Question about Whirlpool 24 in. GU3200XTP Built-in Dishwasher
Our dishwasher started smelling like something is burning, I turned it off straight away, no visible smoke or anything but it hasn't been cleaning very well for a while now. Are these the death throes? Or is it worth calling someone out to fix it?
Make sure there isn't any plastic on the heating element. Also check to see if there is any evidence of previously melted plastic. If it smells like plastic burning & you aren't using any heated options, cut the power & call for service.
Posted on Mar 28, 2011
Why is the dishwasher smelling like electric burning and smoke coming out of the door vent?
Hi friend, thank you for your post!
I understand that your Frigidaire dishwasher is giving off an electric burning smell and you are seeing smoke coming out of the door vent. It could possibly be an issue with your control panel or door vent, both have electrical components inside of them. Since it could be either one of these underlying issues I would recommend having a technician come out to your home and diagnose and repair the dishwasher. Hope this helps. -Matt
Jul 27, 2014 | Frigidaire Dishwashers
Bosh SHY56A Dishwasher - Loud Pop and Smoke While
Hey Matt,
Dishwashers are not that complicated.. Turn off the breaker, pull the machine out - away from the wall..(there will/should be at lest two screws in the top edge holding it to the counter.. remove them first.. then pull it out until you can turn off the water supply.. When you are able to completely remove the washer, you should be able (possibly)to see what happened.. Check to see if the washer arm (inside the washer) will turn, if not.. replace the motor.., check to see if the pump belt will turn?.. it could be the pump drive motor or the pump its self..(remove the belt), then see if the motor will turn, check to see if the pump will turn.
.. White smoke makes me think that the belt was turning and the pump NOT turning..that will cause the belt to smoke.. and smell like burning rubber..If the pump will not turn. you have found t he problem... Also ..Check to make sure there is not a knife or some other object lodged in the drain or pump
NOW -- With all this.. Sometimes REPLACING the machine is actually cheaper than repairing the old one!!! Your wife deserves a NEW one!!
Jun 28, 2017 | Dishwashers
Everytime I start my whirpool dishwasher it smells like smoke. If left on for a while a burning smell and steamy smoke come out when I open the door
I would check your heating element to make sure it is clean of plastic on some label that is against it some type of paper or what have you this element heats just like a oven and can burn objects on it or touching it.If you see a spot clean it very gently until that it all is the same color use a scruff pad sponge to use for removal of the spot in question. Remember to rate my solution and give testimonial this is how i earn achievements here on FixYa Thanks in advance.
Apr 25, 2012 | Whirlpool Dishwashers
JVC I'ART PRO WILL NOT TURN ON
hi keith, if it smokes a bit leave unplugged and get a engineer to have a look at it straight away good luck
regards
shaun
Nov 27, 2011 | JVC AV-56WP30 56" Rear Projection...
Rubber burning smell and smoke
It sounds like a pulley froze up. Pop the hood have someone start the car while you are looking at the pulleys, you should be able to see the problem.
May 14, 2009 | 2002 Daewoo Lanos
Dishwasher smoking
nothing specific until you get a technician to properly diagnose the fault
Aug 19, 2017 | Frigidaire 24 in. FDB1050REC Stainless...
Burning smell and smoke
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Whirlpool 24 in. GU3200XTP Built-in Dishwasher Logo
402 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
