Question about Whirlpool Inglis IP8200 Dryer
My dryer is making a humming noise. I turned it on and it shut itself off. So I turned it back on and the drum wouldn't spin but made a humming noise so I turned it off. My boyfriend looked at it and made sure all the vents are clear then turned it on. The drum spins and heat is coming out but it is still making that humming noise any thoughts?
  • Whirlpool Master
  • 8,220 Answers
Look for something in the blower housing
My dryer is making a humming noise. I turned it on - themobilian_2054.jpgthMy dryer is making a humming noise. I turned it on - themobilian_2053.jpgclass=themMy dryer is making a humming noise. I turned it on - themobilian_2056.jpgass=themobMy dryer is making a humming noise. I turned it on - themobilian_2058.jpgs=themobilMy dryer is making a humming noise. I turned it on - themobilian_2060.jpgthemobilian_2057.jpgthemobilian_2059.jpgthemobilian_2060.jpg
Service Manual and more photos HERE
Posted on Mar 27, 2011
Dryer makes humming noise drum won't spin just goes back to pause
take out the plug and change the capistor ..make a note of the wires and take picture where they go
Aug 05, 2014 | Electrolux EIED55HIW Electric Front Load...
Electrolux front load dryer does not start
if it makes a humming noise for a short peiod then stops and after a while it does it again the drum maybe stuck and making the motror go off on overload try turning the drum by hand and see how it spins
Jan 08, 2013 | Dryers
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
My Kenmore 90 Series electric dryer makes a humming noise when I push the start button. It heats up, run for a short while, then stops. Before it stops there is a clicking noise like a circuit or safety...
There's possibilty that the bearing is going bad. It would cause the belt to slide alittle when the drums starts to turn. The strain on the motor because of the bad bearing can cause the motor overload and shut down until it cools, then it can be restarted.
Apr 08, 2011 | Dryers
My kenmore dryer makes a humming noise when u turn it on n the drum will not spin
If you are hearing a humming noise and no spinning . You have a burnt motor..Do not attempt to switch it on till you fix it to prevent further damage
Mar 07, 2011 | Dryers
Dryer wont start, makes a humming noise. I have to manualy turn the drum then the dryer will start
Check the belt to see if it is worn or loose. If it has a capacitor start motor, the capacitor or motor could be going bad also. If the motor is spinning but the belt is not turning then you have a loose belt.
Jun 14, 2010 | LG DLE2532W Electric Dryer
Drum not turning, hear humming noise
the humming noise is from the motor,see if you can spin the drum by hand,if it moves you have a bad motor,if it's hard to turn you could have something stuck in the blower wheel or the belt is jammed somewhere,the blower wheel is behind the duct that the lint filter slides into
Mar 20, 2010 | Whirlpool LER4634J Electric Dryer
Dryer won't spin, but heats up - belt is okay
the motor may have seized up, or the drum bearings are shot.
Jun 19, 2009 | GE DBL333EA Electric Dryer
The dryer just makes a humming noise when I turn it on, but won't turn all the way on
When you say it won't turn all the way on, does that mean the drum isn't rotating?
If yes, the belt from the motor that goes around the drum might have broken and you can hear the hum of the motor spinning but no longer rotating the drum.
The other thing I can think of is that the motor itself has failed, possibly seized, and you can hear the motor trying to spin but it cannot. With the dryer unplugged and empty of clothes, try to rotate the drum. If it rotates extreamly easily, then the belt has broken. If you cannot rotate it at all by hand, then chances are the motor is seized. It should rotate with moderate effort.
Mar 08, 2008 | Dryers
Whirlpool Inglis IP8200 Dryer Logo
334 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
