Xbox LIVE again. If it works, there may be an issue with your router. Double-check the MTU setting in solution 1 above. Also confirm that you're using a compatible router, and make sure it has the latest updates from the manufacturer. If the problem persists, you may want to try a different router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 06, 2009 | Belkin N1 Vision Router
We tried going on xbox live everything but the MTU didnt work.
Try it with the ethernet cable,that should work. Then try wireless, if it doesnt work, you'll have to take it further into your router config. Contact me for more assistance (MSN iBen@Gmx.Co.Uk
Feb 28, 2009 | Microsoft Xbox 360 Console
Open NAT with Thomson (Speedtouch) TG585 v7 Router
First, try adding a wireless card to the Xbox, run the wireless off of the router OR if you have multiple connections (broadband, should be an "In" port, and several "Out" ports) Try connecting your PC and you Xbox through the "Out" ports, with the cable modem cord hooked into the "In" port...
Feb 02, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Thomson TG585 v7 malfunction
just one answer frimware filure did you skip or try to frimware you self with lan cable
Jan 17, 2009 | Thomson 29DM400 29" TV
Wireless xbox connection to thomson tg585 v7
try to change the channel on the wireless router and make suer the encryption is off or you know the key
Jan 10, 2009 | Microsoft Wireless Network Adapter Xbox...
360 mtu test keeps failing
Access the routers setup page by typing 192.168.1.1 (ip address of the router) on the address bar on IE.
then on basic setup page at the bottom part of the page you will see MTU normally its on auto,
to change the value set it to manual. ask your isp what is their prefferred value for the mtu you can go as high as 1300 to 1500.
Sep 13, 2008 | Linksys Wireless-G WRT54G Router
Microsoft Xbox 360 Console Logo
305 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
